Westy Steve Samba Member
Posted: Tue Feb 17, 2015 1:43 pm Post subject: Someone welded up a 2-tailpipe muffler to make my 1-tailpipe |
Hey guys,
I was nosing around under my car last night and noticed that my muffler was original designed for two tailpipes. But someone welded one of the holes shut so that it looks almost correct for a '55 (one tailpipe).
I'm not sure what's inside a muffler. Are they just an empty chamber. Will this hurt anything? Maybe make too much backpressure, or more backpressure on one side than the other?
TIA,
Steve _________________ Have nice 914, want nice Bug |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Tue Feb 17, 2015 2:23 pm Post subject: |
http://www.vwdcqinc.org.au/vwdcqimages/insideamuffler/insideamuffler.html
probably won't hurt anything (not German shown but similar) _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Posted: Tue Feb 17, 2015 3:05 pm Post subject: |
I can't thank you enough for that. That's exactly what I was looking for. I agree with you. I have an exhaust leak somewhere that I'm beginning to think may be bad gaskets and I was wondering if somehow they got blown out due to excessive backpressure. I guess that's not the case.
Thanks again,
Kjell Roar Samba Member
Joined: December 08, 2008 Posts: 1326 Location: Norway
Posted: Sat Feb 21, 2015 1:37 pm Post subject: |
When you block the left exhaust outlet, you will also block the preheat function that VW made. So icing will be a bigger problem. One tailpipe exhaust also need a endpipe with bigger inner dia than the one used with 2 tailpipes. _________________ I got a historic car, every scratch got a history...
My car, Aug. 4th, 1955 / an early 56: http://www.thesamba.com/vw/forum/album_page.php?pic_id=610438 |
