telford dorr Samba Member
Joined: March 11, 2009 Posts: 3555 Location: San Diego (Encinitas)
Posted: Tue Jun 09, 2015 12:13 pm Post subject: Another fuel sender repair method T2a |
To link to this thread copy and paste
Code: |
[url=https://www.thesamba.com/vw/forum/viewtopic.php?p=7706426#7706426]Another fuel sender repair method T2a[/url] |
Good original German parts for VW's are getting harder and harder to find, and their aftermarket replacements are getting to be poorer and poorer in quality. Thus, it makes sense, if possible, to repair existing parts and restore them to working condition.
One such part is the fuel sender used on early bay window buses, 1968 to approximately 1972.
You will need some tools to perform this repair. Below is a picture of those I use. You may substitute whatever tools you have which will get the job done properly.
From the rear: 4-40 x 1/4" pan head screws and nuts (in film cans), flux and solder, alcohol, Loctite 242. In the middle: various screwdrivers, flux brush, 4-40 tap, DVM. In the front: tinned 22 ga solid copper wire, twist tie, various pliers and cutters. Not shown: soldering iron, cleaning brush.
Procedure
First, you must open the sender so that you can access its internals. To do this, find the nut and keeper located on the bottom of the unit.
Carefully pry the ears of the retainer away from the nut. The retainer is fairly brittle with age, so pry carefully, as we want to reuse this part. Once the ears are out of the way, remove the nut and retainer. Now the covering tube should be removable by pulling it off the sender.
The innards of the sender are fragile, so use caution in dealing with them. You will see a float which slides up and down the center post, and along two fragile resistance wires. Slide the float to the far end of the rod and use the twist tie to keep it there.
Now lay the unit on its lid with the float pointing up. Inspecting the lid, you will see a spring brass tensioner which keeps the resistance wires taunt. It is pressed against the die cast lid by a rivet and metal and plastic washers. The center rivet is the connection to one resistance wire; the brass tensioner is the connection to the other. The float connects the two wires together.
The most common failure mode in this unit is the connection between the lid (pot metal / zinc / aluminum / ?) and the brass tensioner. As these are different metals, corrosion slowly forms between them. This corrosion adds unwanted resistance to the sensor, messing up its ability to deliver accurate information. As the resistance increases, the fuel reading for a full tank slowly drops, and the fuel gauge will indicate empty way too early. So, what we need to do is eliminate this unwanted resistance.
However, we have a problem: the unit is riveted together and it is impractical to disassemble it any further. So, we will have to find a way to create a better connection here.
If you inspect the lid casting, you will notice a hollow area below where the resistance wire is fastened to the brass tensioner. What we're going to do is drill and tap a small hole here. We will use this hole to connect a new ground wire to the lid, and then solder that wire to the brass tensioner, thus bypassing the corroded high resistance connection which has formed. The hole should go where shown. As I used a 4-40 screw, i drilled the hole 5/64" in diameter. If you're using metric hardware, drill a hole of the appropriate size for your tap.
Drill carefully so as to not damage the brass tensioner or resistance wires. Afterwards, tap the hole. The metal is reasonably thick here, so you should get a couple of threads. Clean off any burrs and carefully blow off chips with compressed air.
Now take a length of 22 gauge tinned copper wire and form a loop at one end. The loop should fit snugly over the end of the screw, as shown. Twist the wire to retain it, but not so much as to weaken the wire.
Now insert the wire and screw into the tapped hole from the inside of the lid and tighten. Flip the lid over, put a couple of drops of Loctite on the protruding screw theads, back off the screw a couple of turns to get the Loctite into the joint, then tighten the screw snugly. Add another drop of Loctite, then install and tighten the jamb nut. When complete, it should look like this:
Now you must scrape a spot in the brass tensioner clean and shiny, so you can solder the wire to it. I picked a spot close to the rivet, such that the soldered joint would be as free from any movement as possible.
Take your time doing the scraping. The brass is usually quite corroded, and must be completely clean. Close isn't good enough. Any remaining corrosion will keep the solder from wetting the metal properly, and your soldered joint will fail. When done, it should look even better than this:
Now you must tin the brass tensioner. We're using rosin core solder, 60/40 or 63/37. Unfortunately, the rosin flux in the solder doesn't have the horsepower to get the brass clean enough, so I pre-fluxed the joint with zinc chloride paste flux. Heat the metal with your soldering iron or gun, then add some solder. Heat until the solder flows and wets the brass, but not so much as to melt the plastic/rubber insulator next to it.
Now bend and cut the wire so that it reaches the tinned spot on the brass. Tin the end of the wire, and (with your three hands), heat the joint, press the wire into it with a small screwdriver, and add solder as needed. Afterwards, I add a little more flux, and flow the joint a second time. just to be sure.
When cool, fully clean the joint with alcohol (methanol or shellac thinner). You want to remove all traces of flux. [Note: flux is soluble in alcohol fuels, and would love to plug up your carb jets or fuel injectors, so do a good job.] Now blow dry with compressed air. It should look like this:
Now use the ohmmeter to check the resistance from the sender lid to the brass tensioner. It should be close to zero. Also check the resistance from the wire terminal to the other resistance wire. It should also be close to zero.
There are two more areas where a corroded connection can mess up your fuel sender. They seldom fail, but since it's such a hassle getting at the sender, you might a well repair them now.
The first is at the rivet inside the sensor. Scrape clean, flux, and solder as before. Should look like this when done:
The second is between the rivet and the terminal. This joint is harder to clean and solder, and takes more heat. Should look like this when done:
Now connect the ohmmeter between the sender case and terminal. You should get readings near these, with the sender upright and inverted:
Once the sender has been verified good, reinstall the metal cover tube using the original retainer and nut. Tighten the nut enough to secure the tube. Now carefully bend the ears on the retainer to capture the nut.
Notes on Soldering
Soldering is a thermo-chemical process where one metal is dissolved in another. In our case, the outer surface of the copper wire is dissolved in solder. Being chemical in nature, the joint must be clean and free of any corrosion or contaminates. This is achieved by mechanical cleaning and chemical cleaning, using flux. The hot flux reacts with trace contaminates and metal oxides, and either converts them to forms compatible with soldering, or floats them away from the joint. Thus, good clean flux, of the proper type, is essential to successful soldering. Do not use acid fluxes, as they lead to long term corrosion issues.
Soldering involves the application of heat. You want a lot of heat, but not a lot of temperature. This is the secret to successful soldering. You want to get the joint hot as quickly as possible (lots of heat), but limit the temperature to a point where the solder isn't damaged. I use a 60 watt Weller soldering iron with a 700 degree paramagnetic temperature controlling tip. This iron will dump massive amounts of heat into the joint, but limit the maximum temperature to around 700 degrees F.
Note: this post is a reproduction of a new webpage found at
http://telforddorr.com/FuelSenderRepair/
Comments and corrections welcome. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST)
airschooled Air-Schooled
Posted: Tue Jun 09, 2015 12:31 pm Post subject: |
Wow! Thank you Telford! I'm so glad I kept my old broken sender. This may just give me the confidence to make it work again.
As far as comments go, I think the "." at the end of your personal redirect link at the bottom is confusing my old browser. Removing the period should help stupid browsers redirect. Safari doesn't have that problem at home, but this Internet Exploder window can't tell the difference...
www.airschooled.com |
Posted: Tue Jun 09, 2015 12:45 pm Post subject: |
Fixed. Thanks. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Tue Jun 09, 2015 1:00 pm Post subject: |
still no pics on explorer |
Posted: Tue Jun 09, 2015 1:24 pm Post subject: |
All photos copied to, and now hosted from the Gallery. _________________ '71 panel, now with FI
morymob Samba Member
Posted: Wed Jun 10, 2015 4:01 am Post subject: |
I think i have one somewhere that has resistor wire broken. Neochrome (spelling??) wire comes in different resistance, ohms per ft, maybe too low 4 this short piece. Has to be somekind out there to replace it, in yrs of electronic world never run into any. Will try a search? ? |
busdaddy Samba Member
Posted: Wed Jun 10, 2015 7:11 am Post subject: |
Great post!, well done! _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Tcash Samba Member
SGKent Samba Member
Posted: Wed Jun 10, 2015 8:58 am Post subject: |
Good post. Even back when these buses were new, senders only lasted 3 or 4 years. I am thinking this repair is likely to last a lot longer. The other place that used to present issues is that the fingers holding the slide to the nichrome wire would wear and not make good contact. The solution to that was to lightly sand the wire with something light, like a scotch brite pad, and then make sure the fingers were clean and tight but not too tight.
A person could make a business of repairing senders based on the cost to replace them. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
AaronT Samba Member
Joined: December 18, 2014 Posts: 22 Location: Kodak, TN
Posted: Wed Jun 10, 2015 9:21 am Post subject: |
Very interesting.. Thank you for posting _________________ AaronT
1959 Beetle - Betty
1963 Single Cab - Sam
1970 Bay Bus - Lyle
2009 Custom Sand Rail |
grandpa pete Samba Member
Posted: Wed Jun 10, 2015 10:12 am Post subject: |
grandpa pete wrote: |
Where can I buy film cans like yours to put my screws in ? ...do you have their website |
You go to the guy with the time machine and transport back to the '60's. They're readily available there (and for no extra charge, you get a free roll of film!)
No, they're from my very old personal supply of film cans - NLA. _________________ '71 panel, now with FI
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2541 Location: Ocean Beach in Beautiful BLUE California
Posted: Wed Jun 10, 2015 10:56 am Post subject: |
After a minor electrical fire under the dash I attempted to replace the damaged wires. Big Mistake. In doing so I managed to fry the sender. Fortunately there was this skilled and kind gentleman that repaired all the damage and restored the electrical functions.
Thank you Telford!
Now - about that sender…. Is **someone** interested in attempting to rebuild my 46 year old fried sender? _________________ Larry in OB
69 Westfalia and 2002 Eurovan Camper. |
Posted: Wed Jun 10, 2015 1:26 pm Post subject: |
Get it over to Gary. I can pick it up there and take a look.
- Or -
He has a couple of spares, already overhauled. Maybe do an exchange of some kind, depending on the damage... _________________ '71 panel, now with FI
OB Bus Samba Member
Posted: Wed Jun 10, 2015 6:48 pm Post subject: |
Talk to Gary. He just did this. He used a borescope to find the sender, and get the access hole right over it. Fitted a nice removable marine grade cover to close the hole. _________________ '71 panel, now with FI
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Wed Jun 10, 2015 8:00 pm Post subject: |
Good job on the repair Telford. This was a full tank 30 miles ago.
_________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Wed Jun 10, 2015 8:06 pm Post subject: |
aeromech wrote: |
Good job on the repair Telford. This was a full tank 30 miles ago. |
Hmmm...... thirsty _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
SGKent Samba Member
Posted: Wed Jun 10, 2015 8:13 pm Post subject: |
aeromech wrote: |
Yeah - Nice job Telford and Gary but the red lights on all the time would drive me nuts _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Wed Jun 10, 2015 8:32 pm Post subject: |
... Where can I buy film cans like yours to put my screws in ? ... |
Baby food jars are excellent. Different sizes, clear glass, and the vanilla pudding is tasty.
Aloha
tp |
