northband Samba Member
Joined: August 19, 2013 Posts: 166 Location: Defiance
Posted: Thu Aug 20, 2015 4:43 pm Post subject: Air intake options for EJ22 swap |
Now that I got my engine installed I'm struggling to get the Subaru airbox to fit. I have an '86 Westy GL so the a/c hoses are in the driver side rear engine cubby so the air box barely fits.
I'm considering getting the KEP intake but wondering how well it fits. I'm leaning towards a cone filter intake because it wouldn't have to be stashed anywhere.
Curious what some popular options are - maybe some pics as well.
Thanks! |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12177 Location: Port Manteau
Posted: Thu Aug 20, 2015 5:08 pm Post subject: |
Why don't you just post up a build thread focused on your van, and then all these individual sub-component questions can appear in one central location. _________________ Casey--
'89 Bluestar ALH
'01 Weekender --> full camper
NEAT, no ICE. |
davevickery Samba Member
Joined: July 16, 2005 Posts: 2887 Location: Fort Collins, CO
Posted: Thu Aug 20, 2015 5:43 pm Post subject: |
I think it is a good question. The KEP filter didn't seem to be at the level of OE quality you can find in the junkyard. Plus I'm surprised people haven't found a used alternative over buying something new.
When I was looking for a compact filter for a different conversion, I found a square 10x10x6 Nissan airbox with inlet on one end and outlet on the other. I think it was on an older Maxima.
I also found a tiny airbox from a Chrysler Dogde. It came on V6 Dynasty, LeBaron, and similar late 80s and early nineties cars.
Both of these fit into the D pillar but I think the smaller one might fit in line on firewall. You'd probably have make an intake adapter but they both looked promising so I grabbed them. I may try to fit one on my subie 2.5.
Nissan one:
Dodge one:
Size comparison:
kalispell365 Samba Member
Posted: Thu Aug 20, 2015 6:30 pm Post subject: |
That Nissan one pictured actually fits the factory Subaru air filter correctly(1990-94 Legacy), they are identical and interchange. Good choice, I think way back I researched that one and it also fit an older Sentra. A look on Ebay might confirm this. _________________ 1983 Diesel Vanagon Westfalia chassis with Subaru 2.2l |
Posted: Thu Aug 20, 2015 7:08 pm Post subject: |
| Oh, I forgot the most important part. I was looking for a paper filter air box because I don't like the reusable cone filters like K&N or similar. This isn't from a bad experience but reading up on them shows how critical it is to keep them oiled and to clean them -- way more often than I want to be bothered. The oil does a good job catching the dust but after not too long they are covered in dirt and oil and are very restrictive. If you ever road dirt bikes, you cleaned your air filter every couple rides and re-oiled it. And if you don't oil them, all that dust is going into your engine to give your cylinders a good sanding. |
Halifaxwesty Samba Member
Joined: October 21, 2012 Posts: 213 Location: Halifax, Nova Scotia, Canada
Posted: Thu Aug 20, 2015 7:25 pm Post subject: |
I have the cone shaped filter on my 2.2.
Looks nice and seems to work, but there is a loud "whirr" sound droning out of my driverside D pillar vent.
Its manageable, but noticable. _________________ 84 Westfalia Vanagon
2.2 RMW Conversion
Work in Progress
My first car was a 1968 VW Bug |
AKWesty Samba Member
Joined: April 12, 2014 Posts: 680 Location: Haines, Alaska
Posted: Thu Aug 20, 2015 7:55 pm Post subject: |
I have the Kennedy U shaped air box. It is quiet. I drove through a thunder storm and sucked up enough road mist to choke out the motor. I have since added a flexable hose extension that run up the D pillar to act as a snorkel.
I spent the money because of the quiet design Kennedy boasts. It works. _________________ 84' Westy 2wd
EJ22 - 4spd - Peloquin TBD
GW +1.5 Springs
215/70-16's
www.CatchTheKraken.com
"Never go to Alaska as a young man because you'll never be satisfied with any other place as long as you live." -John Muir |
termuehlen  Samba Member
Joined: May 02, 2012 Posts: 1036 Location: Redwood City
Posted: Fri Aug 21, 2015 11:06 am Post subject: |
The common early 2.2l Subaru OEM filter housing (1990-1994) has a 90 degree connection to the MAF. Here is a picture:
Common later Subaru OEM filter housings (1995+) have a 45 degree connection to the MAF.
The later ones fit a little better in a Vanagon. _________________ 1988 Westfalia automatic Subaru OBD1
1986 syncro tintop wbx |
