jbow1076 Samba Member
Posted: Tue Mar 24, 2015 9:51 am Post subject: What alternator was used in the DDB conversion kits? |
I am trying to find out what alternator was used by the DDB in their kits. I am having an issue with my battery charging and I need to get the alternator tested out, but I have no idea what was used. I do have a couple of pictures of the alternator.
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22410 Location: Kimball, Mi
Posted: Wed Mar 25, 2015 9:11 am Post subject: |
Going off the pictures, it's a Denso unit, with 1 of the mounting arms cut off.
Look it over, and see IF you can find a part number or model number on it.
More than likely, the brushes have worn down, or the internal voltage regulator has died. Both can be had at NAPA. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22448 Location: Escondido CA
Posted: Wed Mar 25, 2015 4:04 pm Post subject: |
I want to say he sourced it from a Honda fork lift. Im pretty sure it was a fork lift but maybe not a Hondah if that helps you out any. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17968 Location: Eugene, OR
Posted: Wed Mar 25, 2015 5:09 pm Post subject: |
If you find the part number & Google it, you can learn more about it's applications etc. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
vwfye Samba Member
Posted: Wed Mar 25, 2015 5:25 pm Post subject: |
My nipondenso apt had no part # on it. Mine is a 40 amp from a toyo fork lift. _________________ 64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3" |
grantndub Samba Member
Joined: November 18, 2002 Posts: 76 Location: Oroville, CA
Posted: Wed Mar 25, 2015 6:15 pm Post subject: |
vwfye wrote: |
My nipondenso apt had no part # on it. Mine is a 40 amp from a toyo fork lift. |
I had one and it didn't have any part #'s but I do think they were toyo fork lift also. _________________ Zek Dee Wagen, a 69 square |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4919 Location: Southern AB
Posted: Wed Mar 25, 2015 6:55 pm Post subject: |
If you take it to a motor rewind shop they can put it on the machine and spin it up to see what it makes for voltage, amps, etc in about 5 minutes.
they don't care what model it is.
That looks very similar to the 40 amp that I have from a 3 cylinder Geo/suzuki _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
LouPeck Samba Member
Posted: Thu Mar 26, 2015 9:07 am Post subject: |
I have the DDB kit on my square, and had it serviced before. An alternator shop that specializes in Japanese models can both repair and also tell you what model or vehicle its from. As I recall, the alternator shop I took it to in San Diego had several of the exact same alternators on their shelves. _________________ 1970 Baywindow weekender
1967 sunroof Squareback |
Posted: Fri Mar 27, 2015 9:16 am Post subject: |
There is no part number on the alternator. I will take it to an alternator shop and see what they can do for me. Thanks for the help! |
