Z Samba Member
Joined: June 15, 2003 Posts: 2517 Location: galveston, tx
Posted: Tue Apr 23, 2013 10:41 am Post subject: |
FYI, this is what the middle seat belt anchor bolt plates look like, inside the U-channel crossmember. Again, camera-suck, sorry.
EverettB Administrator
Joined: April 11, 2000 Posts: 69827 Location: Phoenix Metro
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Tue Apr 23, 2013 5:24 pm Post subject: |
Krustybus wrote: |
Just to add info to the thread, here's how to modify bay rear belt mounts for a split:
Stock bay left, modified for split right
Cut a couple small notches
Bend to 65 degrees and weld.
A lot easier than finding factory split brackets |
This is the kind of post I like to see. Well done. _________________ nothing |
CoastalAirCooledVW Samba Member
Joined: September 02, 2012 Posts: 1882 Location: Mckinleyville, CA (Humboldt County)
Posted: Sat Sep 07, 2013 1:50 pm Post subject: |
I modified some bay brackets like the post above to use in my 66 but now I am trying to find the bolts that hold the bracket to the gas tank tray. They are not the same size as the seat belt bolts. Went to the hardware store and they said they didnt have grade 8 metric in that size (arent metric bolts measured differently in strength anyway?) Any one know what size and what strength I should use and where to get them? Im trying to do this right and not half ass anything with big ass washers.... _________________ 1966 Velvet Green Standard |
Krustybus Samba Member
Joined: February 16, 2004 Posts: 442 Location: SE Michigan
Posted: Sat Sep 07, 2013 3:21 pm Post subject: |
The seatbelt bolts are SAE thread 7/16- 20
The lower bolts to the gas tank shelf are metric thread M10 x 1.5
Length of 25mm works. Hardened metric grade is 10.9.
Thicker metric fender washers are a good idea to spread the load and not tear through. _________________ Tim |
Posted: Sat Sep 07, 2013 4:05 pm Post subject: |
Krustybus wrote: |
Thicker metric fender washers are a good idea to spread the load and not tear through. |
Thanks _________________ 1966 Velvet Green Standard |
Posted: Tue Sep 10, 2013 9:51 pm Post subject: |
In my quest to not half ass these seat belts in any way I have missed a major piece of information. On a bay (and I assume on a factory seat belt split) there are thick brackets that the brackets behind the gas tank connect too. These connect to the rear portion of the frame and I assume provide much of the strength. What was the original split window set up like? I assume that there was some attachment to the frame, no? Z, do you have a picture?
Bay set up
Posted: Thu Sep 12, 2013 5:09 pm Post subject: |
No one with a factory seat belt bus can tell me how the seat belts are mounted? _________________ 1966 Velvet Green Standard |
Z Samba Member
Posted: Thu Sep 12, 2013 5:43 pm Post subject: |
I don't have a pic of what the brackets behind the gas tank connect to, but I'll be out in the garage later and will see what i can get for you. My bus is (thankfully) no longer sans transaxle and engine, but I think I can get a pic of what that looks like, or at least a description. |
Posted: Thu Sep 12, 2013 5:49 pm Post subject: |
Z wrote: |
Z Samba Member
Posted: Thu Sep 12, 2013 9:24 pm Post subject: |
OK...I think these will give a reasonable idea, at least enough to get you started making cardboard templates. I think these were pretty rudimentary pieces...no stampings or reinforcements...just crudely bent flat bar stock. Definitely factory, tho.
Should be easy to replicate, and simple to install if your motor and trans are out.
Posted: Thu Sep 12, 2013 10:29 pm Post subject: |
Awesome pictures and measurements, thanks. Hopefully this will help others not go the "big ass washer" route. Those brackets are much less sophisticated than I had imagined. _________________ 1966 Velvet Green Standard |
Z Samba Member
Posted: Thu Sep 12, 2013 10:40 pm Post subject: |
Yes, I was surprised at how basic they are. I never really paid them much attention before. |
Posted: Sat Sep 14, 2013 4:22 pm Post subject: |
I have now run into yet another problem . There is no way that I can drill the holes from inside the engine compartment because of the angle of the wall gets in the way. From underneath there is no way that I am going to be able to accurately drill the holes . For those who have added bay/split style brackets how did you drill the holes? Thanks _________________ 1966 Velvet Green Standard |
Downtown Brown Samba Member
Joined: May 29, 2004 Posts: 368 Location: Humboldt Nation
Posted: Sat Sep 14, 2013 10:00 pm Post subject: |
don't know how much room you have -- would this drill help?
Posted: Sun Sep 15, 2013 8:36 am Post subject: |
Something like that would help but I have decided to put this seatbelt project on hold since I need my bus to be running on monday. I was about to buy one of those drills but I would need a very short drill bit also. Everywhere I called locally said that they would have to order it. _________________ 1966 Velvet Green Standard |
stevo Samba Member
Joined: January 22, 2004 Posts: 908 Location: the eugeniverse
Posted: Sun Sep 15, 2013 9:08 am Post subject: |
i don't get it. if you're in the same county why not borrow his drill for a small job, clip down a bit, and have the safe driving you want? |
Posted: Sun Sep 15, 2013 9:18 am Post subject: |
stevo wrote: |
Didnt even notice that . I have been told that if you clip down a bit it will chew up the inside of the drill when drilling through metal. I already installed my bay gas tank last night (a real PITA) and I am just going to wait until I have everything ready. Thanks to all that have helped _________________ 1966 Velvet Green Standard |
type2vw Samba Member
Joined: March 07, 2002 Posts: 179 Location: Recovering in Summerfield, FL
Posted: Fri Aug 21, 2015 12:12 am Post subject: |
Thanks for going through all the procrdures so now I know what to do to get the job done. Thanks for the great pics, measurements, and info. My family thanks you too! _________________ No more VW's. Just a garage full of toys and literature. |
JDV Samba Member
Posted: Sun May 08, 2016 10:20 pm Post subject: Re: Rear Seat belt/Middle seat belt mounting |
Any chance someone could post some measurements for drilling and mounting the brackets for the rear seat belt mounts. |
