Engine Noise at Idle
rickb67
rickb67 is offline
PostPosted: Wed Sep 16, 2015 9:01 am    Post subject: Engine Noise at Idle Reply with quote
I purchased a car from a former member. He sent me a video of the car running and told me that there was a helicopter running in the background. Well the helicopter type noise is the engine. It runs alright except at idle the engine rocks. What should I look for... Nose cone?.... Transmission Mount bushings?
FreeBug
FreeBug is offline
PostPosted: Wed Sep 16, 2015 1:50 pm    Post subject: Reply with quote
Helicopter noise? First thing to check is if there isn't a rag or something on the fan, sucked in from behind the shroud.
66brm
66brm is offline
PostPosted: Wed Sep 16, 2015 1:55 pm    Post subject: Reply with quote
Sounds like its missing on a cylinder or two, if it has dual IR carbs it may be plugged idle jets or miss adjusted idle mixtures
Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote:
I am an expert at fitting things in holes, been doing it a long time
theDrew
theDrew is offline
PostPosted: Wed Sep 16, 2015 3:20 pm    Post subject: Reply with quote
check for exhaust leaks too...they have a sharp snap of kind sound...at least on my exhaust
Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
1985 Vanagon Campmobile w/ 2005 EJ25
rickb67
rickb67 is offline
PostPosted: Thu Sep 17, 2015 11:43 am    Post subject: Reply with quote
I can actually watch the engine rock. Even the slightest increase in RPM silences it.
jason
jason is offline
PostPosted: Thu Sep 17, 2015 4:20 pm    Post subject: Reply with quote
Take the fan belt off and let it idle. My brothers car sounds like a helicopter at low idle, his fan shroud. Goes away around 1000 rpm. Gave it a few pushes and pulls, good to go.
