pianobrooks Samba Member
Joined: October 02, 2009 Posts: 5 Location: Seattle, WA
Posted: Tue Dec 08, 2009 9:34 am Post subject: Bostig V1 trailer hitch question |
I've recently installed a used Bostig V1 in my 84 Westy, and would like to add a hitch that is capable of holding a cargo box (not an actual trailer). Currently my westy has a tow bar but the ball is a permanent component; there is no square receiver that could be used to attach a cargo box.
My question is, does anyone know whether I could mount a GoWesty hitch in place of my current tow bar? Would there by a mounting issue with the bostig? I know the GW hitch is designed to sit snugly under the bumper, so I wouldn't be surprised if there was interference. I asked GW and they weren't sure.
And on another note, for Bostig V1 owners: is there a separate online forum where you all hang out, or is this it?
Thanks ~
- Brooks |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17154 Location: Retired South Florida
Posted: Tue Dec 08, 2009 10:10 am Post subject: |
The Go Westy hitch has a brace to triangulate it off the toe eyes and the stock engine carrier. I had looked at buying one for my Vanagon. I ended up fabricating my own to work with the TDI. I notice the Bostig puts the muffler on the side similar to mine. Perhaps you could do something similar.
_________________ ☮️ |
jimf909 Samba Member
Posted: Sun Mar 29, 2015 4:13 am Post subject: |
Hi All -
I have the GoWesty 2" receiver hitch on my van and will be installing a Bostig this Spring. Has anyone modified the GW receiver to fit with a Bostig? Alternatively, what receiver hitches are folks using with their Bostig vans?
My intended use is for a two-bike hitch mounted rack.
Thanks.
Jim _________________ - Jim
Abscate wrote: |
j_dirge Samba Member
Joined: August 08, 2007 Posts: 4641 Location: Twain Harte, CA
Posted: Sun Mar 29, 2015 7:43 am Post subject: |
jimf909 wrote: |
Hi All -
Thanks.
Jim |
Your GW towloop variety would need to me modified. The "stiffener bar" redesigned to clear exhaust.
The current crop of true hitch/receivers should all work with your engine transplant. None are "cheap". Each is of as good or better quality than the big name fabricators like "Reese" etc..
Have a look in the FAQs on "hitch" and "towing".. There are literally dozens of threads on hitches and towing and bike racks. I have one in there somewhere on installing the Burley version (lots of pics)
Better options than the GW hitch (but pricer):
Burley builds a hidden hitch.. (works with the original bumper)
RMW builds a hidden hitch (works with the original bumper) and they also build an integrated bumper w/ hitch.
GWesty builds an integrated bumper hitch.
Each of these products installs in the subframe channels and avoid any interference with the engine/exhaust area. They are pretty bombproof. _________________ -89 GL Westy, SVX.. finally.
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
danfromsyr wrote: |
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
rockfish Samba Member
Joined: February 13, 2007 Posts: 740 Location: Palo Alto, Calif.
Posted: Sun Mar 29, 2015 10:50 am Post subject: |
Along j_dirge's train of thought:
Perhaps a larger investment than what you have in mind, but the GW steel plate bumper has the hitch sleeve integrated into the bumper...and there is no stiffener bar that would interfere with Bostig engine. Instead the two mounting brackets run farther back into the chassis. Check out the GW installation video as well.
Only downside is that they're out of stock at the moment. _________________ 89 Westy
GW 2.5 5-speed trans
"It's what you learn after you know it all that counts."
- John Wooden |
Posted: Mon Mar 30, 2015 1:29 pm Post subject: |
Thanks, guys. I was hoping to see if there were any cut n weld modifications to a GoWesty hitch for the Bostig versus spending $ on a new hitch and selling sell the GW hitch. Maybe I'll just go with the Burley which is a far better solution if this van every actually tows anything. _________________ - Jim
Abscate wrote: |
