ptspringer Samba Member
Posted: Thu Jul 23, 2015 4:18 am Post subject: How to adjust the brake stars on a 4 lug drum? |
I'm used to my 66 bug, but now have a 69 convertible also. The 66 has a 5 lug wheel/drum with a really nice inspection hole that can be used to tighten the stars when the brakes need adjusting. The 69, however, has no hole to adjust the brakes. Do you really have to remove the wheels & drums to adjust the brakes, or is there a secret to it that I don't know yet???
Paul |
Stuart Maingot Samba Member
Joined: December 13, 2009 Posts: 240 Location: Trinidad West Indies
Posted: Thu Jul 23, 2015 4:31 am Post subject: |
| There are holes in the backing plate that allow adjustment of the stars. You will need to get under the car to access them if you are not removing the wheels. A real pia compared to the earlier models as you described. |
67jason Samba Member
Joined: August 28, 2005 Posts: 4741 Location: behind my back feet - Pittsburg CA
Posted: Thu Jul 23, 2015 4:33 am Post subject: |
access the brake adjuster from the back side of the backing plate from under the car. _________________ 67 bug x3
67 ghia
64 bug |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33414 Location: Hot Arizona
Posted: Thu Jul 23, 2015 5:55 pm Post subject: |
Thank you all!
Should have thought to look behind the wheel, although I'm not especially fond of the spiders that tend to live there. |
OLD VW NUT Samba Member
Joined: February 23, 2011 Posts: 2776 Location: High Desert of Washington 98823
Posted: Thu Jul 23, 2015 6:37 pm Post subject: |
Drive it more. Spiders hate high winds - artificial or natural. _________________ 71 Ghia Coupe - stock body - no rust! Powered by a 2110 W/Dual HPMX 44's - Rancho Pro Street Transaxle - A/C by Gilmore
Other car - 2013 VW Golf TDI |
Joey Samba Member
Joined: August 12, 2005 Posts: 5376 Location: Nova Scotia - Canada
Posted: Fri Jul 24, 2015 8:27 am Post subject: |
On both my '74 bus and '79 bus I just drilled a 1/2" hole in the drum. I use to do it from the back but I found if the adjusting stars stick the backing plate just bends. _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 26230 Location: Olympia Wash Rinse & Repeat
theKbStockpiler Samba Member
Joined: July 07, 2012 Posts: 2316 Location: Rust Belt
Posted: Fri Jul 24, 2015 9:42 am Post subject: |
-Go to Harbor Freight and get a cheap set of alen keys that are on a keyring.
-Pick the biggest one that will still fit in the hole.
-Grind a flat blade screwdriver end on the short end the same way adjusting spoons are.
 _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask. |
Posted: Fri Jul 24, 2015 10:04 am Post subject: |
| Joey wrote: |
| On both my '74 bus and '79 bus I just drilled a 1/2" hole in the drum. I use to do it from the back but I found if the adjusting stars stick the backing plate just bends. |
Need more anti-seize to help with that. If adjusting star is that stuck hit with hammer and flat punch the bolt head of the adjuster to help unstick the threads and get it moving. _________________ In Stereo, Where Available! |
Cusser Samba Member
Posted: Fri Jul 24, 2015 11:48 am Post subject: |
| Eric&Barb wrote: |
| Need more anti-seize to help with that. If adjusting star is that stuck hit with hammer and flat punch the bolt head of the adjuster to help unstick the threads and get it moving. |
This. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
