chazwood Samba Member
Joined: February 11, 2006 Posts: 678 Location: The last word in edgewise
Posted: Thu Jun 04, 2015 1:00 pm Post subject: Which way does the back firewall engine seal go? |
Flap up or flap down? Read on.
I have searched this topic and found may wrong answers. The back piece of rubber is made so that it fans out nicely when installed one way.... and bunches up all sadly and won't seal a thing, when installed the other.
Which way is correct you say?
If you had never tried it both ways you might be confused.
If you have a piece of "original" rubber (that someone may have put in backwards)... you might still be confused.
You will not be confused if you simply take the time to put it in both ways and compare.
Then it is painfully obvious which way it goes.
To avoid all the arguments from the "experts" I have not divulged the proper way on purpose.
If you need to know message me. I would be glad to tell you. |
Pinetops Samba Member
Posted: Thu Jun 04, 2015 1:51 pm Post subject: |
I would think down. Another question is, does the flap go between the tin and the body or on top of the tin? It wants to flop down behind the tin, but you can get it to lay on top with a little effort. _________________ "A rolling bus gathers no rust." |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51149 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Jun 04, 2015 2:54 pm Post subject: |
You'd better at least divulge the maker and source of said seal, there's a few different ones on the market and no two fit the same. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Posted: Thu Jun 04, 2015 3:18 pm Post subject: |
There's only one firewall engine seal right? (the one above the flywheel).... not a 'back' one.... and a 'front' one... side...
Firewall is at the front of the engine... right?
Title's got me confused. _________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
Big Bill Samba Member
Joined: June 21, 2005 Posts: 1782 Location: Santa Rosa, Ca
Posted: Thu Jun 04, 2015 4:52 pm Post subject: |
I always install them flap up, I would think it seals better that way. I usually take a flat stick after the engine is in and run it between the engine and seal to position it the way I like it. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69824 Location: Phoenix Metro
flemcadiddlehopper Samba Member
Joined: December 05, 2011 Posts: 2332 Location: Kelowna, BC. Canada.
Posted: Thu Jun 04, 2015 5:43 pm Post subject: |
Never mind the seal....I can't take my eye off the jack stands. If you stare at them long enough, you can actually see them starting to sink into the gravel. Freakin' me out.
Gordo. _________________ Everybody Dies....Some Never Live.
Retrograde Garage. Vintage Aircooled, and others. |
campingbox Samba Member
Joined: November 14, 2000 Posts: 10196 Location: Petaluma, CA
Posted: Thu Jun 04, 2015 7:24 pm Post subject: |
flemcadiddlehopper wrote: |
Gordo. |
Maybe Everett can't afford concrete? Better send in some donations before the bus falls on him! |
suebug Samba Member
Joined: April 13, 2006 Posts: 1152 Location: The OC, SoCal, with my olympic cats
Posted: Sun Jun 07, 2015 10:31 am Post subject: |
Clean the track really well, then watch your knuckles and be gentle as you nurse it across with some gel type lube helps.
It goes back and up even though it looks down there's an up.
_________________ '67 Beetle
'67 Squareback
'66 Sundial
'60 Single cab
'70 Bitchen 3-speed Schwinn |
Stocknazi Samba Member
Posted: Sun Jun 07, 2015 7:00 pm Post subject: |
suebug wrote: |
Now that's a nice looking motor. _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
BlastMasterMannyFresh Samba Member
Joined: November 21, 2001 Posts: 6102 Location: #31peach
Posted: Sun Jun 07, 2015 7:30 pm Post subject: |
campingbox wrote: |
Gordo. |
Greg maybe you should start a go fund me campaign for his driveway. |
Clara Samba Member
Posted: Sun Jun 07, 2015 8:37 pm Post subject: |
suebug wrote: |
I like the Hello Kitty towel. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
