Lidpainter Samba Anti-Hero
Joined: January 21, 2004 Posts: 2045 Location: 41.77 | -83.56
Posted: Tue Sep 22, 2015 8:44 pm Post subject: WW Stroker Crank Question |
I did a search but I could not find this info. Please don't flame me if I missed something obvious. I was wondering what pistons and rods are supposed to be used with the Wolfsburg West 36 hp stroker crank. Any info would be great. Thanks. _________________
EverettB wrote: |
Thanks, time to bulk up on meat! |
Jonnyla Samba Member
Joined: November 11, 2013 Posts: 101 Location: Mesa, AZ
Posted: Tue Sep 22, 2015 9:30 pm Post subject: |
I believe stock pistons and cylinders along with some shims between the cylinders and block. I may be way off but I think I read that somewhere... So basically someone with more knowledge needs to pipe in still. _________________ '55 3 fold sedan, stock with lower stance (project)
'57 sedan, future old speed outlaw style (project) |
Robert Chambers Samba Member
Posted: Wed Sep 23, 2015 4:31 am Post subject: |
The WW Okrasa Kit was covered a couple of times in the Dune Buggy and Hot VWs magazine. July 2010 first, then again in July and August , 2015. Not sure if it will answer all your questions, but they are a good reference for me. I have been following these threads and articles for a similar build. I recently bought an early Porsche crankshaft for my 36 dual carb build. Good luck with yours! _________________ '63 OG 117 Herbie Replica
'56 Euro Oval Deluxe
'52 Standard Zwitter
'63 OG 117 |
tobiasax Samba Member
Posted: Wed Sep 23, 2015 11:21 am Post subject: Re: WW Stroker Crank Question |
Lidpainter wrote: |
I did a search but I could not find this info. Please don't flame me if I missed something obvious. I was wondering what pistons and rods are supposed to be used with the Wolfsburg West 36 hp stroker crank. Any info would be great. Thanks. |
Hello, the stock rods need a light grinding and stock Pistons need to be modified. See my drawing at: http://lowlightkaizen.blogspot.se/2014/04/piston-clearance-for-695-mm-ww-crank.html?m=1 _________________ __________________________________________ |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14576 Location: 18 miles North of the border
volksartist Samba Member
Posted: Wed Sep 23, 2015 3:48 pm Post subject: |
Pushrod spacers as well. |
Posted: Wed Sep 23, 2015 8:51 pm Post subject: |
volksartist wrote: |
It depends on the rest of the engine. My heads was machined down somewhat so I achieved good valve train geometry without spacers.
Lessoned learned: don't do anything to the pushrods until the engine is assembled. _________________ __________________________________________ |
Daniel hunt Samba Member
Posted: Tue Jan 03, 2017 2:54 am Post subject: Re: WW Stroker Crank Question |
I'm also going with the 69.5mm stroker counterweight crank in my 1959 bug. also going with a 80mm by 64mm big bore kit by AA performance requires machine work but will be worth it.
struggling on conrods though I read somewhere that staying with the stock length conrod will cause extra stress and so on. And so should use 5.394 length conrod instead. anyone got any experience with this or just knows if this is correct.
Also what needed/how much machining was required to the heads to allow a 69.5mm stroker?
Only info I find is to add shims but how much exactly and what I'm unsure.
btw I'm very new to the VW scene. |
Posted: Tue Jan 03, 2017 10:29 am Post subject: Re: WW Stroker Crank Question |
Daniel hunt wrote: |
Stock con rods work just fine.
You need a spacer that builds approx. half the increased stroke (69,5-64)/2=2,75 mm
The extra stroke will increase the compression with a given set of heads. If you want to increase more you need to machine the heads, otherwise not. _________________ __________________________________________ |
EVfun Samba Member
Posted: Wed Jan 04, 2017 9:36 am Post subject: Re: WW Stroker Crank Question |
With the talk about spacers are all the stroked 36 horse motors running dual carb setups? I don't see how a stock intake manifold would fit. _________________
Wildthings wrote: |
sled Samba Member
Posted: Wed Jan 04, 2017 10:14 am Post subject: Re: WW Stroker Crank Question |
It's extremely easy to cut and lengthen the intake tubing. Exhaust pipes generally have to be modified as well. _________________ drive your split. |
EVfun Samba Member
Posted: Wed Jan 04, 2017 4:28 pm Post subject: Re: WW Stroker Crank Question |
sled wrote: |
It's extremely easy to cut and lengthen the intake tubing. Exhaust pipes generally have to be modified as well. |
I don't think I've ever seen a welded intake manifold. I would be concerned that good weld penetration would end up creating a weld bump inside and airflow disruption. _________________
Wildthings wrote: |
snowbug Samba Member
Joined: June 12, 2005 Posts: 167 Location: Oshawa Ontario Canada
Posted: Thu Jan 05, 2017 8:48 am Post subject: Re: WW Stroker Crank Question |
Lidpainter wrote: |
have a look at my build, I am not using any spacers. http://www.thesamba.com/vw/forum/viewtopic.php?t=589193 Jim _________________ Old enough to remember THRILLS, the gum that tastes like soap. |
