How to adjust the brake stars on a 4 lug drum?
ptspringer
ptspringer is offline
PostPosted: Thu Jul 23, 2015 4:18 am    Post subject: How to adjust the brake stars on a 4 lug drum? Reply with quote
I'm used to my 66 bug, but now have a 69 convertible also. The 66 has a 5 lug wheel/drum with a really nice inspection hole that can be used to tighten the stars when the brakes need adjusting. The 69, however, has no hole to adjust the brakes. Do you really have to remove the wheels & drums to adjust the brakes, or is there a secret to it that I don't know yet???
Paul
Stuart Maingot
Stuart Maingot is offline
PostPosted: Thu Jul 23, 2015 4:31 am    Post subject: Reply with quote
There are holes in the backing plate that allow adjustment of the stars. You will need to get under the car to access them if you are not removing the wheels. A real pia compared to the earlier models as you described.
67jason
67jason is offline
PostPosted: Thu Jul 23, 2015 4:33 am    Post subject: Reply with quote
access the brake adjuster from the back side of the backing plate from under the car.
67 bug x3
67 ghia
64 bug
Cusser
Cusser is offline
PostPosted: Thu Jul 23, 2015 7:18 am    Post subject: Reply with quote
Easier on the 69 convertible than on the 1966.
ptspringer
PostPosted: Thu Jul 23, 2015 5:55 pm    Post subject: Reply with quote
Thank you all!
Should have thought to look behind the wheel, although I'm not especially fond of the spiders that tend to live there.
OLD VW NUT
OLD VW NUT is offline
PostPosted: Thu Jul 23, 2015 6:37 pm    Post subject: Reply with quote
Drive it more. Spiders hate high winds - artificial or natural.
71 Ghia Coupe - stock body - no rust! Powered by a 2110 W/Dual HPMX 44's - Rancho Pro Street Transaxle - A/C by Gilmore
Other car - 2013 VW Golf TDI
Joey
Joey is offline
PostPosted: Fri Jul 24, 2015 8:27 am    Post subject: Reply with quote
On both my '74 bus and '79 bus I just drilled a 1/2" hole in the drum. I use to do it from the back but I found if the adjusting stars stick the backing plate just bends.
Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle
Eric&Barb
Eric&Barb is offline
PostPosted: Fri Jul 24, 2015 9:33 am    Post subject: Reply with quote
You need to get this manual ASAP.
http://www.amazon.com/Volkswagen-Beetle-Karmann-Se...ice+manual
In Stereo, Where Available!
theKbStockpiler
theKbStockpiler is offline
PostPosted: Fri Jul 24, 2015 9:42 am    Post subject: Reply with quote
-Go to Harbor Freight and get a cheap set of alen keys that are on a keyring.
-Pick the biggest one that will still fit in the hole.
-Grind a flat blade screwdriver end on the short end the same way adjusting spoons are.
Very Happy
My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask.Smile
Eric&Barb
PostPosted: Fri Jul 24, 2015 10:04 am    Post subject: Reply with quote
Need more anti-seize to help with that. If adjusting star is that stuck hit with hammer and flat punch the bolt head of the adjuster to help unstick the threads and get it moving.
Cusser
Cusser is offline
PostPosted: Fri Jul 24, 2015 11:48 am    Post subject: Reply with quote
This.
