68vwfasty Samba Member
Joined: March 26, 2014 Posts: 277 Location: Portland, OR
Posted: Wed May 06, 2015 1:56 pm Post subject: |
chaosisme wrote: |
Today I tried to clean up my crummy speedometer and replace the cracked lens but I realized that the donor speedometer had the wrong lens. I did replace the speedometer cable and now I have no more low speed wobble! Stoked! |
I have been working with a shop to make a tachometer lens. Came out really nice. Probably going to get one for my speedometer since it has a crack. I could have them make a few if anyone is interested. |
chaosisme Samba Member
Joined: August 29, 2005 Posts: 1256 Location: Orange County, Ca
Posted: Wed May 06, 2015 7:14 pm Post subject: |
68vwfasty wrote: |
chaosisme wrote: |
I would be interested. Any idea how much they run?
I need one without the VDO logo on the bottom. I guess later speedometers had the VDO logo on the speedometer face itself. _________________ '65 1500 S [quareback]
'68 FI Sunroof Squareback
'70 Westy
OCT3 - Orange County Type 3's |
LouPeck Samba Member
Posted: Thu May 07, 2015 10:37 am Post subject: |
ataraxia wrote: |
squaretobehip wrote: |
ataraxia wrote: |
ataraxia wrote: |
Air-Cooled Head wrote: |
What goes between the gas tank and the body? It seems I recall foam rubber, or something on a T1, but there was nothing when I removed mine. |
Originally, there's a thin foam gasket between the tank and the body...most of them self-destruct on their own without any help from people.
Of all of the cars I've owned, I've seen remnants of a few and only pulled one off of a car semi-intact. |
Wouldn't it be in the parts book? I did a quick flip through but didn't see anything listed or pictured. Maybe it's hiding somewhere. |
Come on, dude!
311 201 621
Anti squeak packing -Fuel tank
Group 2, Illustration 13, #36 on the diagram |
It was a quick glance! Geez!
Well there you have it folks. There should be a foam seal. |
Just for shits and grins... |
Not to beat this topic up too much, but what kind of seal exactly should we go with? If it is foam, should it be with or without rubber layers encapsulating it? what thickness and width should it be? The part description of `Anti squeak packing' is vague as to the exact material used. _________________ 1970 Baywindow weekender
1967 sunroof Squareback |
squaretobehip Samba Member
Joined: August 23, 2004 Posts: 3686 Location: San Jose, CA
Posted: Sun May 10, 2015 11:46 am Post subject: |
I took my Mom on a nice scenic cruise through the Orange foothills. She really likes my Squareback. _________________ 1963 Notchback - Ruby Red
1963 Squareback - Pearl White
1965 Squareback - Baltic Blue
Follow ISP West on:
Instagram - @ispwest - www.instagram.com/ispwest |
ALLWAGONS Samba Member
Joined: June 03, 2000 Posts: 4188 Location: Pasadena CA/DTLA soon China
Posted: Sun May 10, 2015 6:01 pm Post subject: |
I took my Mom on a nice scenic cruise through the Orange foothills. She really likes my Squareback. |
I am proud of you Sir!
Martin
allwagons _________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
NON INFLUENCER APPROVED |
Air-Cooled Head Samba Member
Joined: October 15, 2002 Posts: 4070 Location: Chicago Suburbs
Posted: Mon May 18, 2015 6:31 am Post subject: |
Re-installed fuel tank and connected to fuel pump. Adjusted valves and went around the block. First time on the road since Fall, 2012. _________________ Everything known to man has been written.
Readers are Leaders! |
t3kg Samba Member
Joined: June 14, 2006 Posts: 2712 Location: Los Angeles
Posted: Mon May 18, 2015 8:18 am Post subject: |
t3kg wrote: |
110-mile round trip shakedown cruise to the Bug-In. Trans definitely needs an overhaul. All forward gears whine like it's in reverse. All good otherwise -- runs cool and cruises comfortably at 70.
It was nice seeing you AND your Ghia. _________________ 1963 Notchback - Ruby Red
Follow ISP West on:
type3nut64 Samba Member
Joined: September 25, 2000 Posts: 347 Location: Yucaipa Ca.
Posted: Mon May 18, 2015 8:34 am Post subject: |
t3kg wrote: |
It was nice seeing you AND your Ghia. |
I thought it was cool show. Caught up with with a lot of people i hadn't seen in while.
Glad you brought your car out. |
JeeJeeJason Samba Member
Joined: May 23, 2014 Posts: 234 Location: Bay area, CA
Posted: Mon May 18, 2015 8:57 am Post subject: |
Got it on the road from Oakland to Santa Cruz, checked the oil pressure to make sure my flickering oil light wasn't serious and swapped shocks with Mr. Steve Clatter.
_________________ 1968 FI Squareback |
ibjack Samba Member
Joined: February 06, 2002 Posts: 2105 Location: Imperial Beach CA
Posted: Mon May 18, 2015 10:31 am Post subject: |
t3kg wrote: |
My does (sounds) the same thing. Doesn't pop out of gears and the fluid level is fine so I just drive it _________________ '68 Lotus White T34 automatic sunroof
'64 Manila Yellow T34
'65 Sea Blue Square Panel
the1500club.com
Shop Lacky at the T3/34 Factory, https://www.facebook.com/profile.php?id=100094313902074 |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13271 Location: Tejas!
Posted: Mon May 18, 2015 2:49 pm Post subject: |
t3kg wrote: |
man, I love that car. if you get the trans rebuilt, make sure it's someone that really knows what they are doing. I've had rebuilt transaxles that make noise... _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Posted: Mon May 18, 2015 3:56 pm Post subject: |
Were your beauty rings still there when you left? _________________ 1963 Notchback - Ruby Red
Follow ISP West on:
t3kg Samba Member
Typ311Dave Samba Member
Joined: June 16, 2006 Posts: 1253 Location: San Diego, CA "6-Volt"
Posted: Mon May 18, 2015 9:05 pm Post subject: |
t3kg wrote: |
She's running Scott? Damn, I guess the pressure is on now... _________________ '62 golfblau Typ 311 Limousine
'89 Vanagon GL Bluestar
"The object of war is not to die for your country but to make the other bastard die for his." - Gen George S. Patton |
t3kg Samba Member
ibjack Samba Member
Posted: Mon May 18, 2015 10:48 pm Post subject: |
t3kg wrote: |
Did I ever mention how much I love that a color? _________________ '68 Lotus White T34 automatic sunroof
the1500club.com
t3kg Samba Member
Sumguy Everett's Parts Holder
Posted: Tue May 19, 2015 2:15 pm Post subject: |
Looking great , good to hear it's running right. You gunna make the classic so i can see it |
t3kg Samba Member
