Wyntand Samba Member
Joined: December 29, 2013 Posts: 37 Location: South Africa
Posted: Thu Apr 02, 2015 2:29 am Post subject: Early Bay Chassis Differences - Help Needed |
Hi all,
I am busy with a huge rebuild of a 1969 Double Cab. The previous owner removed the chassis from just behind the front seats. His idea was to install a Subaru engine and probably thought that he needed to "upgrade" the chassis.
I initially bought this as a body only in order to cut to pieces and use the parts on my 1970 single cab. I decided to safe the 1969 Double Cab and bought a 1971 kombi "bottom half" only for its chassis, floor plates and single seat panels that I am building into the Double Cab.
There are obvious differences for example the front axle beam connection. I have the front suspension of the 1969 Double Cab and the back of the 1971 kombi, so the two different chassis will have to be merged at a point behind the front seats.
I am still preparing the 1971 kombi and removing what I don't need on the 1969 Double Cab (which is not much).
Now my questions....
(1) Is merging the two chassis possible?
(2) Would I be able to drop the 1969 Double Cab body and chassis from behind the front seats onto a 1971 kombi chassis less the front chassis. This includes the engine compartment of course?
(3) Is there anything that I need to know now as I am very careful with measuring and only see the differences as I go along? _________________ Wynand
1970 SC
1969 DC
1964 Beetle |
Djoul Samba Member
Posted: Thu Apr 02, 2015 1:54 pm Post subject: |
this is the chassis for 68-69
in 70, I think the chassis was similar (but we have a smaller splash pan)
sorry, no pict...
in 71 the front of the chassis was reinforced by the adduction of a "Y" metal section.
hope it will help you...
_________________ "please, excuse my bad English...."
69 CLIPPER-L
74 WESTY
68 BUG
73 THING
NEVER UNDERESTIMATE A BUS! |
Esher127 Samba Member
Joined: August 26, 2010 Posts: 607 Location: Staunton, VA
Posted: Thu Apr 02, 2015 1:58 pm Post subject: |
Mine is a 70 and it has the 'Y' members up front. _________________ 1970 Westfalia Pop-Top |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51152 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Apr 02, 2015 2:48 pm Post subject: |
As long as the 71 Kombi has a production date earlier than August I don't see why you can't do what you are proposing. Clearly you are into some advanced metalwork so a little difference in a bracket or something here and there isn't going to be a big deal. You've already discovered the early beam mounting pattern and as mentioned the Y members under the cab floor, from the front beam back there's no difference so any 68-71 will work, truck or bus.
How about some pics?, this project sounds ambitious! _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Apr 02, 2015 9:01 pm Post subject: |
Thank you for the info thus far. This is most certainly not a small project I am busy with and have never done this in my life (always wanted to own a DC though). I am learning as I go along and do not have deadlines as I see this as a hobby but try to be in the garage after work between 17:00 and 18:00 only.
Search the name " Mr Bambiboo " on Facebook. I am trying to update the page daily so the progress of 1 hours' work don't seem like much, but this is my own motivation. _________________ Wynand
1970 SC
1969 DC
1964 Beetle |
Tcash Samba Member
Posted: Thu Apr 02, 2015 9:08 pm Post subject: |
To bad don't do face book.
Good Luck
Tcash |
oorwullie Samba Member
Joined: May 01, 2003 Posts: 2365 Location: fribourg,switzerland
Posted: Fri Apr 03, 2015 6:32 am Post subject: |
if you didn't facebook you would MAYBE have a lot more time to work on that truck............. |
jakokombi Samba Member
Joined: August 15, 2010 Posts: 779 Location: Milwaukee
Posted: Fri Apr 03, 2015 8:03 am Post subject: |
Im curious to know if you're considered removing the rest of the 69 chassis, and going all 71'?
I have no idea of the difference in work involved, but you could have disc brakes and matching wheels (front to back). _________________ 70 Sunroof Kombi
85 Motherfukinvanagon
73 Thing
72 Baja |
Posted: Fri Apr 03, 2015 8:06 am Post subject: |
I am purely looking for good advise from fellow Air Cooled Fanatics with the same passion I have.....
Any advise will be sincerely be appreciated
Thank you for the good advise thus far. _________________ Wynand
1970 SC
1969 DC
1964 Beetle
Posted: Fri Apr 03, 2015 8:18 am Post subject: |
jakokombi wrote: |
I have no idea of the difference in work involved, but you could have disc brakes and matching wheels (front to back). |
I haven't thought about that yet..... At this moment I am using the front suspension of the '69 (including chassis) and rear suspension of the '71. I am focussing on the bigger picture at the moment which is getting the '69 body on the '71 chassis. _________________ Wynand
1970 SC
1969 DC
1964 Beetle |
