MeeferMadness Samba Member
Joined: June 14, 2004 Posts: 305 Location: Eugene Oregon
Posted: Thu Sep 17, 2015 10:21 am Post subject: 1959 Front Seats |
I am putting together a pair of front seat frames for my 59 from a bunch of parts and have some questions. Are the drivers and passenger seats both the same? Also the seat back adjusters; are they both in the same location for both seats? And lastly there is a nylon "nub" on the seat rake adjuster, is there supposed to be the same "nub" on the opposite side as well? See photos.
Thanks
Bruce Ebling |
bluebus86 Banned
Posted: Thu Sep 17, 2015 11:34 am Post subject: Seat Adjuster |
Thanks! That is good to know so I don't assemble them backwards. Would you know if there needs to be a nylon "nub" on both sides of the seat?
Bruce |
bluebus86 Banned
Posted: Fri Sep 18, 2015 5:03 pm Post subject: Seat adjuster |
In the second photo you can see a white circle that is a piece of plastic that is spring loaded. It snaps into the dimples cut into a matching round piece of metal as the adjuster is turned. I see the plastic "nub" on the adjuster side of the seat, but found none on the inside (tunnel) side of the seat frame.
Bruce |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Fri Sep 18, 2015 5:03 pm Post subject: Re: Seat Adjuster |
MeeferMadness wrote: |
Bruce |
That nub acts as detent for the eccentric back rest adjuster. Both seats should have them _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
Posted: Fri Sep 18, 2015 5:07 pm Post subject: Seat adjuster |
I realize they are on each seat, but are they on both the door and tunnel side of each seat? In other words does each seat require one or two sets of the nub/springs?
Bruce |
gulfvet Samba Member
Joined: August 12, 2013 Posts: 14 Location: Northwest
Posted: Mon Sep 21, 2015 10:07 pm Post subject: Re: Seat adjuster |
Bruce |
on my 67 only one side |
cbdubs Samba Member
Joined: December 13, 2013 Posts: 87 Location: Scarborough UK
Posted: Tue Sep 22, 2015 5:00 am Post subject: |
On my 58 bug the seats are the same with the back rest adjuster knob on the right hand side of the seat. This could be useful when the drivers seat wears I can just swap them around. |
