Tcash Samba Member
Posted: Sun Nov 18, 2012 7:27 pm Post subject: Cranks Won't Start Test |
To link to this thread
Code: |
[url=http://www.thesamba.com/vw/forum/viewtopic.php?t=535382&highlight=]Cranks Won't Start Test[/url] |
These are the first things I grab to isolate a cranks won't start problem.
Starter Fluid. If it fires on this you have a fuel problem.
Please read and understand the directions.
Spark Tester. No Spark you have an Ignition problem.
Be aware these are made for both Points Ignition, which includes electronic points, ie Pertronix etc.
and HEI (high energy ignition) systems.
So get the one you need for your vehicle and read and understand the instructions.
Or if you don't have those on hand.
As mentioned first thing you need to do is determine if it is
1. Fuel
Pour a couple of table spoons of gas down the carburetor throat and try and start it.
If it starts or tries to, it is a fuel problem.
2. Electrical
Test for spark. What you are looking for is a nice hot blue flame. Not an Orange or Yellow flame they are too cold.
VDubTech Samba Member
Joined: December 29, 2002 Posts: 9142 Location: Syracuse, NY
Posted: Sun Nov 18, 2012 7:32 pm Post subject: |
Unless you really like a cracked piston, stay away from starting fluid. Is there a point to your post? _________________ First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote: |
a measurement of your rod would be extremely useful. |
notchboy wrote: |
my dad wasnt a belittling cock when he tought me how to wrench on cars. |
EverettB wrote: |
One photo = good for reference.
10 photos = douchebaggery |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51126 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Nov 18, 2012 7:40 pm Post subject: |
Indeed, why the starting fluid? OWCH!!!! A spoonfull of gas will do the same thing without the needless super low octane and permanent engine damage. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Tcash Samba Member
Posted: Wed Jun 03, 2015 8:38 pm Post subject: Re: Cranks Won't Start |
Tcash wrote: |
Starter Fluid. Please read and understand the directions. If it fires on this you have a fuel problem.
Spark Tester. No Spark you have an Ignition problem. Be aware these are made for Points Ignition and Electronic Ign. So get the one you need for your vehicle and read and understand the instructions.
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
SGKent Samba Member
Posted: Thu Jun 04, 2015 7:57 am Post subject: |
I had read WD-40 was not that flammable so once I cleaned a small saw motor bearing of sawdust using it. The saw became a small jet engine the first time it was used, throwing flames about 3'. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
bbrowncods Samba Member
Joined: December 27, 2014 Posts: 58 Location: Virginia
Posted: Mon Jan 29, 2018 3:16 pm Post subject: Re: Cranks Won't Start Test |
I once sprayed out a distributor with WD-40 and put the cap back on. Got in to crank it up. I heard a pop and it wouldn't start. Went back and opened the lid. The distributor cap was in about a thousand pieces! |
