Paulbeard Samba Member
Posted: Thu Aug 20, 2015 12:39 pm Post subject: Steering wheel height/dash visibility options |
Since I may be doing another R&R of my dash (I found a new in the box blower fan in some stuff that came from the PO — after I redid the heater box) to replace the blower fan and and track down a couple of other gremlins, are there any options to gain some instrument visibility?
This is what I get:
The column is at the stock location, not lowered as I had suspected (van was redone for a diminutive person and I thought perhaps the wheel had been lowered for her). So raising it seems unpossible. I have tried all the adjustments I can find in the seats but they have no height adjustment, just F<->R travel and recline, none of which seem to do very much. I'm not a recliner by nature so that doesn't feel right.
It's not a huge deal. My driving habit of many years is to scan the gauges periodically and it's distracting/disruptive to look down and not see them. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
Merian Samba Member
Posted: Thu Aug 20, 2015 1:40 pm Post subject: |
larger dia. wheel
not much in the way of gauges to see anyway tho - just drive until a buzzer goes off, then grab the fire extinguisher and run |
syncroluvr Samba Member
Joined: October 11, 2010 Posts: 200 Location: Trois Rivieres,QC
Posted: Thu Aug 20, 2015 1:52 pm Post subject: |
A couple of weeks ago someone asked the same question. I think Dylan suggested lossening the 4 retention bolts and lifting it a it higher, maybe try a search? _________________ 1990 Syncro Westy with stump pulling 2576cc Subaru
Y2K V6 Passat
Calcandi Leviter |
newfisher Samba Member
Joined: January 05, 2012 Posts: 1764 Location: The wet spot--Oregon
Posted: Thu Aug 20, 2015 3:34 pm Post subject: |
Does the drivers seat have a swivel base? Do you use it? If yes and no, remove it to lower the seat 1 inch. |
Posted: Thu Aug 20, 2015 3:42 pm Post subject: |
Swapping to a larger steering wheel from a bus without power steering worked for me. |
idahoskier Samba Member
Joined: March 30, 2009 Posts: 161 Location: Donnelly, ID
Posted: Thu Aug 20, 2015 3:47 pm Post subject: |
I have a smaller diameter wheel so my needs will not be the same as yours. I was able to gain visibility of the part of the gauges I needed by lowering the column and raising the instrument cluster. I built a spacer that sits under the cluster and raises the leading edge about 3/4". It works for me and no one can even tell there is a spacer in there. I think it may be possible to lower the cluster a bit if you only need a small amount but it depends on how much you want to mess with it. Cheers! _________________ 85 Westy w/ 2.2L Subaru
91 Westy w/ 2.5L Subaru - sold |
danfromsyr Samba Member
Posted: Thu Aug 20, 2015 3:55 pm Post subject: |
it was Paul here with the same question (inpart) a few weeks ago..
apparently hasn't come to a satisfactory conclusion yet.
http://www.thesamba.com/vw/forum/viewtopic.php?t=632869&highlight=
syncroluvr wrote: |
A couple of weeks ago someone asked the same question. I think Dylan suggested lossening the 4 retention bolts and lifting it a it higher, maybe try a search? |
my take. we remove the DS swivel and use the oem pass van rails.. but many may not have the stomach to take a grinder to their vans. _________________
Abscate wrote: |
Posted: Thu Aug 20, 2015 4:09 pm Post subject: |
idahoskier wrote: |
I was able to gain visibility of the part of the gauges I needed by lowering the column and raising the instrument cluster. I built a spacer that sits under the cluster and raises the leading edge about 3/4". It works for me and no one can even tell there is a spacer in there. I think it may be possible to lower the cluster a bit if you only need a small amount but it depends on how much you want to mess with it. |
This is where I may be heading with this. A couple of longer screws up front and some kind of easily worked material is all it would take.
When you say lifting "it" a little higher, what it is intended? The column can't go higher. Do you mean extending the column/raising or lowering the wheel?
I realize the gauges don't say much but again, if you're in the habit of periodically scanning them as you drive — I still check my mirrors when I know there is no one there from the last time I looked because habits/muscle memory are a thing — learning to ignore them isn't a solution. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
— dhaavers |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7756 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Thu Aug 20, 2015 4:36 pm Post subject: |
After your recent dash project, make sure you've pulled the steering column
back to it's full length before bolting in place...there is some play at the rubber
coupler near the floor and it tends to lose altitude while unbolted. I noticed the
same issue after my first dash job and this is where I found the problem.
Good luck!
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
spitsnrovers Samba Member
Joined: December 17, 2005 Posts: 924 Location: Calgary, Canada
Posted: Thu Aug 20, 2015 5:08 pm Post subject: |
After installing non original VW seats, I experienced the same problem. But as I was going to build a tilt steering system, I added 1 inch to the column length. Solved the visibility problem.
Not suggesting you'd need to or want to make a tilt steering mechanism, but perhaps you can add 1" somewhere in the steering shaft.
Tilt steering here:
http://www.griffco.ca/interest/vw/steer.htm _________________ '88 VW Westfalia
'75 Triumph Spitfire 1500 |
Posted: Thu Aug 20, 2015 5:20 pm Post subject: |
Quote: |
we remove the DS swivel and use the oem pass van rails.. but many may not have the stomach to take a grinder to their vans. |
This sounds good, what would need to be ground out? _________________ 1990 Syncro Westy with stump pulling 2576cc Subaru
Y2K V6 Passat
Calcandi Leviter |
Posted: Thu Aug 20, 2015 6:45 pm Post subject: |
dhaavers wrote: |
After your recent dash project, make sure you've pulled the steering column back to it's full length before bolting in place...there is some play at the rubber coupler near the floor and it tends to lose altitude while unbolted. I noticed the same issue after my first dash job and this is where I found the problem. |
Mine is the same as it was before I R&R'ed the dash or near enough to make no difference. I remember wrestling a bit with that assembly…something to look at. I won't expect Bentley to have a factory distance measurement from firewall(?) to wheel. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
— dhaavers |
Posted: Thu Aug 20, 2015 7:16 pm Post subject: |
you need to do the opposite of this, but involves a grinder that can ignite carpet and impregnate glass.
add in that the swivel bases (all 3 pieces) are of value (IMHO) to all non-westy owners, incl GLs, weekenders and multi-vans.
syncroluvr wrote: |
This sounds good, what would need to be ground out? |
Abscate wrote: |
Posted: Thu Aug 20, 2015 7:58 pm Post subject: |
How much visibility are you needing to create? Move the wheel up or down? The required movement will depend on your specific viewing position. In my case the wheel cut off the top of the gauges after I installed Eurovan seats. I played with the steering column position and found no satisfactory way to raise the wheel high enough without the tilt column idea. It is easy to add spacers to drop the column and thus the wheel (I have a smaller diameter wheel from a mk1 so the wheel is not in my way). Doing this in addition to raising the instrument cluster allows me to see over the wheel and have a good view of the gauges (the top of the wheel sits above the clock and over the blanks in the center of the cluster). However, I am 6' tall and have gained an inch in seating height from the Eurovan seats. I did have the idea at the time of dropping the cluster and thought it would be doable but more work. I can take a pic of my setup this weekend if you think it would help. _________________ 85 Westy w/ 2.2L Subaru
Posted: Thu Aug 20, 2015 8:35 pm Post subject: |
idahoskier wrote: |
How much visibility are you needing to create? Move the wheel up or down? The required movement will depend on your specific viewing position. In my case the wheel cut off the top of the gauges after I installed Eurovan seats. I played with the steering column position and found no satisfactory way to raise the wheel high enough without the tilt column idea. It is easy to add spacers to drop the column and thus the wheel (I have a smaller diameter wheel from a mk1 so the wheel is not in my way). Doing this in addition to raising the instrument cluster allows me to see over the wheel and have a good view of the gauges (the top of the wheel sits above the clock and over the blanks in the center of the cluster). However, I am 6' tall and have gained an inch in seating height from the Eurovan seats. I did have the idea at the time of dropping the cluster and thought it would be doable but more work. I can take a pic of my setup this weekend if you think it would help. |
I'm also 6-0 which is why I am surprised this is so unusual. The picture above should help: I am missing the top of the gauges which is where the action is when I'm driving. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
— dhaavers |
j_dirge Samba Member
Joined: August 08, 2007 Posts: 4641 Location: Twain Harte, CA
Posted: Fri Aug 21, 2015 8:25 am Post subject: |
Paulbeard wrote: |
I'm also 6-0 which is why I am surprised this is so unusual. The picture above should help: I am missing the top of the gauges which is where the action is when I'm driving. |
I'm 6-3 and a longer than average torso..
My 89 Westy has the swivel AND I swapped in the thicker padded passenger van seat (which is taller).
As I typed in the thread linked earlier..
I move the seat base forward so the seat base is about even on the sliders..
Then I recline to second to last click (for in-town) and last click (for HWy).
I can see the gauges well enough to read the numbers.
No hacks.. no spacers.. no grinders.. _________________ -89 GL Westy, SVX.. finally.
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
danfromsyr wrote: |
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
Posted: Fri Aug 21, 2015 8:26 am Post subject: |
Sorry about the crappy photos and the dirty van This is close to what my view is now as it depends on how much I recline the seat. The wheel actually sits just a bit higher in my view. It is easy to shift slightly to see the temp and fuel gauges:
This is the spacer under the cluster (made of wood and covered with vinyl):
I also lowered the column about 3/4" but did not grab a pic of that though you can see how much lower the column/ignition cover sits. Certainly not for everyone but lets me see what I want to see. YMMV _________________ 85 Westy w/ 2.2L Subaru
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
