What did you do for your Type 3 today?
Page: Previous  1, 2, 3 ... 186, 187, 188 ... 222, 223, 224  Next
68vwfasty
68vwfasty is offline
PostPosted: Wed May 06, 2015 1:56 pm    Post subject: Reply with quote
chaosisme wrote:
Today I tried to clean up my crummy speedometer and replace the cracked lens but I realized that the donor speedometer had the wrong lens. I did replace the speedometer cable and now I have no more low speed wobble! Stoked!
I have been working with a shop to make a tachometer lens. Came out really nice. Probably going to get one for my speedometer since it has a crack. I could have them make a few if anyone is interested.
chaosisme
chaosisme is offline
PostPosted: Wed May 06, 2015 7:14 pm    Post subject: Reply with quote
I would be interested. Any idea how much they run?
I need one without the VDO logo on the bottom. I guess later speedometers had the VDO logo on the speedometer face itself.
'65 1500 S [quareback]
'68 FI Sunroof Squareback
'70 Westy
OCT3 - Orange County Type 3's
LouPeck
LouPeck is offline
PostPosted: Thu May 07, 2015 10:37 am    Post subject: Reply with quote
ataraxia wrote:
squaretobehip wrote:
ataraxia wrote:
Air-Cooled Head wrote:
What goes between the gas tank and the body? It seems I recall foam rubber, or something on a T1, but there was nothing when I removed mine.
Originally, there's a thin foam gasket between the tank and the body...most of them self-destruct on their own without any help from people.
Of all of the cars I've owned, I've seen remnants of a few and only pulled one off of a car semi-intact.
Wouldn't it be in the parts book? I did a quick flip through but didn't see anything listed or pictured. Maybe it's hiding somewhere. Think
Come on, dude!
311 201 621
Anti squeak packing -Fuel tank
Group 2, Illustration 13, #36 on the diagram
It was a quick glance! Geez! Very Happy
Well there you have it folks. There should be a foam seal.
Just for shits and grins...
Not to beat this topic up too much, but what kind of seal exactly should we go with? If it is foam, should it be with or without rubber layers encapsulating it? what thickness and width should it be? The part description of `Anti squeak packing' is vague as to the exact material used.
1970 Baywindow weekender
1967 sunroof Squareback
squaretobehip
squaretobehip is offline
PostPosted: Sun May 10, 2015 11:46 am    Post subject: Reply with quote
I took my Mom on a nice scenic cruise through the Orange foothills. She really likes my Squareback.
1963 Notchback - Ruby Red
1963 Squareback - Pearl White
1965 Squareback - Baltic Blue
Follow ISP West on:
ALLWAGONS
ALLWAGONS is offline
PostPosted: Sun May 10, 2015 6:01 pm    Post subject: Reply with quote
I am proud of you Sir!
Martin
allwagons
Air-Cooled Head
Air-Cooled Head is offline
PostPosted: Mon May 18, 2015 6:31 am    Post subject: Reply with quote
Re-installed fuel tank and connected to fuel pump. Adjusted valves and went around the block. First time on the road since Fall, 2012. Dancing
Everything known to man has been written.
Readers are Leaders!
t3kg
t3kg is offline
PostPosted: Mon May 18, 2015 8:02 am    Post subject: Reply with quote
110-mile round trip shakedown cruise to the Bug-In. Trans definitely needs an overhaul. All forward gears whine like it's in reverse. Neutral All good otherwise -- runs cool and cruises comfortably at 70.
I WAS THERE! The 2017 Type 3 Rally / September 29–October 1 / Cayucos, CA
2014: The 2014 Type 3 Rally / October 3–5 / Cayucos, CA
2011: 50 Years of the VW Type 3 / September 29–October 1 / California Central Coast
squaretobehip
PostPosted: Mon May 18, 2015 8:18 am    Post subject: Reply with quote
It was nice seeing you AND your Ghia. Cool
Follow ISP West on:
type3nut64
type3nut64 is offline
PostPosted: Mon May 18, 2015 8:34 am    Post subject: Reply with quote
I thought it was cool show. Caught up with with a lot of people i hadn't seen in while.
Glad you brought your car out.
JeeJeeJason
JeeJeeJason is offline
PostPosted: Mon May 18, 2015 8:57 am    Post subject: Reply with quote
Got it on the road from Oakland to Santa Cruz, checked the oil pressure to make sure my flickering oil light wasn't serious and swapped shocks with Mr. Steve Clatter.
1968 FI Squareback
ibjack
ibjack is offline
PostPosted: Mon May 18, 2015 10:31 am    Post subject: Reply with quote
My does (sounds) the same thing. Doesn't pop out of gears and the fluid level is fine so I just drive it
'68 Lotus White T34 automatic sunroof
'64 Manila Yellow T34
'65 Sea Blue Square Panel
the1500club.com
Shop Lacky at the T3/34 Factory, https://www.facebook.com/profile.php?id=100094313902074
Erik G
Erik G is offline
PostPosted: Mon May 18, 2015 2:49 pm    Post subject: Reply with quote
man, I love that car. if you get the trans rebuilt, make sure it's someone that really knows what they are doing. I've had rebuilt transaxles that make noise...
squaretobehip
PostPosted: Mon May 18, 2015 3:56 pm    Post subject: Reply with quote
Were your beauty rings still there when you left? Laughing
Follow ISP West on:
t3kg
t3kg is offline
PostPosted: Mon May 18, 2015 8:40 pm    Post subject: Reply with quote
You tell me. Confused Very Happy
Typ311Dave
Typ311Dave is offline
PostPosted: Mon May 18, 2015 9:05 pm    Post subject: Reply with quote
She's running Scott? Damn, I guess the pressure is on now... Embarassed
'62 golfblau Typ 311 Limousine
'89 Vanagon GL Bluestar
"The object of war is not to die for your country but to make the other bastard die for his." - Gen George S. Patton
t3kg
t3kg is offline
PostPosted: Mon May 18, 2015 9:14 pm    Post subject: Reply with quote
Don't worry Dave, I'm in no danger of finishing it soon.
ibjack
ibjack is offline
PostPosted: Mon May 18, 2015 10:48 pm    Post subject: Reply with quote
Did I ever mention how much I love that a color?
the1500club.com
t3kg
t3kg is offline
PostPosted: Mon May 18, 2015 11:43 pm    Post subject: Reply with quote
It's all yours, Jack! Wink
Sumguy
Everett's Parts Holder
Sumguy is offline
PostPosted: Tue May 19, 2015 2:15 pm    Post subject: Reply with quote
Looking great , good to hear it's running right. You gunna make the classic so i can see it
t3kg
t3kg is offline
PostPosted: Tue May 19, 2015 7:38 pm    Post subject: Reply with quote
Thanks Eric -- trying to decide between the Classic or El Prado or both. Think
Page 187 of 224
