MV8 Samba Member
Posted: Sun Mar 22, 2015 11:36 am Post subject: |
I'd disconnect the long pedal link, jack up one side, spin the wheel by hand and see if you can stop it by pulling on the bottom or pushing on the top of your pivot link that connects directly to the master cylinder pushrod. If not, then you have other issues besides the linkage which seemed to work before.
It worked before with worn out parts. It should work again with new versions of the same parts.
Do you have any idea what "popped" when you lost the brakes?
A pic or two in your gallery would help. |
VSarge Samba Member
Joined: March 31, 2008 Posts: 367 Location: St Louis, MO
Posted: Sun Mar 22, 2015 11:44 am Post subject: |
Hmmm, sorry thought I posted it before.
Sarge[/img] _________________ _________________
VW trike -- FrankenMutt
1971 1600
Swing Arm frame
Stock 4 spd tranny - no reverse gate (crap!)
1966/67 rear brakes wheel cylinders from front of 1966 Bug
1934 Chevy headlight
Custom leading link front end
Ford Ranger rims
P225/60R15 rear tires
GoldWIng front tire
Body is fiberglass nose from semi
One ugly exhaust, heavily rusted, set up for heat??? On a trike?? |
MV8 Samba Member
Posted: Sun Mar 22, 2015 12:05 pm Post subject: |
I meant your pedal linkage.
Also, a bigger wheel cylinder and/or smaller master cylinder provides more leverage but also requires more pedal travel for a given displacement. |
VSarge Samba Member
Posted: Sun Mar 22, 2015 12:23 pm Post subject: |
Alrighty, right side jacked up and spun.
Slows but doesn't stop right away mostly. Every so often it stops right away.
Left up...
Slows and stops slowly. Never locks.
Disconnected the linkage completely and tried by hand. Unable to depress master cylinder any further than lever does.
Will take a pic of linkage in a bit.
Sarge _________________ _________________
1971 1600
Swing Arm frame
Ford Ranger rims
GoldWIng front tire
MV8 Samba Member
Posted: Sun Mar 22, 2015 12:45 pm Post subject: |
Sounds like there are still bubbles in the system as well as what you said about the "feel" before.
I think you said something about gravity bleeding. A good bleed is critical. You might try a one-man bleeder kit or go buy some clear vinyl hose from home depot that will just fit over the bleeder and a jar.
Fill the jar to where the hose end is covered.
Crack the bleeder loose.
Pump the pedal until fluid with little or no bubbles comes out of the bleeder, close it, then do the side closest to the master.
You may want to do that a few times depending on how the lines are routed.
I'd like to see the linkage, but I think your issue is bleeding. |
VSarge Samba Member
Posted: Sun Mar 22, 2015 2:02 pm Post subject: |
No air in the system when last I looked. It was bled via vacuum and also by the old two man system, one pumping the brake while one works the bleeder. Nice clean fresh fluid, DOT 3 synthetic.
BUT while taking pics of the set up I discovered that it appears that the "new" rebuilt master is seeping from a connection to the remote reservoir.
Brake pedal set up:
1971 1600
Swing Arm frame
Ford Ranger rims
GoldWIng front tire
VSarge Samba Member
Linkage:
1971 1600
Swing Arm frame
Ford Ranger rims
GoldWIng front tire
VSarge Samba Member
Posted: Sun Mar 22, 2015 2:03 pm Post subject: |
Master:
1971 1600
Swing Arm frame
Ford Ranger rims
GoldWIng front tire
MV8 Samba Member
Posted: Sun Mar 22, 2015 2:58 pm Post subject: |
You are only moving fluid to two wheel cylinders instead of 4, so there should be half the pedal travel if the linkage is right and the system is bled. |
VSarge Samba Member
Posted: Sun Mar 22, 2015 3:18 pm Post subject: |
Which about what I get. But the effort is equal thru-out the travel, none of the steady increase normally felt. Of course the actual travel is limit by the stroke of the master cylinder.
Speaking of which I have searched but only found bore size on this master, no stroke length. So I have no clue if it is fully involved.
I suspect it would be much easier to move the master right in front of the pedal and forgo all the dang linkage. Of course that would mean replumbing and rebleeding the dang thing. Took 2 quarts this last time.
1971 1600
Swing Arm frame
Ford Ranger rims
GoldWIng front tire
MV8 Samba Member
Posted: Sun Mar 22, 2015 3:30 pm Post subject: |
I have one on the bench that I just checked. Travel is about an inch.
I'd take the master apart and check the condition of the seals. They split where the rubber gets thicker, so you have to flex them a little to see the split.
When you bled the system, was there much force to the fluid coming out of the bleeder or was it real slow? |
VSarge Samba Member
Posted: Sun Mar 22, 2015 3:34 pm Post subject: |
Travel is right then, an inch or a smidge more. I do have free play also so it is flowing back as it should.
The dang master was bought a week ago. I think before I bother rebuilding it, I would return it.
1971 1600
Swing Arm frame
Ford Ranger rims
GoldWIng front tire
MV8 Samba Member
Posted: Sun Mar 22, 2015 4:33 pm Post subject: |
Travel of the primary piston at least. Don't know about the secondary.
If you bench bled the plugged port also, then both circuits should work.
Are you plumbed into the port nearest the pushrod or the other? Can't tell from the picture. |
VSarge Samba Member
Posted: Mon Mar 23, 2015 9:33 am Post subject: |
Plumbed into circuit furthest from piston. Only that much line as it came to me. One line (right rear is on the side and the other (left) is on top.
Watched the action of the shoes this morning. One time the front shoe will move, another the rear and every so often both would move. Not sounding right to me.
During bleeding (still no air by the way) the fluid is fairly slow moving. But for every one inch of piston travel I am getting 2-3 inches of fluid movement. Just not real fast.
1971 1600
Swing Arm frame
Ford Ranger rims
GoldWIng front tire
VSarge Samba Member
Posted: Mon Mar 23, 2015 1:47 pm Post subject: |
All right, I am going to change the system out. Plans are to return the current master. Pick up a 5/8" bore with 1 5/16" travel mounted directly to a floor mounted pedal.
Would you run a single line back and then split it at the rear or two line back separately? I will also add flex lines at the wheels since it currently is hard line all the way.
The pedal mounted master will eliminate any problems with linkage crap as well as making it easier to access. Altho I will most likely make a cover for it some how as well. It will still have a remote mounted reservoir.
1971 1600
Swing Arm frame
Ford Ranger rims
GoldWIng front tire
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6767 Location: Northern California
Posted: Tue Mar 24, 2015 8:27 am Post subject: |
VSarge wrote: |
A single line with a T block.
Definitely need flex hoses.
VSarge Samba Member
Posted: Tue Mar 24, 2015 8:29 am Post subject: |
Cool, thanks. I was leaning that way already.
1971 1600
Swing Arm frame
Ford Ranger rims
GoldWIng front tire
VSarge Samba Member
Posted: Tue Mar 24, 2015 8:45 am Post subject: |
I've been looking at that one as well as one like it but with a remote reservoir. If I go with this one I will also need a residual valve as the master will be below the wheel cylinders.
1971 1600
Swing Arm frame
Ford Ranger rims
GoldWIng front tire
Posted: Tue Mar 24, 2015 2:37 pm Post subject: |
I think a 2 psi residual pressure valve in line would be a cleaner installation than a remote reservoir. At least bleeding should be easy. |
