What alternator was used in the DDB conversion kits?
jbow1076
jbow1076 is offline
PostPosted: Tue Mar 24, 2015 9:51 am    Post subject: What alternator was used in the DDB conversion kits? Reply with quote
I am trying to find out what alternator was used by the DDB in their kits. I am having an issue with my battery charging and I need to get the alternator tested out, but I have no idea what was used. I do have a couple of pictures of the alternator.
Bobnotch
Bobnotch is offline
PostPosted: Wed Mar 25, 2015 9:11 am    Post subject: Reply with quote
Going off the pictures, it's a Denso unit, with 1 of the mounting arms cut off.
Look it over, and see IF you can find a part number or model number on it.
More than likely, the brushes have worn down, or the internal voltage regulator has died. Both can be had at NAPA.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
notchboy
notchboy is offline
PostPosted: Wed Mar 25, 2015 4:04 pm    Post subject: Reply with quote
I want to say he sourced it from a Honda fork lift. Im pretty sure it was a fork lift but maybe not a Hondah if that helps you out any.
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
Mike Fisher
Mike Fisher is offline
PostPosted: Wed Mar 25, 2015 5:09 pm    Post subject: Reply with quote
If you find the part number & Google it, you can learn more about it's applications etc.
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
vwfye
vwfye is offline
PostPosted: Wed Mar 25, 2015 5:25 pm    Post subject: Reply with quote
My nipondenso apt had no part # on it. Mine is a 40 amp from a toyo fork lift.
64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3"
grantndub
grantndub is offline
PostPosted: Wed Mar 25, 2015 6:15 pm    Post subject: Reply with quote
I had one and it didn't have any part #'s but I do think they were toyo fork lift also.
Zek Dee Wagen, a 69 square
W1K1
W1K1 is offline
PostPosted: Wed Mar 25, 2015 6:55 pm    Post subject: Reply with quote
If you take it to a motor rewind shop they can put it on the machine and spin it up to see what it makes for voltage, amps, etc in about 5 minutes.
they don't care what model it is.
That looks very similar to the 40 amp that I have from a 3 cylinder Geo/suzuki
http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap
LouPeck
LouPeck is offline
PostPosted: Thu Mar 26, 2015 9:07 am    Post subject: Reply with quote
I have the DDB kit on my square, and had it serviced before. An alternator shop that specializes in Japanese models can both repair and also tell you what model or vehicle its from. As I recall, the alternator shop I took it to in San Diego had several of the exact same alternators on their shelves.
1970 Baywindow weekender
1967 sunroof Squareback
jbow1076
jbow1076 is offline
PostPosted: Fri Mar 27, 2015 9:16 am    Post subject: Reply with quote
There is no part number on the alternator. I will take it to an alternator shop and see what they can do for me. Thanks for the help!
