JohnnyDemonic Samba Member
Posted: Fri Jul 17, 2015 11:59 am Post subject: removing sliding track cover & where to buy new rubber s |
how the heck do you get this thing off? I've removed the 2 screws & it appears that it should just lift out, but it is stuck like chuck
also, where can i find new rubber gasket for this thing once I have removed it? I dont want to put the old one back as it is pretty crusty & brittle _________________ [url=http://www.vw-mplate.com/mplate2-23235.png]Click to view image[/URL] |
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Fri Jul 17, 2015 12:05 pm Post subject: |
Are you talking about the track cover along the belt line just behind the sliding door?
Yes, can be a bit tricky, but be careful with it. Sometimes they do get stuck. I use a block of wood (like a 2x4) and a rubber mallet. Start at the back, making sure you have cleared the tab that the screw goes through.
Once you get it loosened up a little, work your way forward. It should come out at an angle, with the rear end up first. When you get to the front, you will have to do a little sort of shimmy, bring it out at an angle combined with a little rear slide. You'll see.
Just be careful not to bend anything.
Once out, clean up that track really well. It may need some rust treatment and repaint. Check the nylon block on the slider for wear.
Both sides come out the same way, even though there is a door only on one side.
The rubber strips you are looking for are called welting. Various vendors have it. It's not expensive. _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
RunningRough Samba Member
Posted: Fri Jul 17, 2015 12:21 pm Post subject: Re: removing sliding track cover & where to buy new rubb |
JohnnyDemonic wrote: |
how the heck do you get this thing off? I've removed the 2 screws & it appears that it should just lift out, but it is stuck like chuck |
Do you have a Bentley? Definitely refer to it on this. I just took this off of my 1970 2 weekends ago. There are two larger screws to get, also a smaller screw that is a couple inches long. The philips head of this longer screw is accessible from inside the bus. There is also a tensioning strip that needs to be loosened before you start to hit the track cover. The track cover will not want to move until you take the tension off of the tensioning strip. _________________ 1970 Westfalia
Passenger Interior
Dual port Type 1
Solex 34 PICT-3
Flame Thrower Dist, Vacuum Advance
1982 Vanagon Diesel L
Diesel engine replaced with 1984 VW Golf engine |
Posted: Fri Jul 17, 2015 12:29 pm Post subject: |
jtauxe wrote: |
The rubber strips you are looking for are called welting. Various vendors have it. It's not expensive. |
thanks for this info! I'll give it a whack when i get home! _________________ [url=http://www.vw-mplate.com/mplate2-23235.png]Click to view image[/URL] |
Tcash Samba Member
