NobyDoby Samba Member
Joined: March 03, 2012 Posts: 101 Location: The Netherlands
Posted: Mon Oct 05, 2015 9:14 am Post subject: Sharing some Aircooled love |
After reading many many topics here on the Samba, I'm getting the idea that the Aircooled Vanagon isn't getting the love and appreciation it deserves. Many believe they are slow, unreliable and can't climb a bump in the road. On top of that they are heavy drinkers. So far the believes ....
Here is my story.
Last week I went on a 700 km trip from the Netherlands to the Belgium and French Ardennes (and back). That's the place in Europe where they didn't adapt the roads to the cars ...
With an almost fully loaded Westy we did extreme U-turns, climbs of 15 tot 21% and it never came below 70km/h (in 3rd) and almost always could hold 80km/h in 4th. It never gave a glitch or lost any parts.
The first half of the trip it did 8.12km per liter on regular gasoline (19 mpg). In the Ardennes I changed my vacuum curve a little with the result that it did 8.94km per liter (21mpg) on the second half. I must admit that the last 150km were down hill or flat
Yes I did some work to the engine but it's all finetuning and decent maintenance. No major changes.
So if you give your Aircooled Vanagon a little love it will give you a lot of Aircooled Love back. Even without breaking the bank (Very important because I'm Dutch ). _________________ 1980 Aircooled Type 4 CU 2.0L T3 Westfalia:
Flowed AMC 39x33mm heads with Porsche swivel adjusters and CR 8.0:1
94mm Mahle dished P/C's & 71mm Stroke
Original VW CU Bus Hydro Cam w/Febi Hydro Followers
Dual Dellorto's DRLA 40 - 32 Venturi's
SyncLink Throttle System
MSS Central Airfilter
123Ignition Tune & NGK BP6ET
Vintage Speed Dual Side Super Flow Type 4 Exhaust |
Zeitgeist 13 Samba Member
Posted: Mon Oct 05, 2015 9:24 am Post subject: |
It sounds like you've really got that AC engine dialed in perfectly. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Mon Oct 05, 2015 9:38 am Post subject: |
Yep.
Super smooth running engine with torque over wide rpm range. Starting at 125Nm @ 1500rpm, 148Nm @ 2500rpm - 3500rpm and 125Nm @ 4500rpm. Horses peaked with 82HP @ 4300rpm. _________________ 1980 Aircooled Type 4 CU 2.0L T3 Westfalia:
Satch Samba Member
Posted: Mon Oct 05, 2015 9:47 am Post subject: |
Nice report, sounds like a great trip. Good to hear the air cooled is treating you right. |
Fiddlestyx Samba Member
Posted: Mon Oct 05, 2015 12:24 pm Post subject: |
You get back what you put in. I feel like more people need to learn this. |
VWinVT Samba Member
Joined: April 21, 2013 Posts: 1541 Location: North East Kingdom
Posted: Mon Oct 05, 2015 5:49 pm Post subject: |
Wow! 82hp in an aircooler!?! That must have been big $$ for that build. My stock aircooler (67hp) does struggle with grades, especially when loaded. _________________ 1981 Westfalia with a 2001 Cabrio ABA
Small wheel turns by the firing rod,
Big wheel turns by the grace of God.
Every time that wheel turns 'round,
You're bound to cover just a little more ground. |
tim3 Samba Member
Joined: February 01, 2004 Posts: 547 Location: Los Angeles, CA
Posted: Mon Oct 05, 2015 6:20 pm Post subject: |
i love my aircooled.. I have taken it everwhere.. it cruises well above 70mph on the regular and getting about 20mpg freeway. _________________ Click to view image |
Howesight Samba Member
Joined: July 02, 2008 Posts: 3274 Location: Vancouver, B.C.
Posted: Mon Oct 05, 2015 6:34 pm Post subject: |
To the OP:
Here in most provinces and states in North America, we would not be permitted to replace the EFI with the dual Weber carbs due to emissions testing. The air-cooled engine gets additional cylinder head cooling from the evaporative cooling that carburetors provide. The Ardennes and other locations you are lucky enough to travel to are all generally much cooler climate areas than, say, Southern California, just to name one major area of Vanagon Westfalia vehicles. You also have much better fuel quality in Western Europe, especially higher octane petrol, which allows a tune with higher compression ratio and a more aggressive spark advance curve or map. In short, those locations are where the air-cooled engines experience ideal operating conditions.
Over here, the fuel, ambient heat, OEM design features (like EGR, very lean AFR in the EFI system), lower quality gasoline, and the high speed expectations of freeway travel all conspire to make the air-cooled Vanagon experience a short-lived and slow one. It is truly shocking how much difference ambient temperatures can make to the air-cooled Vanagon.
Your torque and horsepower figures are excellent! Could you share more of the details of your build for those brave enough over here to try a performance 2.0 AC build? _________________ '86 Syncro Westy SVX |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
Posted: Mon Oct 05, 2015 6:44 pm Post subject: Re: Sharing some Aircooled love |
NobyDoby wrote: |
Even without breaking the bank (Very important because I'm Dutch ). |
This is the best thing I've read on the internet today! This post makes me want an orange Bay Window Westfalia with your same motor. _________________ John - 86 Wolfsburg Westfalia "Weekender"
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
Posted: Tue Oct 06, 2015 12:24 am Post subject: |
My setup:
- untouched shortblok (original hydraulic CU cam) because this was already overhauled by previous owner
- new AMC heads with stock (39/33) valves (because the originals were cracked and valve guides came out by themselves)
- completely disassembled new AMC heads, checked all parts (all OK and within specs), only gave the valveguides a bit more clearance (too tight)
- ported heads and manifolds and reworked combustion chamber around the valves
- reworked valve and valve seats (3 angle)
- compression ratio to 8:1
- new valve train geometry with new pushrods and Porsche swivel feet adjusters
- short CSP manifolds (To let it all fit under the decklid)
- Dellorto's DRLA 40 with 32 venturi's with vacuum connections (because the original Solex's where leaking all over the place and one housing was severely cracked)
- velocity stacks
- original heat exchangers
- Vintage Speed exhaust
- MSS Central Airfilter (Expensive, not absolutely needed, but takes the breathing noiselevel down and looks cool )
- 123Ignition Tune distributor (with vacuüm connection) + Bosch spark plug wires + NGK BP6ET
- Dellorto's and distributor finetuned on rolling road
- Vacuum curve finetuned during last 2000km
Some pics and info can be found here: http://www.shoptalkforums.com/viewtopic.php?f=1&t=143948 posted under the same name. _________________ 1980 Aircooled Type 4 CU 2.0L T3 Westfalia:
THE KESZTHELY KID Samba Member
Joined: August 24, 2022 Posts: 27 Location: West Yorkshire
Posted: Tue Oct 10, 2023 5:29 am Post subject: Re: Sharing some Aircooled love |
Hiya Nobyd,
I just took a look at your link on ShopTalkForums.com and you have a Pant Wettingly stunning looking engine there.
I doff my hat to you.
DANK U for making me smile _________________ Current owner of 1980 T25 Westphalia Joker.
1973 Karmann Ghia Coupe - Semi-automatic!!
1983 Trabant 601S Sedan
Daily Driver - 2017 Renault Captur - Automatic |
Posted: Tue Oct 10, 2023 6:41 am Post subject: Re: Sharing some Aircooled love |
You're welcome! Happy to have made somebody smile.
Or in Dutch: Graag gedaan! Fijn om iemand een glimlach te kunnen geven. _________________ 1980 Aircooled Type 4 CU 2.0L T3 Westfalia:
GoEverywhere Samba Member
Joined: December 13, 2020 Posts: 516 Location: Portland, OR
Posted: Tue Oct 10, 2023 9:00 am Post subject: |
VWinVT wrote: |
Wow! 82hp in an aircooler!?! That must have been big $$ for that build. My stock aircooler (67hp) does struggle with grades, especially when loaded. |
Doesn't actually take that much if you can do the work yourself.
I built a 140HP 2.2L aircooled Type-4 when my first one died. All in it was about $2000 to use almost totally new parts. The cases and the heads were the only parts reused and the heads were totally rebuilt.
Now I can keep up with my VW club's Subie swapped rigs and still makes that aircooled sewing machine noises all at 27MPG at climbing grades at 60+! |
Posted: Tue Oct 10, 2023 9:03 am Post subject: |
Howesight wrote: |
To the OP:
Your torque and horsepower figures are excellent! Could you share more of the details of your build for those brave enough over here to try a performance 2.0 AC build? |
Actually not true! You can replace your EFI with carbs in a lot of states as long as you can still meet emissions standards for your year(I BELIEVE California is the only state you can't). I ran around with carbs on mine when I first built it because the stock EFI couldn't handle my big cam and passed emissions fine. I'm BACK to EFI with Megasquirt because EFI is better. But not because of any legal issues. |
Posted: Tue Oct 10, 2023 7:19 pm Post subject: Re: Sharing some Aircooled love |
Here in British Columbia, back in 2015, there was no way that a carbureted type 4 engine would have passed our strict emissions testing standards. But that is now history since our province has ended all emissions testing several years ago. I consider that decision to have been a poor one. The reasoning was that the new crop of internal combustion engines featured impressive emissions performance.
But since emissions testing ended here in BC, there are now so many (mainly younger) folks in new or nearly-new cars they have "tuned" by removing the Cat, installing aftermarket exhaust systems, and re-flashing their tunes. Driving behind these cars leaves you sucking awful choking fumes that could easily be cleaned up with CAT converters.
And don't get me started on the Diesel Dudes rolling coal with plumes so thick you can't even see through them. (They think this is amusing and establishes their "rebel" cred. )
Way back when emissions controls started in the late 1960's (with air pumps, reduced compression ratios and other primitive first steps to abate smog), there were real issues with the smog-engineered cars. They lost power, drivability, fuel mileage and even engine life in some instances. But today's EFI and direct injection engines make tons of power, are smooth, get great fuel mileage, and do all that with very low emissions - - until some A-hole decides to "improve" his new pickup by removing all that engineering and basting other drivers with his exhaust plume.
Okay, rant over. _________________ '86 Syncro Westy SVX |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22668 Location: NYC/Upstate/ROW
Posted: Wed Oct 11, 2023 1:45 am Post subject: |
GoEverywhere wrote: |
Howesight wrote: |
To the OP:
Unless your carb can meet and provide all emissions control functions of the FI system, it is a Federal crime to do this conversion for a vehicle on public highways in any State
The criteria is the replacement has to meet the same emission tests the manufacturer used to certify the car , not your States’ emissions testing _________________ .ssS! |
steve244 Samba Member
Posted: Wed Oct 11, 2023 8:12 am Post subject: |
Abscate wrote: |
Howesight wrote: |
To the OP:
The criteria is the replacement has to meet the same emission tests the manufacturer used to certify the car , not your States’ emissions testing |
At least here on Oregon where I am those emissions tests are amount of CO and amount of hydrocarbons emitted out the tail pipe along with a visual inspection for catalytic converter, EGR, and evap system if equipped from factory.
As long as I can meet the same emissions requirements it had and not remove the evap, EGR, and cat I can pass with carbs fine. I *DID* pass with carbs fine. |
Posted: Wed Oct 11, 2023 8:27 am Post subject: Re: Sharing some Aircooled love |
steve244 wrote: |
Book him, Danno.
Better keep your eye on me too.
GoEverywhere, would you share your parts list for the build?
Once my stock rebuilt is in, I want to adulterate the old engine the way you did. |
Gonna make me go dig out my build list huh?
Ok, here goes.
Stock type-4 cases. Already had a set so no extra cost.
76mm stroker crank from aircooled.net $749.95
QSC 96mm cylinder/piston set $238.00
reused the stock rods. Free
Stock type 4 heads cut for Porsche 914 size valves... Already had the heads. I think it was $200 at the machine shop to clean them up and install the bigger valves?
Scat C25 Camshaft $142
Scat Camshaft Gear $75
Crank bearings $22
Cam bearings $13
New pushrod tubes $36(Could have reused the old ones, but this was easier)
Vintage Speed headers $363
Engine Gasket Set $25
I reused the factory intakes, plenum, throttle body, and fuel injectors.
I had a friend with a Megasqurt2 he sold me for $100 but this would be about $350 if you had to buy another
Dubshop Crank Trigger kit: $160
IGN-4VW Coil Pack: $60.
Probably missing a few bobs and ends off that list, but thats my build at current prices. Looks like a few things have gone up since a few years ago when I built it.
That puts the total there at $2358 accounting for having to buy a new Megasquirt vs getting a deal like I did.
Thats good for 140 flywheel HP at 2200cc and a much nicer ride than stock power!
