crvc Samba Member
Posted: Sat Jan 24, 2015 12:45 pm Post subject: Insulation under luggage comparrment |
I have a 1967 bug with a stock 1600 engine. I added foil-backed insulation all atop the luggage compartment and under the rear seat. But it's still too noisy. I still have plenty of insulation I could glue under the luggage compartment. Will engine fumes or oils dissolve the glue?
Any suggestions?
TIA,
crvc |
AZ66Bug Samba Member
Joined: February 17, 2014 Posts: 311 Location: Chandler, AZ
Posted: Sat Jan 24, 2015 1:23 pm Post subject: |
Don't think it would do any good to add to the outside. Might try some padding on the inside. The carpet kit I just installed came with some 1/2 inch padding that I added on top the Dynamat in the luggage area. As for noise, I don't think anything will stop that completely - its a noisy engine! _________________ 66 Beetle Sedan, restored 2014
66 Mustang: Original Owner, restored 2008
66 Ford F250: 4th Owner, restored 2013 |
yammi450 Samba Member
Joined: October 04, 2005 Posts: 149 Location: Las Vegas,Nv
A lot of noise comes in from the opening in the C pillar if you don't have any filling in there. Use the search for "footballs" and it will give you some ideas. I know when I stuffed mine it made a noticeable difference. |
microbus Samba Member
Joined: October 12, 2007 Posts: 527 Location: Alberta, Canada
Posted: Sat Jan 24, 2015 1:27 pm Post subject: |
I don't think you want to install anything on the outside that might trap water/dirt and aid in the formation of rust! More padding inside... Try driving a Canadian Standard with no lower headliner/padding... ugh! _________________ Darsh Import/ Dubsport Inc... my own VW Parts and Repair shop.
Automotive Service Technician |
ThorpS18 Samba Member
Joined: November 19, 2009 Posts: 160 Location: So. California
Mark Samba Member
Joined: January 20, 2003 Posts: 1523 Location: Victoria, BC Canada
Posted: Sat Jan 24, 2015 8:09 pm Post subject: |
They came from the factory with the 'football' pads in the C pillar.
Mine shows no signs of rust, with the car living in the PNW for 50 years now. |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Sun Jan 25, 2015 5:18 am Post subject: |
On my 65, I did a couple layers of Peel and Seal on the inside from below the window to, and including, the floor. Dont forget wheel wells. Then the usual padding and carpet. BUT on the engine side, I only used cheap aftermarket tarboard over a bare firewall. Already had made and installed replacement pads jammed in the C pillars. Was still a bit louder than I liked.
The next time I pulled the engine, I installed generic "under hood" insulation on the engine side of the firewall and a better tarboard. Made a very noticable difference. _________________ D-Dubya Manx clone - 63 Short pan,1914.
