Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Sat Jan 31, 2015 4:45 pm Post subject: what could this empty taillight socket be used for? |
I started these questions as an addition on another thread, but got no responses so here is a new post with my questions.
GreenMachineVW wrote: |
AdrianC wrote: |
The empty position's used in some markets for the high-intensity fog light, which uses a 21w bulb, so it really shouldn't melt.
Not quite. The empty position is used for a low intensity running light, the outer position is used for a 21W brake light, and the inner position is used for 21W fog lights. 21W could very easily melt the lense in that position. |
I wanted to try a LED backup light and compare it with the incandescent light. I noticed the empty socket and did a search and came up with the above info. My question is when does that socket have power? Why not put a bulb in there just for some more illumination for other drivers to see?
Aloha
tp |
CHARLIE-DONT-SURF Samba Member
Joined: November 16, 2007 Posts: 332 Location: Cow County, UK
Posted: Sat Jan 31, 2015 4:59 pm Post subject: |
In Europe they are tail lights.
The single light on right is for a fog light.
The middle two - top one is reverse and bottom has a 10w bulb that is on the same time as any of the front lights ( we didn't have 'side markers' in our indicators/traffic direction flashers or whatever you call them over there!!! In the headlight there is a 5w side light in the reflector bowl and then the usual dipped/main beam)
Left two - top is indicator/traffic flasher/blinker bulb. Bottom one is brake light.
Been few years since I've driven in the US but IIRC you have some weird(to us anyway) going on with your lights over there
At night, when you have headlights on, what light acts as a rear tail light/position marker? _________________ https://www.facebook.com/Cow-County-Looms-1010851485971680/ |
Posted: Sat Jan 31, 2015 5:01 pm Post subject: |
Oh , and to answer your question , which I successfully managed not to do very well....
It should have power as soon as you put any of the front lights on (totally confused now what you call yours over there, but the rocker switch to the left of the speedo)
That's IF vanagons have euro spec wiring loom on the rear. _________________ https://www.facebook.com/Cow-County-Looms-1010851485971680/ |
Home Team Van Samba Member
Joined: January 02, 2008 Posts: 465 Location: wilmington, nc
Posted: Sat Jan 31, 2015 7:09 pm Post subject: |
If I'm not mistaken there are a few threads about that open socket. I believe you have to run a jumper to it to get power. _________________ _________________________________
82 Diesel Westy |
insyncro Banned
Posted: Sat Jan 31, 2015 7:13 pm Post subject: |
Home Team Van wrote: |
If I'm not mistaken there are a few threads about that open socket. I believe you have to run a jumper to it to get power. |
Yup |
joseph928 Samba Member
Joined: September 22, 2011 Posts: 2114 Location: flagstaff az.
Posted: Sat Jan 31, 2015 9:26 pm Post subject: rear light |
yep! X-3 run a jumper. led lights way better. _________________ 1987 syncro westy tin top sun roof , GW2.3, rear locker, decoupler, Gary Lee tire rack & winch mount, lift, south african grill, big brakes , rhein alloy ,15 BFG AT, Fiamma 10 foot awning ,140 watt rear 85 watt front solar , mppt, truckfridge, automatic fire extinguishing system, tencent oil cooler, And a RMW SS exhaust! - 1971 bug convertible 1776 engine- 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley 95 CI, big bore, Andrews cams . Also 80-84- vans. Stock 65 sunroof bug. |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12008 Location: Santa Cruz, CA
Posted: Sat Jan 31, 2015 9:35 pm Post subject: |
Look in the FAQ. There are a few threads there that show what to do with the socket. |
danfromsyr Samba Member
Posted: Sat Jan 31, 2015 10:18 pm Post subject: |
many of us have done that mod
there is no center +12v power pin, you have to mount one of these replacement pigtails (requires modification to fit) or a custom LED (red) into the hole
pigtail is available at your local FLAPS in the replacement electrics isle.
Abscate wrote: |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32634 Location: Reading Pennsylvania
