LP tank shutoff valve
tlbranth
tlbranth is offline
PostPosted: Mon Mar 23, 2015 1:11 pm    Post subject: LP tank shutoff valve Reply with quote
My tank valve does not completely shut off the gas. If I shut it off all the way, I still get a small amount through the stove if I turn on a burner. I called GoWesty and was told I had to buy a whole new tank. That doesn't sound reasonable. Can I replace the shutoff alone?
Terry
1991 Westfailure. 2004 Forester 2.5 engine. 4speed Standard transmission.
dobryan Premium Member
dobryan is offline
PostPosted: Mon Mar 23, 2015 1:25 pm    Post subject: Reply with quote
http://vanagonwestfaliaaccessories.com/
You can find one here, as well as other vendors. Very Happy
Dave O
The Western Syncro build
tlbranth
tlbranth is offline
PostPosted: Mon Mar 23, 2015 1:46 pm    Post subject: Reply with quote
Thanks Dave. That's more like it.
That fella never saw a word ending in "s" that didn't cry out for an apostrophe.
Terry
veloandy
veloandy is offline
PostPosted: Mon Mar 23, 2015 4:29 pm    Post subject: Reply with quote
On my valve I have to crank it HARD clockwise to shut off the propane all the way (and turn it HARD against the stop CCW to prevent propane from leaking out around the valve stem).
Totally freaked me out when I first got it, but it has been totally functional for the last 3+ years like that.
tlbranth
tlbranth is offline
PostPosted: Mon Mar 23, 2015 6:51 pm    Post subject: Reply with quote
Hmm. Usually gas valves don't like to be turned off with force 'cos it buggars up the soft metal seat and makes it that much harder to shut off next time. This one, however, I figured had been torqued pretty hard and I gave it a bit more but it still lets gas through. No leak though that I can tell. Since all the gas has to be out of the tank to replace the valve anyway, I thought I'd run it dry, remove the valve and see how it's constructed. Maybe there's a needle could be re-seated.
Terry
