WestyDreamer Samba Member
Posted: Sat Jun 29, 2013 12:27 pm Post subject: LED Tail Light Bulbs |
Anyone using the newer LED Tail light bulbs.. Saw that GW and others sell a bulb kit but I'm mainly concerned with the Driving Lights, as they are dim.
I was thinking of using one of those flat LED boards that have 36 or 40 LED's on it and the 1156 style base that would fit into the tail light socket.
Question. Should we use the clear white bulbs or Red LED bulbs, or wouldn't it matter?
kamzcab86 Samba Moderator
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Sat Jun 29, 2013 1:11 pm Post subject: |
FWIW -- I went with the 50W brake lights sold by Terry K. Real bright, much brighter than some LEDs I tried -- but too much heat for anything other than brake lights I think.
I used the LEDs for the rear turn signals -- not just brighter but (IMO) a more abrupt flash to them which helps visibility. |
geodude Samba Member
Posted: Sat Jun 29, 2013 1:50 pm Post subject: |
My dear wife got me the VC setup for Fathers Day (Love that woman) and what I found was the running lights were much brighter, the reverse are about the same brightness as my old ones that I had added reflectors to (so would likely be brighter than stock), the turn signal and brakes are about the same brightness but much quicker coming on. I had my wife hit the brakes and the LED was on instantly and there was a very noticeable wait until the conventional bulb on the opposite side that I hadn't changed yet came on. I'd guess 0.1 to 0.2 seconds for the conventional light to get bright. That's pretty significant. All in all I think worthwhile change.
I also homebrewed my own headlight relay system with separate power taps for the headlight and highbeams running to two relays in a small weatherproof box. The headlights are much brighter than stock. Went from dim yellowy spots to more of a white beam on the pavement. Much more comparable to a newer car light output. Definitely worth $50 to do. _________________ 1988 GL Camper
1991 Multivan — the basket case |
r39o Samba Polizei
Posted: Sat Jun 29, 2013 2:19 pm Post subject: |
Adding in a better power source system and cleaning / replacing the headlamps makes a HUGE difference, generally. _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
joseph928 Samba Member
Joined: September 22, 2011 Posts: 2114 Location: flagstaff az.
Posted: Sat Jun 29, 2013 3:39 pm Post subject: Re: LED Tail Light Bulbs |
WestyDreamer wrote: |
Go Westy love them, also put in the extra bulb. Now have two tail lights! Kam is right on the color of bulb to lens. _________________ 1987 syncro westy tin top sun roof , GW2.3, rear locker, decoupler, Gary Lee tire rack & winch mount, lift, south african grill, big brakes , rhein alloy ,15 BFG AT, Fiamma 10 foot awning ,140 watt rear 85 watt front solar , mppt, truckfridge, automatic fire extinguishing system, tencent oil cooler, And a RMW SS exhaust! - 1971 bug convertible 1776 engine- 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley 95 CI, big bore, Andrews cams . Also 80-84- vans. Stock 65 sunroof bug. |
Syncroincity Samba Member
Joined: April 15, 2007 Posts: 1557 Location: New York City
Posted: Sat Jun 29, 2013 6:00 pm Post subject: |
I'm running these in red in both my van and the Passat;
http://www.superbrightleds.com/moreinfo/tail-brake...tower/526/
They are very bright, and make good use of the reflectors built into the tail lights.
I used some flat panel boards like you described for the brake lights on the van. The leds are white, and I don't like the output compared the the ones above; I'm going to change them out to another set of these. The red LEDs give you a very rich, true red color that really pops out, the white ones behind a red plastic lens look washed-out and pinkish.
I did the panel LEDs in the rear turn signals, too... these I actually like.
It's a fiddly mod for no improvement in output over the tower bulbs above, which pop right in, and it's a pain in the butt to take the tail lights out once they're in. I glued the panels inside the reflectors.
ps. There's 10% off until July 4th. Promo code 070413 _________________ '86 Syncro CHC Top AAZ Turbodiesel
'04 Passat Variant 4Mo 5MT
Vanagon Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=466866&highlight= |
wcdennis Samba Member
Joined: July 20, 2004 Posts: 955 Location: Winston-Salem NC
Posted: Fri Jan 09, 2015 10:06 pm Post subject: |
I was poking around on the web today and discovered these LED tail light assemblies:
http://www.amazon.com/ZNU-Light-Truck-Caravan-Bulb...ail+lights
They are almost exactly the same size as the Vanagon tail light. To get an idea of how they would look, I tried them on with PhotoShop.
I'm not sure about the look, but it would be nice to never have to worry about replacing bulbs ever again. Anybody have an opinion?
PS Not my van, but the same colors. |
Syncro Jael Samba Member
Posted: Fri Jan 09, 2015 10:33 pm Post subject: |
I too bought the GoWesty exterior LED kits for our vans. They are very bright and have been flawless for a couple years. Even the backup lights are bright now. It's hard to spend that much on bulbs but I would do it again in a heartbeat. _________________ 1987 Syncro Westfalia Hightop - NAHT
Subaru EJ25 Forged Frankenmotor, Triple Knob.
Jael = (Mountain Goat) |
thatvwbusguy Samba Member
Joined: April 18, 2007 Posts: 1712 Location: Newmarket, New Hampshire
Posted: Fri Jan 09, 2015 10:37 pm Post subject: |
I bought a set of fairly similar LED tail lights a while back, but the fit was not quite right. For the relatively small investment, it would be great to know if this model would work on the Vanagon without a lot of custom fabrication.
Another nice option with LED tail lights is faster activation, which can (theroetically at least) help with reaction time for drivers behind you when you hit the brakes. _________________ Jay Brown
'85 Zetec Westfalia
Newmarket, NH
If you want others to be happy, practice compassion.
If you want to be happy, practice compassion. |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12008 Location: Santa Cruz, CA
wcdennis wrote: |
The ones you are looking at are even larger.
thatvwbusguy wrote: |
Sorry for not following up sooner. The lights are actually fairly bright from a distance, unfortunately they are about 1/2"-5/8" too long to fit correctly. This makes them protrude into the recessed space toward the center of the van, which pretty much means there is no way to seal them from the weather. Oh well, you win some, you lose some…
http://www.thesamba.com/vw/forum/viewtopic.php?t=5...p;start=20 |
ThankYouJerry Samba Member
Joined: September 01, 2012 Posts: 2271 Location: Shakedown Street
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Fri Jan 09, 2015 10:50 pm Post subject: |
wcdennis wrote: |
It makes the Vanagon look like a vehicle of this century.
But at $86 for a pair I'd rather use the money for fuel lines or headlight upgrades.
Photoshop is easier than installation.
Aloha
tp |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10252 Location: N. Idaho
Posted: Fri Jan 09, 2015 11:59 pm Post subject: |
Thanks, Jerry. I ordered those Amazons right away directly from your recommendation. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
luVWagn Samba Member
Joined: February 21, 2008 Posts: 1340 Location: Snoqualmie (WA)
Posted: Sat Jan 10, 2015 1:01 am Post subject: |
IdahoDoug wrote: |
Thanks, Jerry. I ordered those Amazons right away directly from your recommendation. |
Damned impulse shopping, me too! _________________ '91 Syncro 16 Reimo Hightop Conversion, eTDI |
Posted: Sat Jan 10, 2015 5:22 am Post subject: |
The review on Amazon:
"Light were terrible.... You could not even tell they were on because they were so dim. Would not recommend these lights at all."
Hopefully he wrote that in the daytime.
Do they have both taillights and brake lights in the red lens?
I assume the yellow is for turn signals.
Please post your installation and illumination comments when the job is done.
Aloha
tp |
Posted: Sat Jan 10, 2015 7:30 am Post subject: |
It looks like it has already been tried:
Thanks for finding the thread I missed, syncrodoka.
thatvwbusguy, who tried the very similar lights, passed on the installation because they were about 1/2" too long.
I have already started down the LED bulb route but, so far, only replaced the back-up lights. I was thinking this unit would be great way to do away with the tenuous sockets in the stock tail light. I think I will hold off for now but if someone wants to try, here is the same unit at a better price (for a pair):
http://www.amazon.com/GENSSI-Trailer-Commercial-Li...JBCPG1ASC2 |
Posted: Sat Jan 10, 2015 9:45 am Post subject: |
One thing I've noted from playing a bit with LEDs is that a large number of dim/cheap LEDs in a tail light doesn't create the same perceived brightness on the road as fewer quality bright LEDs. A lot of sellers are offering the former and crowing about "114 LEDs" but not revealing the LED's draw. For instance, the back up lights I just ordered above are single CREE 7W LED. Those are going to to be very bright for back up lights and CREE is a worldwide leader.
So, don't be blinded by sheer quantities of likely cheap LED which won't look impressively bright in the real world, compared to fewer quality LEDs. And if they don't list the draw (3W, 7W, etc) be suspicious.
DougM _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
JED THE SPREAD Samba Member
Joined: July 14, 2009 Posts: 626 Location: South London UK
Posted: Sat Jan 10, 2015 10:22 am Post subject: |
I agree the GW backup LEDs are brighter than stock but still not enough for backing up at night off-roading.
This 36w Cree Flood LED does the trick nicely mounted up high.
