notchboy Samba Member
Joined: April 27, 2002 Posts: 22463 Location: Escondido CA
Posted: Wed Apr 29, 2015 10:52 am Post subject: All things Essen - Westfalia Trailers |
As the population of Westfalia Essen Trailers increase in the US - I thought it best to start a "hub" for the info on parts and a place to show off yours.
At present I have two for my personal use. I will be "importing" ten for those that may be interested in one.
Ive also been fortunate enough to find OG Westfalia trailer hitches for Bay Window Buses to pull with.
Here is some shots of what I have now.
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
lewism Samba Member
Joined: May 23, 2004 Posts: 25 Location: northwest of normal
Posted: Wed Apr 29, 2015 12:38 pm Post subject: |
Thank you for this. I don't think I used the word in the post, but I would've gotten it wrong. I've had mine for too long in a dis-assembled state, when I got it the CELLASTO units were completely blown out. The frame is powder-coated beige.
I want to use stainless steel metric carriage bolts for reassembly. And paint the plywood floor top and bottom with truck-bed liner. Are those good ideas?
Just asking to turn on reply notifications. |
Posted: Wed Apr 29, 2015 1:25 pm Post subject: |
lewism wrote: |
Making it look as stock as possible is always the best in my opinion. Sometimes its hard depending on what you have left to restore. These were utility trailers meant to haul some harsh, heavy stuff - and then most times left to the elements. Not many survive that don't have some sort of "owner improvement".
I think you have a great plan except for the bed liner. I would choose to restore the wood to look like the original color and cover the floor in a rubber mat so as not to worry about gashing or scuffing.
If this is to be used as intended - hauling whatever all the time then make it as you will, but if you want to showcase it behind a classic car - then I think it needs to be classic as well. It should hold a higher value if it looks restored to factory spec if you should sell one day.
I follow these rules because I tow behind a classic and like to keep the appearance of how it was back in the day _________________
t3kg wrote: |
1964 1500 S
lewism Samba Member
Posted: Wed Apr 29, 2015 4:57 pm Post subject: |
Mine's pretty complete, except for a small chunk missing from one fender's trailing edge. And the rack on top has a monogram M on the sides. That's how I knew it was made for me.
Since I hadn't thought about this for a while, I updated. I like Plastidip S, so now it's rubber floormat on top and thick, peelable sheet of satin black Plastidip on the bottom, against the beige powdercoated frame.
What's the best way to refinish the zinc coating on the steel frame?
I'm going for Re-vertable. I couldn't drive without my 5-panel Wink mirror and Hella H-4s. |
Posted: Mon Jun 15, 2015 8:26 pm Post subject: |
Here are the two canopy type tops. One is a rigid design with a frame that is meant to sit inside the trailer without the lid-hard top on. The second is also designed for the same but is meant to sit outside the box on the lip. Its neat feature is that the frame comes apart like a tent pole frame. I see this second types feet also modified to sit on top of the hard top covering the rack and lid under it.
Here is the rigid frame type.
Here is the frame set on top of the lip with the hard top removed as it should be.
Notice the joints so it can come apart like a tent.
With the cover.
This last is an earlier example with the tent top cover added with the feet modified to set on top of the hard lid. Notice the trademark Westfalia rack bars.
t3kg wrote: |
1964 1500 S
lewism Samba Member
Posted: Tue Jun 16, 2015 3:15 pm Post subject: |
Thanks for that. The lidless version seem more utilitarain. Do measured drawings exist?
The plywood box and angle iron frame is in good shape on mine, but the carriage bolts holding everything together were badly rusted.
Should replacements be metric?
Would stainless steel be over-restoring it? |
Posted: Tue Jun 16, 2015 3:19 pm Post subject: |
lewism wrote: |
I would put generic - US stainless in mine - no matter what shape it was in. I used US Stainless from Home Depot to hang the spare tire carrier. _________________
t3kg wrote: |
1964 1500 S
lewism Samba Member
Posted: Tue Jun 16, 2015 7:25 pm Post subject: |
Thanks. Last I checked Eugene Fastener had metric stainless available.
You don't think it would affect the resale value? |
Posted: Tue Jun 16, 2015 7:53 pm Post subject: |
lewism wrote: |
Im sure someone will appreciate it _________________
t3kg wrote: |
1964 1500 S
RONIN10 Samba Member
Joined: April 30, 2007 Posts: 594 Location: Seattle, WA
Posted: Mon Sep 21, 2015 9:47 am Post subject: |
I have never dealt with them direct - but have heard good things. The prices are pretty much in line with anywhere else you can get the stuff.
The trailer finds a new home.
t3kg wrote: |
1964 1500 S
Posted: Mon Sep 21, 2015 7:34 pm Post subject: |
RONIN10 wrote: |
Have you, Jason, or anyone else for that matter located parts lists or diagrams? I'm on the hunt as I type this. |
I have not or do not know of any parts diagram for these trailers. Companies like you listed are the only ties to these trailers I know of or have. Other than Facebook threads that dedicate their space to all Westfalia Trailers.
I hope you find some _________________
t3kg wrote: |
1964 1500 S
6of1 Samba Member
Posted: Fri Nov 13, 2015 4:20 pm Post subject: Re: All things Essen - Westfalia Trailers |
Just brought this trailer in the UK. I'm going to restore it back to original as far as possible. Any advice welcome
Thanks
Arthur
Bromley Kent
UK
Took off the back lights that are not original
The work starts
Posted: Sat Nov 14, 2015 11:31 am Post subject: Re: All things Essen - Westfalia Trailers |
Off to a good start. Are you wanting all stock or tweaking it to your liking here and there?
Love the westy rack bar on the lid _________________
t3kg wrote: |
1964 1500 S
Posted: Sun Nov 27, 2016 9:43 pm Post subject: Re: All things Essen - Westfalia Trailers |
Over the nest couple months I plan on filling in some of the details on this small, light versitile little trailer. Ive come to know it quite well with several imports from Europe to the states and then selling them. Its allowed me to keep two - well accessorised examples and sell 13 others off to individuals in the states - well 11 as I have two left.
So I hope to show what can be done all at onve here - for all Ive learned. Overseas purchase, what accessories come on them, what the costs are involved and any other questions in between
Shot of the 77 towing a 750k edition to the Yakima show here in Washington State.
t3kg wrote: |
1964 1500 S
dsliman Samba Member
Posted: Sun Dec 18, 2016 9:38 am Post subject: Re: All things Essen - Westfalia Trailers |
Hello, I have recently imported two Essen trailers to the states and in the process of getting them back to original condition (reasonably speaking)! Looking for original (or similar) detachable cover hinges and front hasp. Any recommendations where I can find something suitable? |
Posted: Wed Apr 19, 2017 12:35 pm Post subject: Re: All things Essen - Westfalia Trailers |
Taken from Text and photos: Rolf de Kam
http://www.vwbusclub.nl/westfalia-aanhangers/
Westfalia Essen.
Finally, I would like to discuss the type of 'Essen'. This was indicated by Westfalia as Reisegepäckanhänger or simply baggage trailer, and was nothing more and nothing less. A relatively inexpensive trailer, well built but very light and easy to store thereby attracted a large audience of buyers. It was in fact the lightest implementation of a range of timber trailers in different weight classes and for different purposes. The characteristics: inner dimensions 118.5 x 88.5 x 39.5 cm, weight 60 kg, a total weight of 400 kg, 8 inch wheels. Light metal profiles with plywood sheets (depending on the year of manufacture "nature", or "mahogany" pickled), the bottom is of 12 mm plywood. Steel or aluminum support bracket to the rear to make it possible to put the trailer upright path, and the wheels can be folded in one piece, by loosening the bolts of the celastoveren. There was a whole list of accessories. Standard was an open trailer without rear door (which there was little heavier types). A tarp was available as a simple conclusion. Better was a lid lock, hinged on one side and removable. This could optionally be provided with a railing (up to ca.1974) or a roof rack (after), and even of a holder for a boat (canoe?). For those who wanted to carry bigger things, there was a tilt available. Because these fans are mostly built in the 70s (production period around 1966 to 1981), they fit perfectly behind a panorama or a beetle. Type tilt not only space big advantage, but you can see the trailer on the rear of your bus; lower versions not!
Of all the supporters this is the most popular in (for example) VW Bus owners. This is evidenced among other things, from the Westfalia Register.
t3kg wrote: |
1964 1500 S
zuggbug Samba Member
Joined: June 17, 2008 Posts: 3479 Location: Anderson SC
Posted: Tue Nov 14, 2017 1:39 pm Post subject: Re: All things Essen - Westfalia Trailers |
Just picked this up at Bulli Brigade, cant wait to dive into it.
I need some shocks and its missing one button on the side.
_________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
