Vintage Speed Exhaust Recent?
Page: 1, 2, 3, 4, 5  Next
sled
sled is offline
PostPosted: Mon Feb 02, 2015 6:47 pm    Post subject: Vintage Speed Exhaust Recent? Reply with quote
has anyone bought a vintage speed stainless exhaust for a bus recently? Like within the last 6 months to a year maybe?
I have read all of the previous threads about these exhaust systems so I know what the issues are and I am wondering if they have addressed the fitment and alignment issues?
and yes I know I can contact the manufacturer (and have) but customers almost always provide a better review.
it seems a couple people say their systems fit like a glove, while most people describe severe issues.
drive your split.
EDragnDean
EDragnDean is offline
PostPosted: Mon Feb 02, 2015 7:01 pm    Post subject: Reply with quote
I didn't have any issues. Superflow, heater box flanges, no heat riser. Unit is adjustable, so I found it to fit better than EMPI headers, is louder than a stock exhaust.
63 Double Cab http://www.thesamba.com/vw/forum/viewtopic.php?t=443823&highlight=deanos
66 Bus Click to view image - SOLD
73 Thing http://www.thesamba.com/vw/forum/viewtopic.php?p=8111202#8111202
70 BusClick to view image
zuggbug
zuggbug is offline
PostPosted: Mon Feb 02, 2015 7:14 pm    Post subject: Reply with quote
Jake, I purchased the 4 tip last year, and am running it on my 58. It fit well, but very tight to the rear apron. If i had to do it over again i would buy pictured above. I started smelling fumes the day I installed it. I have run with a C0 detector in the bus, no carbon monoxide, but I still have a faint smell of exhaust fumes when i slow down.
here are some pics of the fit.
I have since cut 4 1/2" off the tips
SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy
donald.lemay
donald.lemay is offline
PostPosted: Tue Feb 03, 2015 3:39 am    Post subject: Reply with quote
I have the 42mm full flow standard tail pipe. Fit was awesome and packaging was like a work of art.
Don
66 13 window deluxe
2085cc
9to1compression
ported polished heads 40x36 valves
010 distributor
VS 42mm exhaust
40 IDF carbs
curtis4085
curtis4085 is offline
PostPosted: Tue Feb 03, 2015 4:23 am    Post subject: Reply with quote
I have a couple of vintage speed exhausts,, one of which is currently in transit from vendor. I have one VS exhaust for the lowered vehicles installed by PO. Its functional yet at stops will the right breeze you may get a hint of fumes. No big deal in my book.. If in not smelling gas, oil and the bang of a typewriter I'm not living life to the fullest.
I also have the stock sport versions a well. The fitment I found much easier than reinstalling an empi, yet as others state some of the flanges #1-2 side for me could have lined up better for flow. This was on a bone stock engine. Am Currently having Pat at Vee W-Unlimited building me a Stroker and I'm interested to see if the VS exhaust flanges will line up any better because the engines slightly wider.
I'm still sold on the VS exhaust by it once by it for life!!
Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com
BulletBus
BulletBus is offline
PostPosted: Tue Feb 03, 2015 6:20 am    Post subject: Reply with quote
I will be putting one on a type 4 conversion. Will post fitment results.
53 Hatch Barndoor
If it's not a bus, it's bus money waiting to happen.
otis_bartleh
otis_bartleh is offline
PostPosted: Tue Feb 03, 2015 7:58 am    Post subject: Reply with quote
Bought mine last summer and love it...
-Adam
'59 Mango Bus
'69 Bug - Cobalt Blue
Red Fau Veh
Red Fau Veh is offline
PostPosted: Tue Feb 03, 2015 8:09 am    Post subject: Reply with quote
I had to cut the apron for the muffler and cut some relief in the rear most tin to clearance the tubes with that white fiberglass looking material on them. Also needed to cut and custom make the heater boxes fit. It is a good system but it is fat and tight ime.
1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
1973 Orange transporter stock type 4 with dual 40 Dellortos and Empi single quiet pack
1969 Adventurewagen blue whale Gene Berg 1776 built by Dave Kawell dual 36 DRLA's, Vintage Speed exhaust, Bosch 019 screamer
1961 Swivel Seat camper, L345 grey
Touch Nicks Thing wrote:
Swivel Seat panels are for people with no friends Crying or Very sad
GTV
GTV is offline
PostPosted: Tue Feb 03, 2015 8:32 am    Post subject: Reply with quote
Just for clarity, yours is installed on a Bay.
EMPI Power Rules!
sled
sled is offline
PostPosted: Tue Feb 03, 2015 9:12 am    Post subject: Reply with quote
I am most concerned about the horrible alignment of the flanges? does anyone have pictures of their recently installed mufflers?
Also, I do not want to modifiy my apron and I do not think any 500 dollar exhaust should require someone to do so.
drive your split.
VWsArent4Hippies
VWsArent4Hippies is offline
PostPosted: Tue Feb 03, 2015 10:26 am    Post subject: Reply with quote
I've probably installed 10 or so within the last year. From FI beetles, Type 4 bawindows, split buses, etc. and haven't had to modify anything. But then again, i'm a little biased Wink
For pressed bumper buses i've found that the single early style tip and abarth styles clear with no mods. The tail pipe on the "hidden tail pipe" exhausts will hit the bumper.
mpribanic
mpribanic is offline
PostPosted: Tue Feb 03, 2015 10:51 am    Post subject: Reply with quote
Planning on putting a 4 tip on my panel in the near future!
Call your Cunado's:
https://vimeo.com/67661950
sled
sled is offline
PostPosted: Tue Feb 03, 2015 11:55 am    Post subject: Reply with quote
Colby, curious if you are seeing the alignment issue on the top of the muffler where the primaries bolt on?
drive your split.
56reddy
56reddy is offline
PostPosted: Tue Feb 03, 2015 1:33 pm    Post subject: Reply with quote
I've installed one in the last year and it was spot on. If you know how to install a multi-piece muffler, which I'm 100% sure you do, it will be fine. Most that complained about poor alignment were first timers, and were tightening the nuts and bolts in the wrong order, and didn't follow the directions that are included.
New Vintage Specialist.
1974 ghia convertible
1981 Vanagon Westfalia
Making VW’s Fun Again.(MVFA)
VWsArent4Hippies
PostPosted: Tue Feb 03, 2015 3:17 pm    Post subject: Reply with quote
No, I haven't run into that. Here's a straight on shot of that same engine, you can see they line up with the muffler fine:
Now, all the systems i've installed have been on stock stroke engines. I haven't installed any on strokers with larger diameter header pipes, so I can't comment on how those line up..
jason
jason is offline
PostPosted: Thu Feb 05, 2015 4:15 pm    Post subject: Reply with quote
I installed one on a 59 and in all fairness it isn't marketed for early buses. The engine is stock 1600 and the alignment was terrible. Not my first exhaust either, barely started all the nuts and still wouldn't fit. You can clean the bolt holes up and get some more alignment out of it though. Flanges on top leaked also. Metal seemed thin and it flexed, bent under light torque. Rode against the apron and I had to cut a significant portion out of my bumper. It could all be fixed if they either used a smaller can or moved it down 1/8 of an inch. Spend $200 more and get an A1. This was about 5-6 months ago. Have sold the exhaust and gone back to stock. I was looking for more ground clearance and ended up turning the tip straight down and cutting it shorter. No more exhaust fumes 😴
JohnnyRingo
JohnnyRingo is offline
PostPosted: Tue Feb 10, 2015 11:35 am    Post subject: Reply with quote
horrible is exaggerating........ My gallery picture shows my VS heater version....they don't align with the port in muffler.....super mad about it.Owner wanted me to measure between exhaust ports, I wish he made a non adjustable version. Also its not equal merged header.......but Bus has been sold. But facing same delima.....I'm having a 1904 mini stroker built by Pat Downs at cb performance to go in my 60 kombi not sure what exhaust? I had A1 sidewinder on my 61 panel but it touched the apron.....don't want to blister the fresh paint.
GTV
GTV is offline
PostPosted: Tue Feb 10, 2015 2:03 pm    Post subject: Reply with quote
I believe the higher performance ones are, but not the "sport" system. Anyone confirm this?
EMPI Power Rules!
VWsArent4Hippies
PostPosted: Tue Feb 10, 2015 4:46 pm    Post subject: Reply with quote
The sport and super flows are not equal length. The super flows are the same design as the sports, just with higher flow.
They do offer a separate equal length set up though, with a couple different tailpipe configurations
JohnnyRingo
PostPosted: Wed Feb 11, 2015 6:05 am    Post subject: Reply with quote
nope......that's what I had was the super flow. I could tell a difference with the same motor running the A1 sidewinder. I had a 1915cc in both buses. But the panel was lighter.....anyway I like the fact that the VS is not in the way of 1-2 valve cover. If I go with A1 again I will order it with the v/band clamp.....it was a pain removing the three bolts every time to remove muffler. Just my two cents worth.
Page 1 of 5
