joescoolcustoms Samba Member
Posted: Mon Jun 29, 2015 8:48 am Post subject: |
Pete at AirKewld is a top notch supplier. I enjoy each time I order from him and know he will back me up if I stumble.
Also, love the detail! Man after my own heart. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Airkewld Samba Member
Joined: November 14, 2003 Posts: 3152 Location: Goodyear, AZ USA
TSFR Samba Member
Joined: May 14, 2013 Posts: 365 Location: Columbia, SC
Posted: Mon Jun 29, 2015 10:11 am Post subject: Re: Small Update |
Airkewld wrote: |
Thanks for the kind words my friend! The build is coming together nicely! |
The next picture you see of the beam (god willing) it will be completely assembled spindle to spindle. I hope to make you proud Pete! _________________
Thanks,
Jeff
Manxter 2+2 #160 |
dbsmith Samba Member
Posted: Tue Jun 30, 2015 3:53 pm Post subject: |
What kind of paint did you use from the LPS. .?
That seems to be my biggest downfall is the final paint. I can fabricate, prep, sandblast, but when it comes to final shooting, can't seem to pick the correct topcoat.
You had a thread about the registration. I got the donor registered before I tore it apart. So it's a 69' vw. If I ever finish I'll see about going to a special construction. So just take your numbers and weld it to the pan and don't worry too much till it's a running down the road.
David _________________ dbsmith
SoCal
#127 Manxter - 99.5% done.... |
TSFR Samba Member
Posted: Wed Jul 01, 2015 6:27 am Post subject: |
I'm pretty sure is was Dupli-Color Cast Iron Gray Engine Enamel and Dupli-Color Clear Engine Enamel to shine it up. We just followed the directions. As with everything prep is key. I cleaned everything up with a wire wheel, sprayed it down with brake cleaner because we didn't have any paint thinner handy, handled with paper towels from then on, suspended at a good height and then painted from 1 direction, waited, painted from another direction, waited, painted a little heavier all over, waited and then repeated with the clear. The clear says to apply with in 1 hour of the paint. The we went to have lunch and when we came back we put them in the sun to finish "baking". They came out pretty good and I'm happy for something that will most likely be overlooked.
I'm pretty sure that I'm just going to bite the bullet and move forward with the Homebuilt Special Registration Kit Car thing. My 72 donor chassis with title will be going up for sale soon. _________________
Thanks,
Jeff
Manxter 2+2 #160 |
TSFR Samba Member
Posted: Mon Jul 06, 2015 5:04 am Post subject: |
Independence Day Weekend Progress: Steering Box refurbification
I took the steering box apart and cleaned all the old grease/grime out. While apart, I figured it would be a good time for some beautification as well. Honestly, that was always the plan LOL. I wire wheeled everything I could and repainted. I only cleared the bolts so there would be some contrast.
Once I get some John Deere Cornhead Grease (yes it's a real thing LOL) I will clean up the inside edges of any overspray and get it buttoned up. I also repainted the Tie-Rods. I already have new Tie-Rod ends and my new ball joints should be in this week. I'm hopeful the front end will be assembled this weekend, but with a car show/drag night happening it seems a little unlikely. It's all good though and should be another great event. _________________
Thanks,
Jeff
Manxter 2+2 #160 |
jrailer Samba Member
Posted: Mon Jul 06, 2015 11:19 am Post subject: |
looking good Jeff |
TSFR Samba Member
Posted: Mon Jul 06, 2015 12:00 pm Post subject: |
Operation Corn Head Grease was a success!
Thanks,
Jeff
Manxter 2+2 #160 |
Buggy Brian Samba Member
Joined: October 26, 2006 Posts: 308 Location: Yulee, FL
Posted: Tue Jul 07, 2015 5:13 am Post subject: |
Looking good!! I think I may have you go ahead and clean and paint those wheels for me. You're getting to be a pro, so it should be simple. Right? _________________ -(Loretta) Manx # M2940D910E on customized 1970 chassis by Joescoolcustoms
-(Scarlett) Manx Resorter #12 (R0012B931S) on 1969 chassis.
-Original Home built buggy that started all. I learned to drive in it back in 1985.
Manx Club Member # 4436
Check out my Loretta here: http://www.manxclub.com/forum/viewtopic.php?f=65&t=3365Manx
Scarlett is getting a Makeover! http://manxclub.com/forum/viewtopic.php?f=82&t=3745&p=24983#p24983 |
TSFR Samba Member
Posted: Mon Jul 13, 2015 8:08 am Post subject: Front Wheels Down |
Progress for this week…I blew off a car show so I could work on my front beam assembly, that and it was literally 100º with no wind and it sounded like a better idea to be in a shaded garage. I saw pictures and it looked like everyone had a great time and there were lots of nice rides.
Airkewld Front Beam is still sexy, but like any fine lady can be a little temperamental! LOL As I started installing the torsion leaves and thinking this through (probably the bulk of my problem) it appears that I’m only getting lift out of the beam instead of a drop. With my drop spindles, that isn’t really a problem though so it seems like everything is going to work out in that regard. It has me scratching my head a little, but if nothing else will help me out on the beach!
With Brian’s help (Thanks Boo!) we were able to test fit the beam into place and it literally fits like a glove! It’s like the David Barrett Chassis was made around this beam. Now this is only a test fit and things still need to be greased and the control arms touched up from pressing in the ball joints, but so far so good! Enough yappin, and I’m surprised if you’re still reading this LOL
I’m not so sure about the body lift anymore after looking at where its sits now. I think I’m going to drop the floor pans under the seats a little instead because there is already more wheel well gap than I was wanting. With a body lift, the chassis would be dragging the ground to take up enough wheel well gap space. As it is, I may just need to step up the front tire size a little. But that’s so far down the road and still need to see what it looks like settled with a full tank of fuel. As it sits, the front beam is just over 6.5” off the ground if I remember correctly but that value is subject to change.
This is likely the stopping point for any major construction for a while until I 100% decide what rear torsion I’m using and get the SubaruGears engine/transmission mounts in my hands. This will buy me enough time to think it through and change my mind 14,000 times only to probably do what I was going to in the first place. A budget has a funny way of doing that LOL _________________
Thanks,
Jeff
Manxter 2+2 #160 |
Posted: Mon Jul 13, 2015 5:55 pm Post subject: |
That beam looks better in person that in the pictures. It is super sexy! But Jeff, the next time you call me Boo, I'm going to come over there and disassemble that damned thing! _________________ -(Loretta) Manx # M2940D910E on customized 1970 chassis by Joescoolcustoms
TSFR Samba Member
Posted: Tue Jul 14, 2015 6:43 am Post subject: |
Buggy Brian wrote: |
That beam looks better in person that in the pictures. It is super sexy! But Jeff, the next time you call me Boo, I'm going to come over there and disassemble that damned thing! |
Come on guy, LOL!!! You of all people know how heavy it is
In all seriousness, I truly appreciate the help my friend _________________
Thanks,
Jeff
Manxter 2+2 #160 |
Posted: Tue Jul 14, 2015 2:59 pm Post subject: |
TSFR wrote: |
In all seriousness, I truly appreciate the help my friend |
No problem Bro! _________________ -(Loretta) Manx # M2940D910E on customized 1970 chassis by Joescoolcustoms
AuburnGrad93 Samba Member
Joined: April 20, 2015 Posts: 63 Location: Ooltewah, TN & McDonough, GA
Posted: Fri Jul 17, 2015 11:11 am Post subject: |
Jeff, it's really looking good! I'm so jealous!! I'm still working on trying to remove the floor of my Frame Head!
PS: Hey Boo, (Snicker snicker!) I still have the 73 chassis for sale!!! _________________ Thanks,
Darren
Blaming a gun for crime is like blaming a fork for Rosie O'Donnell being FAT!
1969 Dune Buggy |
TSFR Samba Member
Posted: Thu Feb 18, 2016 12:21 pm Post subject: Re: Manxter 2+2 #160 |
So it was brought to my attention (Mr Pepper ) that I should really update my thread even if just a little. Well sadly there's not a lot of actual buggy progress so much as buggy part progress.
I've ordered the SubaruGears Reverse Ring and Pinion Kit, and begun the install.
For the most part that's about it, but look for updates in the summer. There will be a burst at that point, not completion but progress for sure.
Buggy on peeps! _________________
Thanks,
Jeff
Manxter 2+2 #160 |
TSFR Samba Member
Posted: Thu Feb 18, 2016 12:36 pm Post subject: Re: Manxter 2+2 #160 |
oh, seats.....I got some seats too.
The rear covers are just basically sitting on the shell and will get some extra foam and attention.
Thanks,
Jeff
Manxter 2+2 #160 |
63Fiberbuggy Samba Member
Posted: Fri Feb 19, 2016 2:16 pm Post subject: Re: Manxter 2+2 #160 |
Jeff, the seats look awesome! Sorry I had to "poke" a little to get an update posted, glad you did! 😎
Who's gonna finish your roll cage & what are you doing (powder/paint/chrome)? Also, offer still stands for me/Bill/Bob/etc to roll the 45 minute drive to Cola and help with assembly...and swill a few 🍻🍻👍🏻. |
hillmotorsports Samba Member
Joined: December 27, 2014 Posts: 432 Location: Morrisburg, Ontario, Canada
Posted: Fri Feb 19, 2016 2:49 pm Post subject: Re: Manxter 2+2 #160 |
Is that an aftermarket front end?
Who made that one? Who's sells it? _________________ Rosemarie and Paul Hill
Morrisburg, Ontario
(With way more projects than spare time!) |
