clutch alignment without alignment tool
penthink
penthink is offline
PostPosted: Mon Apr 18, 2005 12:52 pm    Post subject: clutch alignment without alignment tool Reply with quote
Anyone have any secrets on how to accomplish this? My clutch alignment tool has grown legs...
www.mainesaltwater.com
Ace
Ace is offline
PostPosted: Mon Apr 18, 2005 12:56 pm    Post subject: Reply with quote
Just make sure it is aligned to the center looking down the end of the clutch assembly. It's pretty easy to do visually. Make sure that the bolts are only finger tight until you get it aligned.
earthmuffin
Samba Worm Farmer
earthmuffin is offline
PostPosted: Mon Apr 18, 2005 12:57 pm    Post subject: Reply with quote
Get a 1/4 drive extension and wrap it with masking tape on the end so it fits snug in the pilot. Then wrap it again to a larger dimension where it sits in the clutch disc. Use it to center it and snug the pressure plate down. Once you have it all done, give it a visual to make sure it looks centered before you stab the engine.
I've used this little ghetto trick successfully several times.
This thread SUCKS!!!
panasonic90
panasonic90 is offline
PostPosted: Mon Apr 18, 2005 1:10 pm    Post subject: Reply with quote
I did it poking my finger through the middle hole and feeling if it was centered. It is not something super critical, an eye aproximation does the trick.
"May the fweem be with you"
Obi Volks Kenobi
74 bay ambulance
type 4 2lt carbs engine
covelo
covelo is offline
PostPosted: Mon Apr 18, 2005 1:47 pm    Post subject: Reply with quote
That's what I did recently (without the masking tape) and it worked well. It helps to have an extra pair of hands to hold the thing horizontal while you're fingertightening the bolts.
I wonder if, when it's not perfectly aligned whether it will once everything is mated and you put your first load on the engine and release/reengage the clutch. (I hope so, because it may have been a mm or so off).
jeb1978
jeb1978 is offline
PostPosted: Mon Apr 18, 2005 1:48 pm    Post subject: Reply with quote
I use a Craftsman 3/8" drive 10 mm deep socket. The shallow end fits perfectly in the gland nut.
Just remember to remove when you are done torquing up the pressure plate.
twinfalls
twinfalls is offline
PostPosted: Mon Apr 18, 2005 2:43 pm    Post subject: Reply with quote
Do not worry.
At the first declutching, the disk is free to find it's final alignement.
Stock 1974 US Westy, AW-A 1800cc dual carbs. Twin Falls is my favorite site on the Churchill river in Manitoba.
earthmuffin
Samba Worm Farmer
PostPosted: Mon Apr 18, 2005 6:44 pm    Post subject: Reply with quote
twinfalls wrote:
Do not worry.
The alignment is only for the purpose aligning the clutch disc to make way for the tranny input shaft. If you can get that baby to slide in, it will find its way to alignment nirvana all on its own. The frustrating part is when it is off and you are trying to assemble the engine to the transaxle. Make a guy want to start throwing tools and stuff. Very Happy
Randy in Maine
Randy in Maine is offline
PostPosted: Mon Apr 18, 2005 7:15 pm    Post subject: Reply with quote
Nice tip guys.
It is in. I am tired. I am dirty. A cold beer, hot shower, I am off to bed.
josh
josh is offline
PostPosted: Mon Apr 18, 2005 7:25 pm    Post subject: Reply with quote
Lost my alignment tool and eyeballed the clutch alignment. I had never had an engine mate so damn easily. Iv'e tried it again with the same results. Now I know where the tool is but I never use it. I was working with a friend and when I did this he asked why I didn't have an alignment tool. When I told him I had one but didn't want to use it he thought I was nuts...until we slid the engine in.
Schmooey
Schmooey is offline
PostPosted: Mon Apr 18, 2005 9:46 pm    Post subject: Reply with quote
I lost my alignment tool during the Carter administration, and have eyeballed it ever since. Laughing
penthink
penthink is offline
PostPosted: Tue Apr 19, 2005 3:13 am    Post subject: Reply with quote
For the love of God, that is why I am not an engineer. I would have sat at the back of bus crying all night because I had no way to get my engine back in. Thanks for the tip guys. As Randy said, but I am drinking bourbon instead of beer.
