shiningstar76 Samba Brewer
Posted: Fri May 01, 2015 7:39 am Post subject: Type 4 Injector question |
I couldn't find anything in the search.......
Injection is all new to me so please bear with me as I may have some noob questions.
I just changed out the rubber fuel lines under in the engine bay, and noticed that the rubber line right off injector number 3 is leaking. Is that rubber hose pressed into the injector and not replaceable? _________________ KK4NTP
96 Tacoma
86 4Runner
My bus caught on fire and is now on the other coast with someone who gave me money for it. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51057 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri May 01, 2015 7:45 am Post subject: Re: Type 4 Injector question |
shiningstar76 wrote: |
Is that rubber hose pressed into the injector and not replaceable? |
It is replaceable, you can either get under those bell shaped cups with an xacto knife and cut the hose off lengthwise or split the bell with a dremel (I prefer the surgery myself), the injector has a hose barb on the end like anything else in the system, use new FI style clamps on the new hoses. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Tcash Samba Member
Posted: Fri May 01, 2015 7:55 am Post subject: |
You have to cut a slit in the metal band around the hose and spread it, and it will come off. Make sure to use fuel injection hose it has a higher pressure rating.
Good Luck
Tcash |
Posted: Fri May 01, 2015 7:57 am Post subject: |
Great. Thanks for the help. _________________ KK4NTP
96 Tacoma
86 4Runner
