zak99B5 Samba Member
Joined: December 21, 2014 Posts: 471 Location: Albany, NY
Posted: Fri May 01, 2015 5:39 am Post subject: Heater Fan Runs But Doesn't Blow |
Well, it kinda blows a little bit. But even on high, you can barely feel air flowing out of the vents.
All the vents work properly with the ram air when the bus is moving, so it would seem all the flaps and all are good.
Any suggestions on what to look for? |
kourt Samba Member
Joined: August 13, 2013 Posts: 1940 Location: Austin, TX
Posted: Fri May 01, 2015 5:41 am Post subject: |
What year Vanagon are we talking about?
The blower isn't really meant to provide any air movement except for when the van is idle--and even then, it's marginal at best. At all other times (when the van is moving) the ram air effect is what is driving air through the vents--and you regulate the volume of air through the opening and closing of siding vent controls in the dash, not by using the rotary blower control switch.
kourt |
Posted: Fri May 01, 2015 5:46 am Post subject: |
Sorry--it's a 91.
It's less than marginal now with the van standing, even with the blower on high. |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16501 Location: Brookeville, MD
Farf Samba Member
Posted: Fri May 01, 2015 10:32 am Post subject: |
Did this problem start suddenly or has it been an issue from day 1? |
Posted: Fri May 01, 2015 10:39 am Post subject: |
I recall the fan working pretty well when I first bought the van, when I was checking it out before purchasing it. A little debris did come out of the defroster vents.
PO said he had recently fixed the resistor as the blower wasn't working before.
But I do not recall it really pushing air out the vents after that, so I would say it was rather sudden.
I did read something about loose/free-swinging flaps that might have something to do with air from the fan, though I am not 100% sure on that. |
Farf Samba Member
Posted: Fri May 01, 2015 11:07 am Post subject: |
Edit: Ooops, misread your last post. Answer not applicable. |
Farf Samba Member
Posted: Fri May 01, 2015 11:34 am Post subject: |
zak99B5 wrote: |
But I do not recall it really pushing air out the vents after that, so I would say it was rather sudden. |
Does the "after that" in the above quote mean right after the PO repaired the resister? If so, it might be possible that the polarity of the motor was reversed and is now running backwards. |
Posted: Fri May 01, 2015 11:53 am Post subject: |
Farf wrote: |
zak99B5 wrote: |
No, PO had replaced the resistor before I had seen the van the first time.
I meant "after that first time I turned the fan on." |
Farf Samba Member
Posted: Fri May 01, 2015 11:59 am Post subject: |
dobryan wrote: |
Mouse nest in the fan intake? |
Good place to start. |
Posted: Fri May 01, 2015 1:24 pm Post subject: |
dobryan wrote: |
Possible. How do I get at the fan intake?? (Please don't say remove the dash please don't say remove the dash please don't say....) |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7754 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Fri May 01, 2015 2:53 pm Post subject: |
Control cables FUBAR-ed...??? _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Fri May 01, 2015 3:27 pm Post subject: |
dhaavers wrote: |
Control cables FUBAR-ed...??? |
don't think so as everything works as it should with ram air. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32576 Location: Reading Pennsylvania
Posted: Fri May 01, 2015 7:13 pm Post subject: |
djkeev wrote: |
Access to fan is only possible by removing the Dash.
Dave |
I figured. But the fan itself isn't the problem. I do realize I will have to pull the dash and get into the heater box anyway though.
Could this be those free-swinging flaps I've read about not closing so the fan's air isn't forced to go through the heater core and out the proper vents?
I have read here you are supposed to hear them shut when you turn the fan on, but I don't hear anything. |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Sat May 02, 2015 10:24 am Post subject: |
zak99B5 wrote: |
djkeev wrote: |
Dave |
Do you have your sliders at:
-----S
S-----
-----S
-----S _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
B-bear604 Samba Member
Joined: August 16, 2014 Posts: 118 Location: Delta BC
Posted: Sat May 02, 2015 11:08 am Post subject: |
I was afraid to remove the dash the first time to, after all I'm a banker not a mechanic, but it really wasn't anywhere near as tramatic as I originally thought. Also it gives you a chance to see all that the PO messed with and it's so much easier to clean the grounds without anything in your way. Did I mention that you can clean as well, not sure how so much grime gets to areas that you can't.
Just follow ben's instructions from http://www.benplace.com/dash.htm and you are good to go.
Just as a side note I didn't remove my steering wheel, just dropped it, but I did remove my front seats to give me more room to move around.
And if I ever had to do it again I wouldn't hesitatenot as bad as I had feared. _________________ Brent H
1991 Westfalia Multivan "Vicki"
1986 Westfalia "Wolfsburg Edition" Lowered, RIP😭
2005 Jetta Wagon TDI
1985 Mercedes 380sl |
Posted: Sat May 02, 2015 12:39 pm Post subject: |
Jake de Villiers wrote: |
-----S
S-----
-----S
-----S |
It doesn't seem to matter where I have the sliders. Ram air flows out the correct vents when driving. When stopped, air only faintly exits the same vents that work at speed. |
Posted: Sat May 02, 2015 12:53 pm Post subject: |
It is possible the flaps through which ram air enters the box aren't closing well or at all. With a stock system in good condition you can hear the flaps slam shut when you turn the fan on high.
I wonder if you fan motor could be running backwards or something, you wouldn't get much air flow if that were happening. |
davideric9 Samba Member
Joined: January 21, 2009 Posts: 1000 Location: Oakland CA
Posted: Sat May 02, 2015 2:50 pm Post subject: |
"How do I get to the fan intake?"
Air intake can be seen and maybe cleaned by removing the upper grill, then removing the black plastic screen at the center. I think this is the main entry point for mice. _________________ 1987 Syncro Westfalia, stock (bought 1994)
1986 Syncro Westfalia SVX, 3 knob (bought 2008)
1987 Westfalia (bought 2010)
1988 Wolfsburg GL (bought 2012) |
