Honuak Samba Member
Posted: Tue Jul 07, 2015 10:17 am Post subject: Subaru VSS solution and a queston |
I finally got a fix for the absent VSS on my subaru vanagon. I can recommend enginewiring.com. The guy was really helpful and the install was as simple as spicing into the VSS wire, ignition power and a ground. At the same time I grounded wires to insure the ECU was set up as manual trans and grounded the body of the ECU as recommend by enginewiring.com. The part itself is really small, about the size of the end of a sharpie cap. It seems to run fine now even thought there are still a few codes on the ECU. When I clear said codes it doesn't seem to change the way it runs, as opposed to before when it would go into limp mode, high idle etc. But while I was installing the VSS I noticed this.
Anyone know what the burned out/melted resistor is?
SAMBA! |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Tue Jul 07, 2015 10:58 am Post subject: Re: Subaru VSS solution and a queston |
Honuak wrote: |
SAMBA! |
That's your Small Car code board. You could try asking them... _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
Honuak Samba Member
Posted: Tue Jul 07, 2015 11:39 am Post subject: |
Perfect!
Ordered a new one. And it looks like this will solve all the code issues. Looking forward to seeing if my MPG improves... |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12006 Location: Santa Cruz, CA
Posted: Tue Jul 07, 2015 3:38 pm Post subject: |
I had their dummy constant speed VSS. Meh
I prefer the speedo mounted style that actually gives it the correct input like fastforward.ca sells. |
Honuak Samba Member
Posted: Tue Jul 07, 2015 3:52 pm Post subject: |
syncrodoka wrote: |
So...what is the advantage?
My van has/had operational cruise control at one point, not working now and I'm not sure why. Unrelated to the recent VSS fix.
Is the speedo mounted version GW sells comparable to fastforward one? Difficulty of installation? |
wesitarz Samba Member
Joined: August 20, 2012 Posts: 1491 Location: Victoria,B.C.Canada
Posted: Tue Jul 07, 2015 4:21 pm Post subject: |
red/blue wire is for fan relay if that's what the resistor connects to.
yellow/blue is ign
You could just replace the resistor if handy with a soldering iron. |
kalispell365 Samba Member
Posted: Tue Jul 07, 2015 5:06 pm Post subject: |
syncrodoka wrote: |
I agree, My ecu like actual speed variances vs. this, I used to have it as well. The Go Westy one and the Fast Forward one work identical, however the Fast Forward one is nicer quality...the price reflects it. The FF one has a pulse flashing LED which shows it is working, which I like so it was worth the extra to me.... _________________ 1983 Diesel Vanagon Westfalia chassis with Subaru 2.2l |
