EMPI Camber Compensator Parts
ataraxia
ataraxia is offline
PostPosted: Fri Jul 03, 2015 6:54 pm    Post subject: EMPI Camber Compensator Parts Reply with quote
I'm looking for the center bushing (indicated by red arrow) for an EMPI camber compensator
OR
Someone who can repop them using my NOS piece as a template.
Anyone know where they can be found? I've got two of these compensators and only one center bushing.
ataraxia
ataraxia is offline
PostPosted: Thu Jul 09, 2015 5:02 pm    Post subject: Reply with quote
Are there just not that many of these out there anymore?
Multi69s
Multi69s is offline
PostPosted: Thu Jul 09, 2015 6:45 pm    Post subject: Reply with quote
What is the bushing made out of? I might be able to reproduce it.
69 road Bug 2110
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
73 Squareback - 2L, T4, Automatic W/ AC
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback
ataraxia
ataraxia is offline
PostPosted: Thu Jul 09, 2015 7:01 pm    Post subject: Reply with quote
It's made of rubber and has an internal threaded piece in the center.
I'll post up photos and dimensions when I get home on Saturday.
t3kg
t3kg is offline
PostPosted: Thu Jul 09, 2015 10:38 pm    Post subject: Reply with quote
Is Eric Outland ([email protected]) still selling camber compensator parts? Maybe he would have it, or know a source.
I WAS THERE! The 2017 Type 3 Rally / September 29–October 1 / Cayucos, CA
2014: The 2014 Type 3 Rally / October 3–5 / Cayucos, CA
2011: 50 Years of the VW Type 3 / September 29–October 1 / California Central Coast
PostPosted: Thu Jul 09, 2015 10:56 pm    Post subject: Reply with quote
I made mine from a rubber plug from the hardware store:
One concern is that I don't know if the rubber is the correct hardness.
KTPhil Premium Member
KTPhil is offline
PostPosted: Thu Jul 09, 2015 10:58 pm    Post subject: Reply with quote
It appears the threaded insert (embedded in the rubber) is used in the design so that you can back out bolt "C" to remove it, thus allowing you to drain the oil by removing just the one bolt.
If you substituted a simple bolt/rubber bushing/washer/locknut assembly instead, you could probably use any old rubber/urethane hunk, drilled and cut to fit.
You might then have to remove the crossbar to get drain plug access, but how often do you need to do that? The fill plug is removed more often to check the level; the drain plug, not so much.
ataraxia
ataraxia is offline
PostPosted: Fri Jul 10, 2015 7:45 am    Post subject: Reply with quote
That's his name! I couldn't remember...last time I contacted him about the straps a while back he didn't have them and seemed to be winding down. I'll contact him and see if he's got a source.
Thanks.
This will be the route I'll take if I can't find a proper piece. I went to Lowe's and had a look around at my options.
ataraxia
ataraxia is offline
PostPosted: Fri Jul 10, 2015 7:49 pm    Post subject: Reply with quote
Roughly 36mm in diameter, 17mm thick
Looks like a real thick washer/spacer with an internal thread.
M6x30 is what I have for a fastener. The instructions I scanned show a hex head cap screw but I have a round cap screw with a screwdriver slot.
This hole is 9mm in diameter:
If you look REALLY closely, you can see the seat for this thing. It's about 1mm - although I'm sure that grows in size as it's compressed.
PostPosted: Fri Jul 10, 2015 11:15 pm    Post subject: Reply with quote
ataraxia wrote:
The instructions I scanned show a hex ead cap screw but I have a round cap screw with a screwdriver slot.
My original had that same screw too.
ataraxia
ataraxia is offline
PostPosted: Sat Jul 11, 2015 6:57 am    Post subject: Reply with quote
I have another question:
How long is the bar supposed to be?
My NOS camber compensator is rougly 31" long. The other one, which looked to be original, is closer to 34" long.
Did EMPI make different length compensator bars?
PostPosted: Sat Jul 11, 2015 8:59 am    Post subject: Reply with quote
From this thread
I have an original here and the length of the bar is approximately 35.5" from eye to eye.
blackdog1999 wrote:
There are many differences. Split case trans uses a completely different center bracket (smaller) that will not work on a tunnel trans & vise versa. There were also atleast 4 different widths. Early Bus (1963 & older). Late Bus (1964-67). Short axle Bug/Ghia. Long axle Bug/Ghia. There was also a completely different center bracket for Type 3 in the later production runs.
I don't know what lengths are for what vehicle in his list above.
ataraxia
ataraxia is offline
PostPosted: Sat Jul 11, 2015 10:41 am    Post subject: Reply with quote
So my short one is probably for a Type 1...well, that sucks.
I noticed that he said that the Bus version was 37" long.
Thanks for posting up the information.
Bobnotch
Bobnotch is offline
PostPosted: Sat Jul 11, 2015 11:39 am    Post subject: Reply with quote
Th 31 inch one is probably for a short axle bug or ghia up thru 65.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
ataraxia
ataraxia is offline
PostPosted: Sat Jul 11, 2015 11:46 am    Post subject: Reply with quote
Yeah, that was my guess...looks like it'll be up for sale soon! Rolling Eyes
turbomicrowaves
turbomicrowaves is offline
PostPosted: Sun Jul 12, 2015 11:14 am    Post subject: Reply with quote
I recently picked this Camber Compensator up at a swap meet. I hadn't even considered that different models would require different compensators, I just assumed they were all the same. It does have a patent number stamped on it that matches the EMPI versions, but doesn't have any other identifying marks on it. Also, it measures out to just under 37".
'68 Sunroof Squareback
"There are no pieces"
OCT3 - Orange County Type 3's
ataraxia
ataraxia is offline
PostPosted: Sun Jul 12, 2015 11:30 am    Post subject: Reply with quote
I recently learned this myself when I brought my recently powder coated bar back to compare with the NOS unit I bought a few months ago. I never really thought that it would be shorter than the one I was restoring.
turbomicrowaves
PostPosted: Sun Jul 12, 2015 11:41 am    Post subject: Reply with quote
The version you have mounts to the frame horns, correct?
ataraxia
ataraxia is offline
PostPosted: Sun Jul 12, 2015 11:42 am    Post subject: Reply with quote
Correct. But the bar that spans the axles should be the same design.
t3kg
t3kg is offline
PostPosted: Sun Jul 12, 2015 1:15 pm    Post subject: Reply with quote
I never knew about the different lengths either. I'd like to submit my application for membership to the short axle club. The NOS compensator I have is 31 in. wide.
Hmmm....widened wide 5 steelies on short axles...? Twisted Evil
