cdnltded Samba Member
Joined: March 13, 2015 Posts: 381 Location: Pincher Creek, Alberta
Posted: Sat Apr 18, 2015 11:48 am Post subject: |
EVfun wrote: |
The older cast pedals look nicer and would be appropriate for your frame. I know the clutch cable location was moved inside the tunnel at least once. How far in from the edge the tube is located is the only critical dimension. If it is the same as both of your pedal assemblies then the one to use is up to you. I can say from experience that using a roller pedal in the early pedal assembly is a bit uncomfortable on long drives. |
thanks for the info i will keep that in consideration |
Posted: Sun Apr 19, 2015 9:29 pm Post subject: |
so another little update. got the rear portion of the lip cut of and welded back up. as well as the heater tube thing
havent got them ground back down maybe tomorrow. the removal and welding took longer then i thought it would
ammocan Samba Member
Joined: October 02, 2014 Posts: 169 Location: utah, usa
Posted: Mon Apr 20, 2015 2:05 pm Post subject: |
You have quite the project on your hands. About the same rusty place I started. Looks good so far. I noticed your body mold is almost identical to mine. The only 2 places I see a difference is the dash and the spots molded for the headlights. If you happen to know or find out who made your body let me know. In the meantime keep up the good work. _________________ skill comes by the constant repetition of familiar feats, not by one over bold attempt at a feat for which the doer is yet poorly prepared |
Posted: Mon Apr 20, 2015 6:28 pm Post subject: |
ammocan wrote: |
You have quite the project on your hands. About the same rusty place I started. Looks good so far. I noticed your body mold is almost identical to mine. The only 2 places I see a difference is the dash and the spots molded for the headlights. If you happen to know or find out who made your body let me know. In the meantime keep up the good work. |
thanks
like i said your build has been my insperation
more work tonight i hope |
Posted: Mon Apr 20, 2015 6:32 pm Post subject: |
so my pedal dilema is solved. i took the newer base assembly with the factory roller assembly and put the older clutch and brake pedal on it. turns out all the shafts are the same size so i solved all my issues except the clutch and brake pedal return stop |
Posted: Mon Apr 20, 2015 9:43 pm Post subject: |
so i got one side floor pan cut out and just sitting in place. other side tomorrow night i hope
Posted: Tue Apr 21, 2015 9:44 pm Post subject: |
got the right side floor cut and also go both of the tacked into place so i can move onto other things. and alos got my pedals figured out too.just need to figure out where to put the pedal stop bolt hole
Posted: Thu Apr 23, 2015 6:33 am Post subject: |
so here is another question for all that have lots of experience.
can i use a older 1200 that is complete but seized as a engine to do all my fabbing around.
is there much difference in size to a 1500 |
Posted: Fri Apr 24, 2015 6:30 am Post subject: |
does anyone know??
heywebonya Samba Member
Joined: July 08, 2010 Posts: 823 Location: Portage, MI
Posted: Fri Apr 24, 2015 6:40 am Post subject: |
For fabbing, there is no engine size issues to be concerned about. The layout of exhaust COULD be an issue.
Nice job so far. _________________ If I knew what I was doing; I wouldn't be building a buggy! |
joescoolcustoms Samba Member
Posted: Fri Apr 24, 2015 10:47 am Post subject: |
The only issue of difference is the exhaust. A 1200 is more narrow than a 1500/1600 at the exhaust ports by about 1 inch overall. So, if you have your final exhaust on hand, loosen the heads and spread them apart enough to get the exhaust on. You will need to loosen the intake and tins to do this.
It also will not have the dog house shroud if that makes any difference. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Fri Apr 24, 2015 11:53 am Post subject: |
thanks guys |
Posted: Tue Apr 28, 2015 9:28 pm Post subject: |
got the "hat" weld into place, just need to clean up the welds. thay look way worse then they are. next will be the rear portion then the mount for the steering column
Posted: Thu Apr 30, 2015 9:46 pm Post subject: |
got some work done at the batwing tonight, just welded in some vertical pieces, that later i will attach some wider more supportive metal
this metal work takes longer then one would expect. a couple of hours a night just doesnt seem to be enough |
Posted: Wed May 06, 2015 9:43 pm Post subject: |
started to do the fab work for my gm/buick steering column
this is from the underside trying to get things into place
just got the column held in place with a strap need to make the uprights for it yet
Posted: Thu May 07, 2015 9:41 pm Post subject: |
so i got the stand alone steering column mount all tacked up and in place tonight. at this rate i will be doing final welding for a week straight.
here is some pictures
Posted: Sat Jan 23, 2016 9:26 pm Post subject: Re: My project Doom Buggy |
well almost a year later i am working on this again
got my gas tank modified for the buggy. going to us a remote fill
pictured here
also got mt driver seat mounts figured out. i am using rzr seats with only adjust on the left from a mazada rx7
Posted: Fri Jan 29, 2016 8:34 pm Post subject: Re: My project Doom Buggy |
seat all the way back
seat all the way forward
gas filler hood off
and under the hood
i think i am going to still add a bracket to the steering column support |
Posted: Thu Feb 04, 2016 10:24 pm Post subject: Re: My project Doom Buggy |
got my passenger seat mounted. but i think i put it too far forward
Posted: Sat Feb 13, 2016 2:54 pm Post subject: Re: My project Doom Buggy |
go the support for the filler neck welded in place as well as got the steering column support all welded to the final |
