insyncro Banned
Posted: Sat Jan 17, 2015 7:42 am Post subject: |
luVWagn wrote: |
what's the fastest way (other than powder-coating, which almost always has some waiting queue), for me to prep and paint these? I'd love to get these started for installation this weekend (tomorrow). |
If you want the coating to hold up, don't rush it. |
luVWagn Samba Member
Joined: February 21, 2008 Posts: 1340 Location: Snoqualmie (WA)
Posted: Sat Jan 17, 2015 4:39 pm Post subject: |
insyncro wrote: |
luVWagn wrote: |
Went down the prep and powder path, you said it - no point rushing it.
Got the CLKs and Cooper Discoverer AT3s mounted up now, sorry for Mr. Blurry Cam:
Damn, need some center-caps! _________________ '91 Syncro 16 Reimo Hightop Conversion, eTDI |
4x4BNB Samba Member
Posted: Sat Jan 17, 2015 6:28 pm Post subject: |
Have you decided what you are going to do with the steel wheels? |
Posted: Thu Jan 29, 2015 11:24 pm Post subject: |
4x4BNB wrote: |
havent yet, will likely keep for now as future dedicated winters...
and in other news, get the van back tmrw! _________________ '91 Syncro 16 Reimo Hightop Conversion, eTDI |
Needforspace Samba Member
Joined: September 30, 2014 Posts: 36 Location: Norway
Posted: Fri Jan 30, 2015 4:52 am Post subject: |
I like this car a lot, my one was almost ready for use, but sadly my garage burned down a week a go.
It had a Westfalia solution inside and I mounted a Reimo highroof on top.
91Transporter16" Samba Member
Joined: February 07, 2011 Posts: 258 Location: Tualatin Oregon
dobryan Samba Member
Joined: March 24, 2006 Posts: 16508 Location: Brookeville, MD
Posted: Fri Jan 30, 2015 8:28 am Post subject: |
91Transporter16" wrote: |
What the heck!! Is this the van you are installing the VNT into? Man that sucks. I'm no expert but it looks like it can be brought back.
Tony |
Not mine, but definitely No Good In Norway!
Needforspace, my condolences! _________________ '91 Syncro 16 Reimo Hightop Conversion, eTDI |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Mon Feb 02, 2015 6:30 pm Post subject: |
So I daily drove the van today (to work). Interestingly, and this could partly be because of the tire changes, I'm finding some scenarios performance challenged - too many variables changed at once, so hard to know if this is engine, turbo/boost, or tire/gearing related.
Additionally, i'm using the EGT gauge now to ensure that I don't go over ~1200 (which I climb towards quite rapidly under acceleration on slight inclines), and I'm also seeing boost and oil (or coolant?) temp on the 3-in-1 gauge. Boost seems to top out around 12-15, and temp is at 198 or so. Dash cluster temp gauge is slightly below the LED as well.
One major concern is that I can see into the bell-housing (?), and I'm guessing there should be a plastic cap on there so no crap falls in off the road? It is making me queazy just thinking about it
The other major problem is that since the work (which meant engine out, as well as having my drive-shaft rebalanced and u-joints fixed to eliminate vibrations), I'm now popping out of 4th gear WAY more often (like, almost always). This gives me hope that it is not internal to the transmission, but more like fitment/adjustment somewhere that can be externally tweaked?
I see this thread here: http://www.thesamba.com/vw/forum/viewtopic.php?t=422264&start=0, and noticed that tschroeder0 had mentioned:
tschroeder0 wrote: |
Just a thought; I just had to replace my trans and after reassembly it was also jumping out of 4th it also did not engage easily.
The end result was that I had the mounting plate that holds the rear bushing (the one closest to the tranny was mounted on the wrong side of the flange.
This allowed it to shift into gear but with a moderate amount of vibration it wold jump out because it was not really fully engaged or just barely.
It's easy to see, as when it is in 4th there should be about an inch of space between the shoulder of the "L" shaped shift arm and the final shift bushing, if they are tight together then you've mounted it wrong (sorry I can't remember which side of the trans it should mont on right now). Todd. |
Also, Fairweather mentioned:
Fairweather wrote: |
The shift shaft could cause that problem also and is replaceable with the tranny in situ. Pretty easy, pull off reverse switch plate and undo shifter ball from the other side, slide old out and new in. Slide it back in gently trying not to damage the seal around the shifter ball end. Pay attention (picture) to the alignment when removing the old one. Your rebuilder or a friend could provide you with a known good shaft. |
Lots of other threads pointing to multiple topics. What's the best way to evaluate my shift-linkage, mounting-plate, etc.? I'm way out of my depth, and in desperate need... hoping to avoid my 2nd expensive repair foray, right after TDI AHU replacement. _________________ '91 Syncro 16 Reimo Hightop Conversion, eTDI |
Jon_slider Samba Member
Posted: Mon Feb 02, 2015 7:29 pm Post subject: |
luVWagn wrote: |
So I daily drove the van today (to work). Interestingly, and this could partly be because of the tire changes, I'm finding some scenarios performance challenged - too many variables changed at once, so hard to know if this is engine, turbo/boost, or tire/gearing related. |
it may be too little horsepower (how much do you have now?, might be able to increase it with a chip, 140hp would be good) and too big tire size related
since:
>Cooper Discoverer AT3 225/75R16, as per Jon_Slider's advice for my gearing.
I apologize and suggest you exchange them for 215x70x16, unless you increase horses (iirc stock ahu is 90 horses, which apparently is too little despite your syncro 16 ring and pinion.. what tire size did you have before?)
I hope your tranny gets sorted soon too _________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco |
BavarianWrench Samba Member
Joined: January 18, 2004 Posts: 1045 Location: Oceans Edge
Posted: Mon Feb 02, 2015 7:57 pm Post subject: |
If the hole you speak of is where you check your timing? The guy who installed your engine may still have it? If not no big deal. It is the same threaded plug you find on an early Rabbit bell housing. |
Posted: Mon Feb 02, 2015 8:11 pm Post subject: |
Jon_slider wrote: |
luVWagn wrote: |
since:
I hope your tranny gets sorted soon too |
I should've been at 110hp, with the previous AFN, except it was mated to the wrong (non-VNT) turbo, so doubt I was getting 110 at all. I did have smaller tires before, details are way up in the thread, let me check and get back.
EDIT: Previous tires were 195/75R16
I do plan to get to VNT soon, and will also check nozzles, so would be interesting if that alone would get hp increase up around 110 (at least), but not sure if chipping is required to get that far?
Exchanging the tires is a bit problematic now that they're on and rolling I can also swap back to the old steel rims+tires until things are dialed in more. _________________ '91 Syncro 16 Reimo Hightop Conversion, eTDI |
Posted: Mon Feb 02, 2015 8:13 pm Post subject: |
BavarianWrench wrote: |
Yes, that's the spot I believe, and i'll follow up with them tomorrow to get the plug back / installed. Not great that it got left off... but I guess just a simple mistake. _________________ '91 Syncro 16 Reimo Hightop Conversion, eTDI |
Posted: Sat Feb 07, 2015 8:55 am Post subject: |
Taking a break from the ongoing headaches of the machine itself, look what just arrived for me!
Well packaged and safe.
This shape looks vaguely familiar.
There's no option for cut-outs to host the stock switches, so I've got a Mk3 headlight switch (with fog indicators) coming, and will install a 2nd binnacle/cluster pod in my dash to host the relocated switches, stereo, etc. Kind of a bummer that the cut-outs can include room for optional gauges, but not the stock switches But I knew that going in.
The RPM gauge is a bit low, so hopefully my TDI and gearing doesn't end up with me up at 5000RPM very often? I didn't realize at time of order that the 160mph dash got me a higher rev-range on the tach, and dumbly ordered the 140mph dash (since I'll never be going that fast anyways). Argh.
Andy @ SyncroSport was great to deal with (after some initial delays), shipping was timely, packaging well done, etc. _________________ '91 Syncro 16 Reimo Hightop Conversion, eTDI |
Posted: Thu Feb 12, 2015 6:34 pm Post subject: |
Nice spring day in Snoqualmie, here I am with a new jacket trying to camouflage myself into the van
Don't know why i'm smiling like an idiot, as i'm actually experiencing Hightop Hell. Too bad there is already a thread on here about a Syncro 16 Moneypit, otherwise I'd have to re-title this thread _________________ '91 Syncro 16 Reimo Hightop Conversion, eTDI |
Posted: Thu Feb 12, 2015 11:04 pm Post subject: |
luVWagn wrote: |
Don't know why i'm smiling like an idiot, as i'm actually experiencing Hightop Hell. Too bad there is already a thread on here about a Syncro 16 Moneypit, otherwise I'd have to re-title this thread |
Its only money - and the van looks terrific! _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
lloydy Samba Member
Joined: September 15, 2010 Posts: 715 Location: cheam surrey
Posted: Thu Feb 12, 2015 11:52 pm Post subject: |
Yeah, you can't take money with you
12-15psi is about the norm for a afn, mine will tend to hold at 13.8 or so.
Once you get that engine sorted you'll be laughing, if you have the 6.17 final drive it feels like a rally car.
Also, good to see one of Andys dash pods in the states _________________ 16" syncro multivan pop top AHU TDI
“Give a man a fire and he's warm for a day, but set fire to him and he's warm for the rest of his life.”
Posted: Fri Feb 13, 2015 12:06 am Post subject: |
lloydy wrote: |
12-1psi is about the norm for a afn, mine will tend to hold at 13.8 or so.
Also, good to see one of Andys dash pods in the states |
Engine is mostly sorted (dropped in an AHU, bit hard to start, smokes white for first 5-mins, especially down hill, still having some n75 and glowplug issues). Next problem is that after all this, now it won't stay in 4th . Admittedly, it had done that twice in 1000mi, but now does it religiously - which is a bit suspicious...
I could do without a $4k tranny overhaul at AA, especially since Aidan Talbot already did this box, but hey - would give me a chance to put in a decoupler and have a triple knob :p
Lloydy, what turbo and nozzles and N75 you running on your AFN, and do you have an after run pump? _________________ '91 Syncro 16 Reimo Hightop Conversion, eTDI |
