PLF-Blue Samba Member
Joined: October 07, 2014 Posts: 327 Location: Nevada, tahoe, and elsewhere
Posted: Sun Feb 08, 2015 7:59 pm Post subject: Wanted - pics of your outdoor camping tables (mounted?) |
Howdy all - we are about to hit the road in the bus and i am thinking of adding a table that can be used during camping set up. Just a little one for cutting food, table top ipod, etc.
we dont want to carry a big table with us.
Thinking more along the line of a swing out model maybe attached to the passenger bulkhead or a little shelf model similar to the outside removable, rail mounted tables on our past toy hauler trailers.
Anybody fab up a nice set up?
I can alway appreciate others ideas and fabs so, please, do share...
Thanks... Leaving in 9 days... _________________ ..."I live in my own little world. but it's ok, they know me here." -L. Myracle |
cliveawn Samba Member
Joined: December 07, 2010 Posts: 481 Location: Southern Sweden
Posted: Sun Feb 08, 2015 8:19 pm Post subject: |
Have you got the stock westy table? if so then you can use one of those umbrella stakes that you knock into the ground.I found one that fits my westy table perfectly,just make sure you knock the umbrella stake or tube device deep into the ground.
Mine works ok.
Another option is the bracket that fits into the jack hole on the side of the bus.
Also very good.
I also have the Outwell table that folds in two with screw on legs and a net under,its large but fits in the back over the egine compartment no problem. _________________ ---------------------------------------------------------
Green 78 Westfalia Helsinki,
2056 with 41 x 34 valves,ported heads
Fully balanced
8,5:1CR
JPM Custom made cam
JPM 7075 dual taper pushrods
IDF 40's with 28mm venturi's
Python CSP 42mm exhaust.
115 HP
Daily driver 2017 Volvo V60 D5 hybrid
Rica stage 2 tune 345hp.
''Funny thing about common sense is that its not very common''
Seismic gun mechanic |
Posted: Sun Feb 08, 2015 8:36 pm Post subject: |
The country homes table is a hinged table. I could add screw out legs but was hoping to keep it even more minimal for travel. Going to slide the table under our bed from the rear hatch but want to use it out the slider section when the awning is out or be able to briefly use for shorter stops without a lot of set up.
Thinking possible a tube support mounted to the passenger bulkhead that would swing out the slider and rotate up to a vertical position. Thought i saw a pic of one someone had similar to that on here but cant seem to find it... _________________ ..."I live in my own little world. but it's ok, they know me here." -L. Myracle |
Sprink1es Samba Member
Posted: Mon Feb 09, 2015 10:50 am Post subject: |
I just use a little 2x4' folding table I got on Amazon for $50 http://www.amazon.com/Wenzel-97927-Aluminum-Camp-T...camp+table
It's the right height, weather proof, best bang for the buck I found. Not the sturdiest but I didn't need it for much. I throw it in the back under my gear, or I think it almost fits in my tall narrow cabinet to the right of my sink. I bring it every time I camp! Below:
Posted: Mon Feb 09, 2015 11:41 am Post subject: |
Yeah, we were thinking of those too. It'd be easy ad the wife would probably like that... But of course, i get in fabrication mode and was hoping to think up something like this found in the gallery -
But a little larger and swivels to a horizontal position for storing, May swivel it out the slider and be able to use inside as the weather dictates.
Will do some tinkering the next few days. _________________ ..."I live in my own little world. but it's ok, they know me here." -L. Myracle |
EZ Gruv King of Plaid
Joined: December 10, 2002 Posts: 8544 Location: Las Vegas
Posted: Mon Feb 09, 2015 11:53 am Post subject: |
Not to put in a shameless plug, but here's a shameless plug:
http://www.thesamba.com/vw/classifieds/detail.php?id=576723
Check out all the photos there. Hundreds of happy customers.
_________________ Eric
1977 Deluxe Westfalia - 2.0L FI Type IV, Completely Original
Photographer for HotVWs, VolksWorld, AirMighty, VW Camper & Commercial, Hayburner, and more.
My Photography Page. |
Posted: Mon Feb 09, 2015 12:01 pm Post subject: |
Ah, shame has always been overrated....
Thats some nice work there. We saw some of those on other *obviously* happy customers pictures. May be a good option for moving it outdoors.... We don't have a westy table but am planning on using a tube support that i have down in the basement.
Can you tell me the inside diameter of the round tube you use in those? _________________ ..."I live in my own little world. but it's ok, they know me here." -L. Myracle |
Posted: Mon Feb 09, 2015 12:04 pm Post subject: |
PLF-Blue wrote: |
Can you tell me the inside diameter of the round tube you use in those? |
Our bracket has an 'expansion' slot (or slit) built in, so non-stock tubes could be used; however it is designed to be used with the stock Westy table leg.
I can measure mine later today, but someone here may have the answer before I have a chance to get it. _________________ Eric
my59 Samba Member
Joined: August 13, 2003 Posts: 3791 Location: connecting the dots
Posted: Mon Feb 09, 2015 4:55 pm Post subject: |
I put an extra set of brackets on the passenger seat bulkhead and the table pivots out the door or sits behind the passenger seat. Out the door it is more like a bar height table which is good for standing around. The bus does not have swivel passenger seat so it does not interfere there. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
Posted: Mon Feb 09, 2015 5:36 pm Post subject: |
my59 wrote: |
I put an extra set of brackets on the passenger seat bulkhead and the table pivots out the door or sits behind the passenger seat. Out the door it is more like a bar height table which is good for standing around. The bus does not have swivel passenger seat so it does not interfere there. |
That sounds like what i am thinking of. Started a little fab today... Pics later _________________ ..."I live in my own little world. but it's ok, they know me here." -L. Myracle |
PITApan Samba Member
Joined: November 09, 2014 Posts: 1058 Location: Northern Colorado
Posted: Tue Feb 10, 2015 12:37 am Post subject: |
PLF-Blue wrote: |
my59 wrote: |
That sounds like what i am thinking of. Started a little fab today... Pics later |
Methinks it odd to use a 3500 lb vehicle as a table leg (or two). Thye only space you save is that table leg (or two). If it's raining you either rig a pretty fancy tarp or tent to keep from getting dripped on. In the snow you stand right there next to the drippy van in the snow. The table is small--even the big ones in the pics above look small.
I bought a plastic topped table, steel frame and folding legs, 2' x 4'. Plenty big for the coleman on one end, food prep in the middle and people eating at the other. Moves away from the bus to dry and sheltered areas. Clusters with other peoples tables at the party or gathering. Goes over by the bonfire for the franks, 'mallowsm, forks, jugs of wine, glasses and cups, etc. It's the camp table, not a cute bus accessory. $35 or something. Travels on the roof although it will certainly fit inside. Could use some nice slots routed into the top for tie down straps.
I have seen some pretty fancy rolling ones. Costly. |
Sage79 Samba Member
Joined: September 13, 2008 Posts: 433 Location: Holland MI
Posted: Tue Feb 10, 2015 5:09 am Post subject: |
We love EZGruv's adaptor and use the table outside the bus in the rear jack point every time we camp. It functions as the kitchen with the coffee pot and toaster on it and the food under it. It stays dry under the canopy by Fancher's upholstery, another Samba vendor. _________________ Dirk
'79 Westy 2.0FI
'73 Sportsmobile 1.7dual Solex 003Auto - now my daughter's
'77 delux 2.0FI 090Auto - now my son's |
Posted: Tue Feb 10, 2015 7:32 pm Post subject: |
Got it figured out.
We ended up with a small, portable table we can set up as needed at campsites.
BUT.... not one to leave well enough alone, i had a thought and it wouldnt leave my head so i had to run with it.
I wanted a little table area, sort of a bar-like setting that could hold a beer or two on our teavels and our music, etc. just a little something to utilize unused space....
Started with this...
All materials downstairs in the shop.
Did a quick little attachment and a few modifications to end up with this....
The table attachment locks in any position with the screw friction. Table comes on and off with finger tightened screws on top.
Table off and an edge and pattern routed, just for the 'ell of it!
It aint perfect but it is darn fun... Will throw a coat of shellac on it tomorrow and plan to share a few beers over it in the future. Overall a fun and slightly practical space.
Cheers! _________________ ..."I live in my own little world. but it's ok, they know me here." -L. Myracle |
Marya Samba Member
Joined: August 31, 2004 Posts: 353 Location: Portland, OR
Posted: Tue Feb 10, 2015 8:59 pm Post subject: |
You've been busy! Looks great. It's funny cause mine - I guess most of ours - has the table that folds out from the ice box cabinet but without a cabinet, you had to get a bit more creative. And it's nice that you have that extra space in there, not having the ice box. I like the artistic touches you added as well. _________________ 1970, Riviera, 1600 cc type I [single port] |
Posted: Wed Feb 11, 2015 10:11 am Post subject: |
Marya wrote: |
You've been busy! Looks great. It's funny cause mine - I guess most of ours - has the table that folds out from the ice box cabinet but without a cabinet, you had to get a bit more creative. And it's nice that you have that extra space in there, not having the ice box. I like the artistic touches you added as well. |
The extra space there is pretty nice. Our ice box is tucked back against the drivers side wall. It is actually a pretty good design and floorplan. It needed a little table right there. And yeah, it is always a good omen/good luck to travel with a minature version of the vehicle you are in. Something i learned with an old mustang we had... _________________ ..."I live in my own little world. but it's ok, they know me here." -L. Myracle |
otiswesty Samba Member
Joined: November 21, 2006 Posts: 1730 Location: Portland
Posted: Thu Feb 12, 2015 1:41 am Post subject: |
I built a jump seat and added a table bracket for the same reason.
_________________ 1978 Sage Green P22 Westfalia
1989 T3 Syncro Single cab
Just a regular guy |
my59 Samba Member
Posted: Thu Feb 12, 2015 3:28 am Post subject: |
PITApan wrote: |
PLF-Blue wrote: |
my59 wrote: |
Methinks it odd to use a 3500 lb vehicle as a table leg (or two). Thye only space you save is that table leg (or two). If it's raining you either rig a pretty fancy tarp or tent to keep from getting dripped on. In the snow you stand right there next to the drippy van in the snow. The table is small--even the big ones in the pics above look small. |
We go to a lot of parades and the bus becomes a hang out spot while the fife and drum corps assembles because of the cooler inside. Putting the table and leg I already have outside makes cooler access easier and keeps muddy boots outside. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Posted: Thu Feb 12, 2015 9:01 am Post subject: |
otiswesty wrote: |
Great minds.... _________________ ..."I live in my own little world. but it's ok, they know me here." -L. Myracle |
ROCKOROD71 Samba Member
Joined: January 18, 2012 Posts: 2770 Location: Boston, MA
Posted: Thu Feb 12, 2015 9:45 am Post subject: |
I'll be getting one of these after I'm done paying for paint/bodywork!
http://www.ebay.com/itm/Folding-Picnic-Table-Bench...234a95d515
I've seen them in action before, at a flea market. They are sturdy and fold up into a thin suitcase. Won't take up much room in the van at all, and lightweight aluminum. Some older fancier versions you can find out there use wood, and look period correct if that's your thing. _________________ 1971 STD BEETLE- DD-1st car, 1st love. keepin' it stock! 1600DP, Solex 34-3 Mexi Bosch SVDA Dist NOW w/POINTS
1977 WESTY "KrustyKamper" 2L FI
79SuperVert wrote: |
30 years from now, the next guy may not want your girlfriend, but he may want your classic car, depending on how nice you were to it. |
asiab3 wrote: |
Careful guys, a petulant child can grow up to be president these days. |
**winter drivers: no survivors!**rust warrior**#keepbodyshopsbusy** |
