Sodo Samba Member
Joined: July 06, 2007 Posts: 9606 Location: Western WA
Posted: Wed Jun 24, 2015 8:31 am Post subject: Syncro transmission rebuild every 10-20k miles |
Need another Syncro tranny rebuild after 9,000 miles. I bought a pickup to use as a daily driver, to stop putting so many miles on the Syncro. But now planning a trip to Yellowstone, but the tranny is making more noise than I'd like to hear.
My tranny was rebuilt often:
104,000 (2004)
136,000 (2007)
147,000 (2009, added Subaru 2.5L & Peloquin)
165,000 (2011)
Now at 174,000 (2015), its making that old familiar sound AGAIN …..
In neutral, (edit--->parked) clutch OUT it sounds like this:
WOW wow WOW WOW wow WOW WOW wow WOW WOW wow WOW
Inside the van, its kinda loud. With my head outside the window, the sound is considerably louder than the quiet Subaru engine.
All rebuilds have been by the same reputable shop (mentioned often here on TheSamba). They have been offering a little "assistance" due to the 3-yearsbetw rebuilds but the R&R COST is a lot. Any idea what's going on here, it's getting awful expensive and a hassle too.
Sometimes I tow a 400 lb motorcycle trailer with either 250-or 500 lbs of motorcycles. Because I'm tranny-challenged I sometimes crawl under and put my hand on the tranny - it's never hot when towing. _________________
....KTMs, GasGas, SPOT mtb
danfromsyr Samba Member
Posted: Wed Jun 24, 2015 9:51 am Post subject: |
and each time after a rebuild/refresh trans the wowowowowowo goes away for a little while?
else I may suspect a wheel bearing..
do you hold it in 4th gear on big hills/passes at low Rpms instead of dropping to 3rd and keep the revs up?
IMO this driving behavior puts more side load on the bearings while the rpms aren't slinging enough oil and the torque to side load pushes past the shear lubricity of the gear oil in the bearings.. YMMV of course.. _________________
Abscate wrote: |
zippyslug31 Samba Member
Joined: July 20, 2007 Posts: 799 Location: Central Oregon
Posted: Wed Jun 24, 2015 10:07 am Post subject: |
I don't understand this. I replaced my trans 12 or 13 years ago and around 100k miles with a rebuilt. No problems since.
The past few years are with a 2.5 Subi and 16" wheels, in case it matters.
If you are going through transmissions this often, you must have some other issue. _________________ previous:
'80 westy
current:
'90 syncro westy 2.5L subi, triple knob, 16" wheels.
'84 sunroof van, 2.1L motor. |
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Wed Jun 24, 2015 10:20 am Post subject: |
zippyslug31 wrote: |
If you are going through transmissions this often, you must have some other issue. |
^^ x2 An overly stiff VC comes to mind .. _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
Sodo Samba Member
Posted: Wed Jun 24, 2015 11:21 am Post subject: |
Thanks very much for your help & suggestions. I agree that there's possibly something else wrong, but WHAT?
What is a wowowowowow? I suspect a main or countershaft bearing.
danfromsyr wrote: |
and each time after a rebuild/refresh trans the wowowowowowo goes away for a little while? |
I'm more than a little embarrassed I can't remember the details,,,, but yeah it makes some kind of bearing noise. The wowwowow is my current indicator that there's a problem NOW.
danfromsyr wrote: |
else I may suspect a wheel bearing.. |
Makes the wowowowowow noise while stopped, idling, in neutral. Noise winds down to stop if I push the clutch.
danfromsyr wrote: |
do you hold it in 4th gear on big hills/passes at low Rpms instead of dropping to 3rd and keep the revs up? IMO this driving behavior puts more side load on the bearings while the rpms aren't slinging enough oil and the torque to side load pushes past the shear lubricity of the gear oil in the bearings.. YMMV of course.. |
I have a Smallcar install, bellhousing, 2007 2.5L iActive, it doesn't have much power if the RPMs pull down. Pretty much have to go to 3rd gear on hills, always, to keep up with traffic.
gears wrote: |
^^ x2 An overly stiff VC comes to mind .. |
VC is about 70k miles old, last tested at 120k when I bought the van. It was unable to climb a 2x4 at idle. Climbed up if I raised rpms a little. Turning sharp, the tires don't scrub much (on gravel). My pickup scrubs, but what I scrubbing hear from the Syncro does not suggest it's locked up, not much different than a 2wd. Probably time for a re-test. _________________
gears Samba Member
Posted: Wed Jun 24, 2015 11:30 am Post subject: |
It sounds like the VC isn't the problem. But without knowing specifically which parts are failing, requiring all these rebuilds, we're just wild guessing. _________________ aka Pablo, Geary
'87 Syncro GL 2.5
davevickery Samba Member
Joined: July 16, 2005 Posts: 2887 Location: Fort Collins, CO
Posted: Wed Jun 24, 2015 11:51 am Post subject: Re: Syncro transmission rebuild every 10-20k miles |
Sodo wrote: |
So you are in neutral, clutch out and not moving, why would that be a transmission noise? |
FrankenSubySyncro Samba Member
Joined: May 03, 2007 Posts: 638 Location: Vancouver, WA.
Posted: Wed Jun 24, 2015 11:52 am Post subject: |
Does it make the noise while moving and when parked?
I had that on a 2wd trans. Replaced main shaft bearing and it went away.
The MS bearing bore may be loose since this keeps happening. On my syncro, I switched to the aluminum case (can also sleeve the stock bore) that holds the MS bearing. I also did the tranny cooler using gears internal mods so oil is delivered to both sides of the MS bearing. You may want the cooler if you continue to tow.
http://www.thesamba.com/vw/forum/viewtopic.php?t=568039&highlight=syncro+trans+rebuild _________________ Syncronize it!
1987 Franken Syncro (converted 2WD auto)
2004 2.5 SOHC Subaru
F & R lockers, decoupler, SS, 6.17 R&P
Trans Cooler
EMPI race prepped 930 CVs and axles
Bilstein coilover front, rear ProComp MX-6066R shocks, 14" hypercoil springs
30x9.5 15" BFG Muds
Custom skid plates
Nose job (custom front bumper) http://www.flickr.com/photos/subyvanagon/sets/72157624970330925/ |
Merian Samba Member
Posted: Wed Jun 24, 2015 11:56 am Post subject: |
maybe your tranny wasn't really rebuilt?
DIY?
if not did you have them save all old parts and what did your inspection show?
often people only replace certain parts, leaving others with minute, but damaging, wear or they do not properly and accurately check the tolerances
I dunno re the syncro trans. but that is true of baulk ring pooschey boxes |
Posted: Wed Jun 24, 2015 12:11 pm Post subject: |
Sodo wrote: |
VC is about 70k miles old, last tested at 120k when I bought the van. It was unable to climb a 2x4 at idle. Climbed up if I raised rpms a little. Turning sharp, the tires don't scrub much (on gravel). My pickup scrubs, but what I scrubbing hear from the Syncro does not suggest it's locked up, not much different than a 2wd. Probably time for a re-test. |
I should have mentioned that I have a driveline decoupler, so my VC isn't really a factor in my comparison. So, perhaps this is the problem with your van and worth taking another look at? _________________ previous:
'80 westy
current:
Sodo Samba Member
Posted: Wed Jun 24, 2015 1:28 pm Post subject: Re: Syncro transmission rebuild every 10-20k miles |
davevickery wrote: |
Sodo wrote: |
If I "coast" the wowowows align with vehicle speed. And it emanates from the tranny area. And due to repeated past experience I become pessimistic about my tranny.
Rebuilder is well known. They are looking into their notes but since it is over so many years I dont know what they will offer. I understand the years thing, they have to protect themselves, but Warrantys havent helped me as I pass the time but don't run it many miles. _________________
....KTMs, GasGas, SPOT mtb |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6829 Location: Fort Lauderdale, Fl.
Posted: Wed Jun 24, 2015 1:41 pm Post subject: |
if your dead nuts sure it is the tranny and your going to rebuild it again...buy a different tranny. |
iltis74 Samba Member
Joined: November 20, 2003 Posts: 826 Location: Anchorage, AK
Posted: Wed Jun 24, 2015 3:10 pm Post subject: |
Any chance it could be the release bearing? If it's not fully releasing I would imagine it's life would be dramatically shortened. Pressure on it could settle it down for a while. May not fit the coasting bit but something to keep in mind. _________________ 65 Beetle
74 Thing
87 Syncro |
insyncro Banned
Posted: Wed Jun 24, 2015 3:18 pm Post subject: |
That many rebuilds doesn't sound like any fun at all. |
Sodo Samba Member
Posted: Wed Jun 24, 2015 4:19 pm Post subject: |
Yesterday when I started it and heard "the wowowowow", had been sitting for several months. I drove it around today and the sound "went away", which is only mildly comforting.
I'm thinking of feeding it the best oil I can find. I know this is a risky question in this day and age but is there an extreme gear lubricant? I have been using Redline MT90 but at the last rebuild gave up on it when the installer asked what was making me think MT90 was doing any good. He filled it with garden variety 90w he had in stock.
Thinking about Swepco 201 or 210. This will cost $90 on eBay.
Are there "tranny or differential additives" such as moly lubes that are effective? _________________
Howesight Samba Member
Joined: July 02, 2008 Posts: 3274 Location: Vancouver, B.C.
Posted: Wed Jun 24, 2015 4:29 pm Post subject: |
Darryl recommended to me that I use Swepco 210 after he rebuilt my syncro transaxle. This product has greater EP protection than the Swepco 201. For what it is worth, the Porsche guys (both street and race) have been singing the praises of the Swepco products for a very long time (30 years or so).
Darryl advised that as long as I was very easy on the power and load, it was acceptable to use standard MT90 for the first 500 miles during which the new bearings, and new Weddle 3rd and 4th gears would bed in, then drain the MT90 and associated swarf and fill with Swepco 210.
So far, so good. _________________ '86 Syncro Westy SVX |
Posted: Wed Jun 24, 2015 10:37 pm Post subject: |
Check Amazon's prices on the Swepco. |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Thu Jun 25, 2015 8:49 am Post subject: |
Howesight wrote: |
So far, so good. |
Ditto. I bought a five gallon pail of 210 because Darryl said I should use it.
Good enough for me. _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
Syncro Jael Samba Member
Posted: Thu Jun 25, 2015 12:37 pm Post subject: |
When the last tranny went out on my Syncro it was the main bearing. At first it would only make the noise under a load. Then you could hear it when cold and would lessen when warmed up.
Did you drop the tranny gear oil and take a look for "Unicorn Blood" or magnesium from the case?
When I rebuilt mine last I purchased all new aluminum housings, the main bearing retainer plate, oiling plates, and added a decoupler. I double checked flange angles, added new CV joints and a new driveshaft. I believe the vibration caused by the drivetrain and running in 90° temps for hours at freeway speeds without monitoring the transaxle temp, contributed to my transaxle failure.
Possibly your EJ25, pulling a trailer, and or driving habits could be stressing your transaxle enough for the premature failures?
When it was rebuilt before, what was wrong each time?
Here are a couple clips of a tranny main bearing failure in action and the "Unicorn Blood".
_________________ 1987 Syncro Westfalia Hightop - NAHT
Subaru EJ25 Forged Frankenmotor, Triple Knob.
Jael = (Mountain Goat) |
Sodo Samba Member
Posted: Sat Jul 04, 2015 9:37 am Post subject: |
I am going to drain my tranny fluid and have a look at it. Should I drain it HOT or cold? _________________
