heywebonya Samba Member
Joined: July 08, 2010 Posts: 823 Location: Portage, MI
Posted: Wed Apr 01, 2015 6:19 am Post subject: Tubing flanges - what are they called? |
What is the name of the flanges used to join two sections of tubing for a removable section of cage or bridge the body? (muffler clamp, tubing flange, thingy?)
Should they be caps (closed ended) or open and welded around the tubing like muffler clamp?
Where is the best place to buy them?
http://offroadwarehouse.com/i-11643862-synergy-tub...thick.html
_________________ If I knew what I was doing; I wouldn't be building a buggy! |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20365 Location: Just a tiny bit west of Yosemite Valley
Posted: Wed Apr 01, 2015 6:44 am Post subject: |
"Flanges"..... I would prefer open end as you can slide a pair of flanges on tube (bolted together with washer spacer), and weld frame member into place, and then weld "flanges" in exact place you want them and then remove bolts and then cut tube with hacksaw, and you have perfectly aligned "connection"...
This site has tons of precut parts for just thing you are doing...
http://www.aa-mfg.com/
Site search results shows...
http://www.aa-mfg.com/catalogsearch/result/?q=flange
Get their "free" catalog... And they do custom orders and will give quote if you send them a sketch...
prctowd Samba Member
Joined: October 23, 2013 Posts: 10 Location: Prescott, Az.
Posted: Wed Apr 01, 2015 8:00 am Post subject: |
Here is another supplier for all kinds of brackets and such. They are in my town so I can just will call them. www.tabzone.com
Jeff |
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6767 Location: Northern California
ammocan Samba Member
Joined: October 02, 2014 Posts: 169 Location: utah, usa
Posted: Wed Apr 01, 2015 8:57 am Post subject: Re: Tubing flanges - what are they called? |
heywebonya wrote: |
I agree with the previous remarks about how these should fit. If you make proper preparations and order pipe flanges then your better off. Factory pipe flanges slide over the pipe and with perfect fit for welding and often have slightly elongated bolt holes to make bolting together easier. In theory your alignment will be perfect with factory ones unless you don't get them rotated and aligned on the 360° axis.
I made mine the way I did because it was just too easy to make a flat plate rather than cutting an opening for the pipe to slide in. If you have to do garage made ones like me then that would be entirely too much effort. Just take the extra 30 seconds to make sure your parts are properly aligned and weld together. If you take your time (which isn't much for these) you can get a nice finished product and no one will know it's not a factory part and I doubt mine is lacking in any strength but again even I would rather get these out of a box than make my own.
_________________ skill comes by the constant repetition of familiar feats, not by one over bold attempt at a feat for which the doer is yet poorly prepared |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8687 Location: Sunset, Louisiana
Posted: Wed Apr 01, 2015 9:24 am Post subject: |
If you use the slip over flanges you can also use a sleeve inside the pipe to add strength and aid in alignment of the tubes. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
