tjet Samba Member
Posted: Mon Jun 22, 2015 5:07 pm Post subject: Product review: The Club Twin Hook steering lock, model 3010 |
This is a quick review of The Club Twin Hook Steering Wheel Lock, Model 3010 (red).
Long story short, I've finally pieced together a rusty non-running Syncro I bought last year. It can be best described as a rolling storage unit for used 4wd parts.
So a few weeks ago I finally got it running & I've been driving it to shake it down & fix the bugs
Anyway, being mainly consumed about getting this thing to run, I never really considered about fixing the door locks (the key is missing). Last weekend I drove it to the store to pickup a few things & I parked it near the front of the parking lot. I didn't bother rolling up the windows as I can't even lock the door...
When I came out, another car was parked right next to it with 2 guys in it, & another walking around my van. It seemed like they were just checking it out, but when I approached the one guy got really surprised & started saying "oh...this is yours??" I said hello & told him I just got it running. He mentioned something random about a similar Ford van while the car next to my van drove off.
I left the store & I started thinking about the strange situation that just happened. Even though they probably weren't going to steal it, it got me thinking how easy it would be...
So I figured I needed a least 1 piece of security for it. I went online to check prices on The Club & found that they have a newer style twin fork design. Now I realize that a pro can remove these in 10 seconds, I figured it's better than nothing (& my steering wheel doesn't lock either).
I have to say that this twin fork design looks like it was made to fit a vanagon. Just take a look. I think it would take a lot of steering wheel cuts to remove it.
Another plus is that these come in handy if you need to jam the gas pedal to get a high idle or the brake pedal to check the lights.
For $30, A+ in my book
http://www.theclub.com/
leathersmyth Samba Member
Joined: September 23, 2012 Posts: 122 Location: Calgary,Alberta
Posted: Mon Jun 22, 2015 5:55 pm Post subject: |
They can deter some people, But This weekend i wired in a kill switch off the ground of fuel pump, so when switched off cant start van because no fuel........
So little more piece of mind than the club..... |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10357 Location: N. Idaho
Posted: Mon Jun 22, 2015 6:37 pm Post subject: |
I use a club even when parked in my driveway, and when we travel and leave it for dinner or a hike it gets put on. These things are way too easy to steal, and to me the emotional value is the highest of any vehicle I own. A pro can get one off, but to me the convenience (8 seconds to install as I leave, similar to remove when I slide back in) is worth enough deterrence to make 99% of folks with bad intentions move along to another vehicle.
DougM _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1993 Toyota LandCruiser, 2002 BMW 325iX, 1982 Toyota Sunrader |
tjet Samba Member
Posted: Mon Jun 22, 2015 6:51 pm Post subject: |
Yeah the new type goes on real quick & it automatically locks when it's deployed.
The cool thing about this particular model vs the original club, is that the standard removal method (cut the wheel) wont work as long as it's installed as per the photo |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12397 Location: Santa Cruz, CA
Posted: Mon Jun 22, 2015 6:55 pm Post subject: |
| Would it stop someone from unbolting the steering wheel? |
tjet Samba Member
Posted: Mon Jun 22, 2015 7:29 pm Post subject: |
Probably not, but thx for bringing that up. Will order some tamper proof HW from mcmaster carr
Do you know the bolt size? |
Posted: Mon Jun 22, 2015 7:34 pm Post subject: |
| It is a single nut that comes off with a 24mm socket. Looks like it would be relatively easily removed with that in place. |
vanis13 Samba Member
Joined: August 15, 2010 Posts: 4573 Location: ABQ NM USA.... Except when not
Posted: Mon Jun 22, 2015 7:43 pm Post subject: |
then they would have to bring their own replacement steering wheel or steer with some vicegrips. now that would be some planning. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
Posted: Mon Jun 22, 2015 7:51 pm Post subject: |
I have seen that done.  |
tjet Samba Member
Posted: Mon Jun 22, 2015 7:54 pm Post subject: |
| & the steering wheel comes off without a puller? yikes |
Posted: Mon Jun 22, 2015 7:56 pm Post subject: |
| Yes, you pull on either side hard a few times and it pops loose. I have done that many times on different vans without issue. |
tjet Samba Member
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6933 Location: Fort Lauderdale, Fl.
Posted: Tue Jun 23, 2015 12:24 am Post subject: |
Yeah...it works, but so does a 20v Dewalt battery operated grinding/cutoff tool with a 6" carborundum cutting disc.
Makes noise, but so do the alarms system you hear driving off...
Still prefer the stealth fuel cutoff switch.
Seeing it in the window would definitely deter the average lowlife.
Is there enough room under the cross bar to get the horn pad off to get to the wheel nut?
What brand of radio is that in your dash? Looks interesting.
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Tue Jun 23, 2015 5:09 am Post subject: Re: Product review: The Club Twin Hook steering lock, model |
| tjet wrote: |
| This is a quick review of The Club Twin Hook Steering Wheel Lock, Model 3010 (red). |
I bought one of these last year (a yellow one) and was happy with it, but the lock stopped working after a few months. _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
greggearhead Samba Member
Joined: June 20, 2004 Posts: 579 Location: Colorado Springs, CO
Posted: Tue Jun 23, 2015 8:52 am Post subject: |
| syncrodoka wrote: |
This is my problem with using them. It might be fixed by welding a plate over the center area? Don't know the metal used in the club, though.
I think as Doug mentions, the point is that someone glancing in with bad intentions will see it right away, and likely think that there may be other anti-theft measures as well, and move on. That's the benefit that makes me reconsider these. _________________ 1972 Porsche 911E Hot Rod (3.4 Turbo)
1973 VW 412
1979 Audi Fox GTI
2002 Eurovan
Period Lights, VW & Porsche wheels and Recaro/Scheel Seats for sale
https://www.facebook.com/greggearhead
http://greggearhead.com/soco-swap---september-vw-swap-meet.html |
tjet Samba Member
Posted: Tue Jun 23, 2015 4:40 pm Post subject: |
What I like about it is that it's fast & easy to install.
Ultimately, it's only a slow down device. A kill switch is a better idea. I still need to install the battery disconnect. I picked up this one, It has a removable key...
http://www.rallylights.com/hl87181-battery-master-...d-key.html
| Mellow Yellow 74 wrote: |
| tjet wrote: |
I bought one of these last year (a yellow one) and was happy with it, but the lock stopped working after a few months. |
You should contact the manf. Maybe they will fix it free |
GypsyDriver Samba Member
Joined: November 06, 2012 Posts: 190 Location: Columbus, GA
Posted: Tue Jun 23, 2015 5:01 pm Post subject: |
| This is the exact same model I use. Don't know if its deterred any would-be thieves, but I like it very much. My only minor issue is storing it. I put it down in the aisle when driving, but that doesn't feel very secure. |
RCB Samba Member
Joined: September 05, 2005 Posts: 4143 Location: San Francisco-Bay Area
Posted: Tue Jun 23, 2015 5:55 pm Post subject: |
| The Auto-Lock attaches to either the clutch or the brake pedal. Small enough to fit behind the drivers seat. |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3667 Location: Dartmouth, Mass.
tjet Samba Member
Posted: Thu Aug 04, 2016 1:50 pm Post subject: |
| GypsyDriver wrote: |
| ..... My only minor issue is storing it. I put it down in the aisle when driving, but that doesn't feel very secure. |
Here's where I stow away mine while driving. Very secure there & easy access.
