grainger Samba Member
Joined: June 09, 2004 Posts: 30 Location: Las Cruces NM
Posted: Tue Apr 05, 2005 6:27 pm Post subject: Top canvas mating with windows... |
Is this normal... the canvas not mating with the windows?
If not, how do I fix it? |
erdonline Samba Member
Posted: Tue Apr 05, 2005 7:51 pm Post subject: Mating top canvas and sides |
On mine, it seems to be caused by a bent top frame. I have seen a lot of Things with the same problem. None are perfect, but a lot are like yours (and mine). I'm eventually going to get a new or good used top frame, canvas, and side curtains. One other by-product on mine is that the bent top frame has pulled the windshield back.
Ed |
Captain Spalding Samba Member
Joined: February 19, 2005 Posts: 2519 Location: . . . in denial.
Posted: Wed Apr 06, 2005 12:19 am Post subject: Re: Top canvas mating with windows... |
grainger wrote: |
It's an endemic problem. The top frame has some typical weak spots. A poorly installed top can exacerbate the issue. Greg at German Motor Works can take your frame apart, weld on appropriate reinforcements, and put it back together, resetting the giant rivets at the hinge. Better than new, and I think less $ than new. I think I read Mike Basso provides a similar service, but I'm not sure.
Be sure to have the top canvas properly reinstalled, and then ensure that you are raising and lowering it properly, or the problem will re-occur. |
Big Luni Samba Member
Joined: December 29, 2003 Posts: 427 Location: Hartford, CT
Posted: Wed Apr 06, 2005 7:29 am Post subject: |
Also, does your top have the side clips riveted on? Alot of replacement tops don't have them, but you can pick up a set cheap from most Thing suppliers. Even if the frame is a little bent, those can help alot. |
chinarider Samba Member
Joined: November 08, 2002 Posts: 276 Location: San Francisco, CA
Posted: Wed Apr 06, 2005 10:37 am Post subject: |
That's VERY normal for Things. The type of metal used for the soft top frame had to flex enough to deal with the physics of lift (same as an airplane wing) at speed, yet be rigid enough to keep it's shape. Metal that's too soft would look much worse than most of our soft tops do after 30+ years, and metal that's too rigid could potenially crack and break apart. Colder climates exacerbate the problem.
In addition to GMW and Things Unlimited, the Thing Shop sells reinforcement bars that you can weld in place, that'll straighten out & stiffen up the frame.
I got satisfactory results by simply hammering the metal back into shape, using a combination of hardwoods and clamps. It's remained relatively straight for a few years now, but I'm planning on replacing it in time (you can only bend metal so much). |
