Anyone else use GoWesty radiator baffles?
climber2377
climber2377 is offline
PostPosted: Mon Apr 14, 2014 7:09 pm    Post subject: Anyone else use GoWesty radiator baffles? Reply with quote
I installed a set today. It was easy enough and plastic is better than cardboard, but has anyone else been disappointed by them? It seemed that the pieces weren't made correctly and I even had to cut one to get it to fit. Also a hold down piece busted off when I bent it to fit the right way. Maybe because my westy has ac they were not an exact fit? Either way I think I would have made them shaped differently.
[email protected] 84 Westy 1.9 waterboxer > 2001 Legacy 2.5L sohc w/ subarugears 5MT Ty754
greenbrier62
greenbrier62 is offline
PostPosted: Mon Apr 14, 2014 7:12 pm    Post subject: I've got'em Reply with quote
I have a set too. I've only installed the lower piece, but will get to the sides once I'm done painting. As you mentioned, it looks easy enough with the grills off...I don't have a/c though...We'll see.
1987 Vanagon camper
2005 VW Passat TDI
1962 Chevy Greenbrier
climber2377
PostPosted: Mon Apr 14, 2014 7:34 pm    Post subject: Reply with quote
i slid them up from the lower grill section. i had both grills off. you need to use the little metal clip from the old ones so dont toss it out.
zipster48
zipster48 is offline
PostPosted: Mon Apr 14, 2014 8:26 pm    Post subject: Reply with quote
I just did this recently, had both grills off which made it much easier, also had to take out my spare to attach screws for the bottom piece. The sides had to be juggled around some but attached ok without anything breaking - definitely better than the old cardboard pieces on my 84 & no AC. I think go westy says they are made from recycled plastic
dkoesyncro
dkoesyncro is offline
PostPosted: Mon Apr 14, 2014 9:24 pm    Post subject: Reply with quote
I installed a set and a new radiator, the GW fer-rings are built well of a plastic material. The only down side is the way the upper tabs fit on my 86' they don't seat/fit well when forced to match the old mounting holes. Easy fix to over come and far superior to the card board type.
16CVs Premium Member
16CVs is offline
PostPosted: Tue Apr 15, 2014 5:54 am    Post subject: GW air directors Reply with quote
I recently installed a set. The fit was funky and they didn't sit as tight to the radiator as I thought they should. Once I bent the tab around and re fastened it ,they seemed to work fine way better then the almost nothing I had.
Stacy
Samba member # 14980
schoonerman
schoonerman is offline
PostPosted: Tue Apr 15, 2014 10:21 pm    Post subject: Reply with quote
I just installed a set, the bottom fitted well, but had trouble with the side's,
I fitted the edges with the old clips, but the angled foot I had to ty-wrap to secure, as I didn't have the screws and fastening pieces, otherwise they seem to work ok.
My old cardboard ones had disintegrated
87 Westy/Vanagon
climber2377
PostPosted: Wed Apr 16, 2014 3:03 am    Post subject: Reply with quote
Did anyone else snap the inner edge of the side pieces into the groove in the radiator? It seemed like that was where it wanted to go.
Gnarlodious Premium Member
Gnarlodious is offline
PostPosted: Sat Jul 11, 2015 4:56 pm    Post subject: More about these baffles Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?t=632252
http://www.thesamba.com/vw/forum/viewtopic.php?p=7746027
mbwesty
mbwesty is offline
PostPosted: Sat Jul 11, 2015 10:01 pm    Post subject: Reply with quote
Me...installed May 2013 as I was installing my set of stainless steel coolant pipes. I don't remember it was difficult getting them installed. Did they help? Probably some, but the new radiator and pipes I installed for sure did more...it's been one cool van since...
igarrett
igarrett is offline
PostPosted: Wed Jul 22, 2015 11:23 am    Post subject: Radiator Reply with quote
Anyone have any recommendations on which brand radiators are the best for Vanagons
I have a 85 1.9L Westy
Thanks
Merian
Merian is offline
PostPosted: Wed Jul 22, 2015 11:52 am    Post subject: Reply with quote
what did you do to the upper tabs to make them fit? cut them or what?
dkoesyncro
PostPosted: Wed Jul 22, 2015 12:29 pm    Post subject: Reply with quote
I will post a pic this evening, my memory bank tossed out the details LoL.
dkoesyncro
PostPosted: Wed Jul 22, 2015 6:14 pm    Post subject: Reply with quote
I made brackets for better hold
syncrodoka
syncrodoka is offline
PostPosted: Wed Jul 22, 2015 7:37 pm    Post subject: Reply with quote
dkoesyncro
PostPosted: Wed Jul 22, 2015 8:32 pm    Post subject: Reply with quote
Mario, has the correct install looks like he cut the fat from the bottom. Only down side is lacks the extra 4" of surface area and the deflected angle to draw the air in.... Very Happy
Altoona
Altoona is offline
PostPosted: Wed Jul 22, 2015 8:41 pm    Post subject: Reply with quote
It looks like you can easily install yours correctly. Just bend those tabs up and over the lip like syncrodoka did. I can't see any reason why you can't install yours like he did, other than perhaps you are missing the hardware.
camerobias
camerobias is offline
PostPosted: Wed Jul 22, 2015 9:06 pm    Post subject: Reply with quote
Just did it on my Aircooled van that I'm preparing for a motor swap.
Forthwithtx
Forthwithtx is offline
PostPosted: Thu Jul 23, 2015 5:12 am    Post subject: Reply with quote
My experience was that the upper fastening tabs did NOT line up with the existing holes without some serious contortions. So, I just drilled new holes and fastened them with sheet metal screws.
Cheers,
Karl
Merian
Merian is offline
PostPosted: Thu Jul 23, 2015 12:17 pm    Post subject: Reply with quote
My '86 doesn't have the yellow objects in the pics & they are not in the baffle kit I bought
where did you get them? - are they the brackets you made for a better hold?
