Shaking/chattering gear stick
-Zodiac-
-Zodiac- is offline
PostPosted: Tue Mar 31, 2015 6:48 am    Post subject: Shaking/chattering gear stick Reply with quote
I've been having this problem with the 73, whenever I'm in third or fourth gear the gear stick shakes quite a bit, enough to make it chatter. Drives me crazy, and I can put my hand on it to make it stop, but is there a simple solution that will solve this problem?
1973 karmann ghia - current, not the last VW.
1947 Chevy stylemaster - gone, but not forgotten.
1995 Ford F-150 - gone, hatred for it lives.
CiderGuy
CiderGuy is offline
PostPosted: Tue Mar 31, 2015 6:58 am    Post subject: Reply with quote
When you did your carpet, did you move the shift plate that is under the boot ?
Cars Currently Owned:
1970 Karmann Ghia Coupe
1973 Karmann Ghia Coupe - Project car for sale
1970 Karmann Ghia Convertible (Body off restoration)
Timing is everything
-Zodiac-
-Zodiac- is offline
PostPosted: Tue Mar 31, 2015 7:04 am    Post subject: Reply with quote
Nah, just moved it alittle so I could find first easier. Also I noticed the problem before that, but it seemed intermittent.
ccihon
ccihon is offline
PostPosted: Tue Mar 31, 2015 7:55 am    Post subject: Reply with quote
Verify your shift rod bushing and clip in the tunnel, plus the shift coupler at rear are all in position and good shape. The coil spring that is compressed with the shifter installation also need to be in place. Further, it helps to have heavy grease applied to the shift ball and cup, and of course, the shifter bolts through the plate fastened tightly. I recall this was actually an issue with some of these cars as new from the factory. It won't rattle at rest if it is supported and can't move around. Also, the smoother the engine is running and the better the engine and transmission mounts isolate the vibration, the less rattle you have.
KGCoupe
KGCoupe is offline
PostPosted: Tue Mar 31, 2015 8:00 am    Post subject: Reply with quote
Along that same train of thought, is it also possible that having a poorly balanced wheel might transmit extra vibrations to the shifter and cause it to rattle?
-Zodiac-
-Zodiac- is offline
PostPosted: Tue Mar 31, 2015 9:02 am    Post subject: Reply with quote
I shall verify those items this week, I would like to think my engine runs pretty smooth, the mounts looked good. Maybe a wheel? If I recall one of them in the rear needs the camber adjusted. It occurs at higher speeds, on smooth roads, the lever its self just moves left to right pretty rapidly - I don't notice any major vibrations. But will pay more attention on the next drive
ccihon
ccihon is offline
PostPosted: Tue Mar 31, 2015 10:14 am    Post subject: Reply with quote
I once pulled a shifter to find the tunnel stuffed with bubble wrap - an effort, I think, to quiet the rattle!
60ragtop Premium Member
Bonneville Belt Bitch
60ragtop is offline
PostPosted: Tue Mar 31, 2015 10:35 am    Post subject: Reply with quote
check the bushing the screw goes thru, they wear where they go thru the shift rod and will rattle
Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
[quote="Sharp64"]But thatís crazy talk. He must be made to comply!!![/quote]
[quote="TDCTDI"]Jump on it some more & then LITFA.[/quote]
[quote="[email protected]"]aftermarket shit that always needs a tweek eats time[/quote]
[quote="Eaallred"]People are over analyzing.......(insert your problem here)[/quote]
-Zodiac-
-Zodiac- is offline
PostPosted: Wed Apr 01, 2015 1:59 pm    Post subject: Reply with quote
Here's mine, I don't exactly know what it looks like when worn - so maybe someone will be able to tell right off.
c21darrel
c21darrel is offline
PostPosted: Wed Apr 01, 2015 2:05 pm    Post subject: Reply with quote
your "looking" for play in it. This is what transfers the shift from the shifter, down the shaft, thru coupling to the trans. No play=Good.
GhiaBuild
-Zodiac-
-Zodiac- is offline
PostPosted: Wed Apr 01, 2015 2:41 pm    Post subject: Reply with quote
Play in the screw or play in general? Because it has a good amount of play in each gear
c21darrel
PostPosted: Wed Apr 01, 2015 4:03 pm    Post subject: Reply with quote
as you move the shifter it transfers movement to the shaft, travels the shaft to coupler which makes the connection to the trans/hockeystick. What you want is for the hockey stick to move as you move the shifter (all as one). If the coupler is sloppy, shifts will be sloppy.
GhiaBuild
CiderGuy
CiderGuy is offline
PostPosted: Wed Apr 01, 2015 5:30 pm    Post subject: Reply with quote
When I was 17 my best friend ( who became a very well paid super mechanic ) and I replaced the shift coupler on a 63 bug I owned. He still says it was one of the hardest small jobs he has ever done. I recall it taking us most of the day. Lost the spring/clip in the tunnel .....
There were no Bentley manuals that I knew of at the time, someone showed you how to do it, or you just winged it.
-Zodiac-
-Zodiac- is offline
PostPosted: Wed Apr 01, 2015 6:25 pm    Post subject: Reply with quote
I have a spair shift rod and coupler - it just needs new ruber. Can I get just the ruber, or should I just buy a whole new coupler?
c21darrel
PostPosted: Thu Apr 02, 2015 11:17 am    Post subject: Reply with quote
They're only about $10 bucks new. Very Happy
GhiaBuild
-Zodiac-
-Zodiac- is offline
PostPosted: Thu Apr 02, 2015 2:08 pm    Post subject: Reply with quote
I was mainly concerned about quality Wink but if I can pic one up at my flaps I'll go for it.
-Zodiac-
-Zodiac- is offline
PostPosted: Fri Apr 03, 2015 12:46 pm    Post subject: Reply with quote
This morning I cranked up the ghia and it was chattering at an idle - it stopped after I let it idle a bit more, and after driving it it went away. Can anything drastic happen while driving? I'm relying on the car tomorrow, and Monday. After that I'm taking out the shift rod, replacing the coupler if needed, greasing the hell out of Everything, and replacing the bushing(still haven't verified that it's in good shape)
c21darrel
PostPosted: Fri Apr 03, 2015 1:35 pm    Post subject: Reply with quote
Everything warms up.
GhiaBuild
-Zodiac-
-Zodiac- is offline
PostPosted: Fri Apr 03, 2015 1:37 pm    Post subject: Reply with quote
Hmm..
Sounds terrible, guess I'm walking.
c21darrel
PostPosted: Fri Apr 03, 2015 2:03 pm    Post subject: Reply with quote
Good thing florida is pretty flat, no hills to walk up. Cool
GhiaBuild
