peaceful warrior Samba Member
Joined: January 22, 2005 Posts: 5274 Location: Taoswest, USA
Posted: Sun Sep 06, 2015 4:53 pm Post subject: Help identifying this exhaust question. |
I am trying to identify the exhaust but I am confused as whether it is a Type 4 or Type 3 exhaust. See the photos.
Thank you.
_________________ "Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
"Notchboy" says "Man up!"
"Tram" says " My bus is bigger than your bus."
66 13W Deluxe, 68 Westfalia, 87 Syncro.
TOOB Member #15
Brian |
D/A/N Samba Member
Posted: Sun Sep 06, 2015 4:56 pm Post subject: Re: Help identifying this exhaust question. |
peaceful warrior wrote: |
Thank you.
That preheat pipe on the left suggests a carbureted motor. I'm not sure what is meant by "Typ V 71" but the info below that says quite clearly that the exhaust is for a 61-64 Variant. |
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Sun Sep 06, 2015 4:59 pm Post subject: |
It's for the early Type 3, either 62-63 with PHN carb, or the later N model 64-65, with the later PHN 1 or PHN 2 carb. The extra pipe on the left is the carb pre-heat tube. |
Posted: Sun Sep 06, 2015 5:05 pm Post subject: |
Thanks D/A/N and Ataraxia.
That is why I was confused because of the Type V marking.
Know anyone that needs it? I think I picked it up for my Type 34 but it was incorrect for my 66. _________________ "Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
TOOB Member #15
Brian |
Posted: Sun Sep 06, 2015 5:07 pm Post subject: |
Know anyone that needs it? I think I picked it up for my Type 34 but it was incorrect for my 66. |
You need the later version with separate small heat exchangers for a 66, if T34 is the same as T3.
Someone in the 1500 Club should snap it up if the price is right... |
Posted: Sun Sep 06, 2015 5:12 pm Post subject: |
ataraxia wrote: |
You need the later version with separate small heat exchangers for a 66, if T34 is the same as T3. |
Yeah, I found that out after I picked it up.
Thanks, I will try to price it fairly. _________________ "Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
TOOB Member #15
Brian |
Bobnotch Samba Member
Posted: Sun Sep 06, 2015 8:19 pm Post subject: |
ataraxia wrote: |
I bought 1 like that for my 64 T-34 with dual carbs. I just used a bug block off plate and gasket to cap the tube. Worked just fine. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22728 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Sun Sep 06, 2015 9:34 pm Post subject: |
ataraxia wrote: |
Thanks, I will try to price it fairly. |
I was going to ask you about it but I see it's pending at $250. Damn. That was fast and i thought it was priced slightly high! I should pull the 3 or 4 NOS ones I have down out of the rafters. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
