AKAvant Samba Member
Posted: Tue Jul 21, 2015 11:24 pm Post subject: 1pin to 4pin Coolant Temp Sensor Wiring for mTDI conversion |
I recently swapped a 1z into my 1982 diesel Vanagon using the mTDI injector pump from a 2000 VW LT van. Almost no new wiring was needed but I do need to figure out how to adapt the old single wire setup for the coolant temp sensor to the 4-pin sensor on the 1z. Anyone have any experience with this? I still haven't found a pin-out description for the 4-pin sensor.
Here's a video of the first drive sans exhaust.
http://vid305.photobucket.com/albums/nn213/Disher0...kgvcdv.mp4 _________________ 1981 Westy 2.0 P22 Weekender (Sold 9/2/13)
1982 Westy 1.6 diesel (Sold 10/1/14)
1999 Caravelle 2.5TDI Syncro
2003 California 2.5TDI Syncro |
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10509 Location: Sunshine Coast B.C.
Posted: Wed Jul 22, 2015 1:35 am Post subject: |
edited: It sounds like your coolant sensor has the temp gauge and ECU sensors built into one housing. Search 1.8T sensor pinout here? OR, google your engine block code and ECT diagrams? The 1z ECT plug will have a number at each pin that corresponds to the 1z Bentley diagram.
Determine which pair of ECT sensor pins you need, connect one to ground the other to your coolant gauge +
1982 diesel Vanagon Bentley diagram, (P97.38 ) shows a blue-yellow wire from the temp sensor to T3C (behind dash) to wire 6 at the T14 connector to cluster. This appears to be the + wire from the OEM sensor.
Double check this but this is what I see.
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN
Waldi Samba Member
Joined: February 28, 2014 Posts: 1752 Location: Germany
Posted: Wed Jul 22, 2015 5:42 am Post subject: |
http://www.motor-talk.de/forum/aktion/Attachment.html?attachmentId=719242
You have to put on pin 1 mass than you can connect on 3 the water temp gauge.
If it works than ok, if not try this on pin 2 and 4.
The other 2 pins should work same for glowing plugs.
If you want to connect your electric water pump, you need another sensor on the zylinder head. |
svenakela Samba Member
Posted: Wed Jul 22, 2015 3:43 pm Post subject: |
On the conversions I've made I have taken the coolant sensor from the old engine and made up a small adapter.
_________________ Vanagon mirror end caps |
Posted: Wed Jul 22, 2015 4:03 pm Post subject: |
Very nice, how did you do that? _________________ 1981 Westy 2.0 P22 Weekender (Sold 9/2/13)
?Waldo? Samba Member
Joined: February 22, 2006 Posts: 10124 Location: Where?
Posted: Wed Jul 22, 2015 4:16 pm Post subject: |
I imagine he used a lathe and tap. It's a really nice solution.
I've used the earlier I4 aluminum coolant flanges. I don't like the later plastic ones much. Some creativity is required for the aluminum ones due to the different attachment angle at the center of the head. _________________ I am a high-functioning autistic into VW diesels and Vanagons along with other things that are unrelated to this site. |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12177 Location: Port Manteau
Posted: Wed Jul 22, 2015 5:15 pm Post subject: |
| I can't remember diagnosing those old style coolant sensors, but don't they need to be grounded to the block? |
Posted: Wed Jul 22, 2015 9:35 pm Post subject: |
| svenakela wrote: |
nice.
could the OP use a 2.1 WBX 2 pin temp gauge sensor? It might be the same dimension as the 1z 4 pin sensor? I've read that other VW's use the same connector as 2.1 does. This would make wiring pretty easy.
(VW Gas I4)
VE7TBN |
rotaecho Samba Member
Posted: Tue Apr 26, 2016 8:03 pm Post subject: Re: 1pin to 4pin Coolant Temp Sensor Wiring for mTDI conversion |
I'm actually visiting this now on my AHU mTDI conversion. This is for trying to simplify the coolant wiring/sensor for the mTDI build.
The parts are ordered and I am trying to swap a 1.6na p/n 068121133M flange in place of the AHU 028121132A flange.
This would give me the simple coolant sensor setup than the bulky plastic monster the AHU has.
Also, I am trying to swap the AHU flange 028121145 (Flange With Glow Plug Mounting) with a 1.6na 068121145K one.
I'm not sure of the creativity tweak Andrew speaks of yet. I haven't mounted it on to see / visualize what he's talking about.
It just like him, I didn't like the plastic flanges of the AHU and how bulky they are. _________________ -Will
1982 Westfalia mTDI (50deg) aka Betsy Bertha
http://www.tdivanagons.com |
Waldi Samba Member
Posted: Wed Apr 27, 2016 2:35 am Post subject: Re: 1pin to 4pin Coolant Temp Sensor Wiring for mTDI conversion |
You can use the late AAZ 4 pin sensor.
There you have temp gauge and pre glow signal. |
Posted: Sat May 07, 2016 1:47 pm Post subject: |
That's slick! Do you have one to sell?
| svenakela wrote: |
Posted: Sat May 07, 2016 1:52 pm Post subject: Re: 1pin to 4pin Coolant Temp Sensor Wiring for mTDI conversion |
So, I have the AHU (used engine) next to the long-block I'm building up.
In the photo below is the 1.6na 068121133M flange against the AHU engine. It looks like it'd interferrier with the injector lines. What creativity did you use to get this to work for you Libby? Did you bend the injector lines?
I really like that adaptor made for the older style with the AHU 028121132A flange (which I found an aluminum version online of).
Thanks for any insight! _________________ -Will
Posted: Sat May 07, 2016 2:50 pm Post subject: Re: 1pin to 4pin Coolant Temp Sensor Wiring for mTDI conversion |
There isn't any interference with injection lines, but the new angle means that the bypass hose is too short. I added a coupler and an angled section of hose. _________________ I am a high-functioning autistic into VW diesels and Vanagons along with other things that are unrelated to this site. |
Posted: Sat May 07, 2016 3:05 pm Post subject: Re: 1pin to 4pin Coolant Temp Sensor Wiring for mTDI conversion |
Thanks Andrew,
It looked like it'd interferer with the IP lines, nice to know it wouldn't.
Nice tid-bit thanks!
| Andrew A. Libby wrote: |
| There isn't any interference with injection lines, but the new angle means that the bypass hose is too short. I added a coupler and an angled section of hose. |
Outback Kampers Samba Member
Joined: December 29, 2004 Posts: 2345 Location: Oregon Outback
Posted: Sun May 08, 2016 8:33 pm Post subject: Re: 1pin to 4pin Coolant Temp Sensor Wiring for mTDI conversion |
| Waldi wrote: |
One of the few times I totally agree with Waldi.
The AAZ sensor is accurate for the gauge + the glow plug relay. Why make it more difficult and expensive when the sensor does the job perfectly? _________________ Karl Mullendore
1990 Syncro 16" sunroof Reimo highroof conversion
1990 Westy Multivan 112i automatic
1992 LT31 Karmann Distance Wide 'La Tortuga'
2014 Touareg X TDI |
Posted: Sun May 08, 2016 9:04 pm Post subject: Re: 1pin to 4pin Coolant Temp Sensor Wiring for mTDI conversion |
forgive my ignorance here,
But in trying to duplicate the 1.6na glow plug setup for the mTDI AHU, I thought the glow-plug sensor was done off the end of the block with (p/n 068121145K) or similar from the 1.6na? Since the flange on the AHU (p/n 028121145) with the coolant glow-plugs aren't needed.
Would this just turn into another "additional" sensor where the late AAZ sensor in the AHU (028121132A) flange would handle both conditions (glow-plug / coolant temps) with that single sensor?
Thanks for the clarity, just trying to understand it.
| westyventures wrote: |
| Waldi wrote: |
The AAZ sensor is accurate for the gauge + the glow plug relay. Why make it more difficult and expensive when the sensor does the job perfectly? |
Posted: Sun May 08, 2016 9:32 pm Post subject: Re: 1pin to 4pin Coolant Temp Sensor Wiring for mTDI conversion |
| rotaecho wrote: |
The AAZ sensor is two sensors in one - for temp gauge and for glow relay. The original AHU sensor in this spot was for temp gauge and ECU temp sensor. The AHU end of cyl. head flange can just be used as-is, no worries with leaving the coolant plugs in place. _________________ Karl Mullendore
Posted: Sun May 08, 2016 9:44 pm Post subject: Re: 1pin to 4pin Coolant Temp Sensor Wiring for mTDI conversion |
Thanks. I also reread the URL Waldi posted. I'll revisit my coolant temp sensor idea. The later AAZ temp sensor (need to dig that p/n) may be the way to go for this. I can use the cylender head alone then. _________________ -Will
Posted: Sun May 08, 2016 9:50 pm Post subject: Re: 1pin to 4pin Coolant Temp Sensor Wiring for mTDI conversion |
Would the proper AAZ later coolant sensor p/n be: 357-919-501A ? _________________ -Will
Posted: Sun May 08, 2016 10:46 pm Post subject: Re: 1pin to 4pin Coolant Temp Sensor Wiring for mTDI conversion |
357 919 501
green ring _________________ Karl Mullendore
