Does it Exist?!? Odd Year Turn Signal
Page: 1, 2, 3, 4  Next
SamboSamba22 Premium Member
SamboSamba22 is offline
PostPosted: Mon Oct 05, 2015 7:25 pm    Post subject: Does it Exist?!? Odd Year Turn Signal Reply with quote
I am after this part!!! It is totally different than the 74+ setups! I cannot find it anywhere, does anyone know of such things existing??? Share with me good news! Does not have to be NOS, but I'll take what I can get. I'm searching far and wide. Thank you in advance folks! 1974 Westfalia
Tcash
Tcash is offline
PostPosted: Mon Oct 05, 2015 8:56 pm    Post subject: Reply with quote
Good luck on that one. This is the part number you are looking for.
211 953 509 H VW Bus 5 wire turn signal switch 73-74
The SWF (the manufacturer's) part number is HLS 201 096
Good luck
Tcash
PostPosted: Tue Oct 06, 2015 6:33 am    Post subject: Reply with quote
It seems as if this particular setup was only used for the tier end of 73 and a couple months in early 74. Doing electrical inspection and tracing, I noticed the entire plastic casing inside with the Actuator is completely busted, assuming from use. I live in Arkansas, where folks do not use turn signals, but I do have respect for others, and want to protect my bay in every circumstance, so the search for the part continues.
Thanks for the info Tim, still wish you had it for sale Laughing
MattJay1991
MattJay1991 is offline
PostPosted: Tue Oct 06, 2015 12:11 pm    Post subject: Reply with quote
Mine was temperamental, the turn signals worked but the high beam didn't. I took it apart to try and fix it but I was unable to.
By sheer luck I managed to find a guy who had got a NOS one. But i struggled before then.
I've still got what's left of my old one, not sure if the parts would be of any use to you to try and fix yours?
PostPosted: Tue Oct 06, 2015 1:01 pm    Post subject: Reply with quote
Matt,
I haven't really torn it apart, my issue is evident without the need of opening up the housing. Removing the steering column housing that goes around it, I noticed looking at the back where the soldered wires are visible that the plastic square part that the arm pivots in has cracked in the center, as you can see in the photo. I feel a little better knowing now, I'm not the only one trouble by this rarity.
Thing is just snapped right in half.
alman72
alman72 is offline
PostPosted: Tue Oct 06, 2015 1:14 pm    Post subject: Reply with quote
take it apart, take out the broken piece, glue it, and take it to be 3D printed.
OR, maybe, that particular piece is the same in other years.
or is this still available? http://forum.earlybay.com/viewtopic.php?f=11&t=67357&start=0
or this? http://www.evamclassic.com/split-bus/groep-9,-elektra/53.-richting-aanwijzers/p-1/
PostPosted: Wed Oct 07, 2015 11:38 am    Post subject: Reply with quote
Awesome leads Alman, I'm trying to figure a way to contact the gentleman (vwed) on earlybay.com without joining the site. Anyone a member willing to be a messenger for me? I'd like to contact him to see if he indeed still has it available. Looks promising, if he still has it.
Convoy
Convoy is offline
PostPosted: Wed Oct 07, 2015 11:51 am    Post subject: Reply with quote
Did you contact http://bustedbus.com/
PostPosted: Wed Oct 07, 2015 8:25 pm    Post subject: Reply with quote
Convoy,
I emailed them after you mentioned them, good looking out, though I am in luck. They do have one...buuutttt, take a breathe, they want $329.00 before shipping! Used! Whoa!!!! Like really, I understand the part being a rarity, but cmon, I thought BustedBus was cooling than that!
Well with that new info, and grateful they responded to my email, and quickly as they did, I'll have to continue to search elsewhere!
captincanuck
captincanuck is offline
PostPosted: Wed Oct 07, 2015 9:49 pm    Post subject: Reply with quote
Or if you could glue the cracked piece and then make a silicone mold and make a replacement piece with some resin. Might cost you $30 and you would have lots left over to make other stuff.
1979 Westfalia "FireFly" Subaru 2.2 with Subaru gears 5spd.
Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=634777&postdays=0&postorder=asc&start=0
Mellow Yellow 74
Mellow Yellow 74 is offline
PostPosted: Thu Oct 08, 2015 1:10 am    Post subject: Reply with quote
I bought a NOS one from Germany a couple of years ago - not cheap but I wouldn't expect a rare part sitting on a shelf for 40 year old to be cheap. There are NOS switches still available in Europe if you have a look and are prepared to pay enough:
http://www.aircooled-museum.com/achat-t2-72-74-turn-signal-switch-21738.html
http://have-a-nice-bay.nl/product_info.php?products_id=4029
1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon)
alman72
alman72 is offline
PostPosted: Thu Oct 08, 2015 3:48 am    Post subject: Reply with quote
so, does anyone know if that cracked piece is the same in an early or late bay switch? just swap the broken piece? I understand that the switch of the OP is different, but HOW different?
captincanuck
PostPosted: Thu Oct 08, 2015 8:41 am    Post subject: Reply with quote
I know its different in my 79 and the parts would not be interchangeable.
Convoy
Convoy is offline
PostPosted: Thu Oct 08, 2015 11:51 am    Post subject: Reply with quote
This is the exact same one in my 74. Knowing how rare and expensive these are to replace I might have to watch the young kids more carefully as they yank and switch it back and forth while playing in the drivers seat Shocked Shocked
SGKent Premium Member
SGKent is offline
PostPosted: Thu Oct 08, 2015 12:39 pm    Post subject: Reply with quote
get a hold of Ken at Busco.
PostPosted: Thu Oct 08, 2015 12:42 pm    Post subject: Reply with quote
Awesome Feedback guys, greatly appreciated. I do understand the expense of a vintage item, one rare at that. 160 euros isn't too bad, roughly $200 shipped. That's manageable for a NOS SWF item. I was just dumbfounded by BustedBus, as I've talked with the guys a handful of times, and they seem very cool and down to earth, but we all have bills to pay and hobbies to pursue, nonetheless so be it. Not speaking bad of the guys, again very nice folks. Looks like I'm going to be sending some dinero across the pond.
Convoy, now you know. Guard it with your life! haha Or let it go and say the hell with using turn signals, like the rest of the schmucks down here, you can tell they're turning when the give you the "get out of my damn way look with their eyes" once you're close enough to see their faces Laughing
Cheers guys!
Convoy
Convoy is offline
PostPosted: Thu Oct 08, 2015 12:51 pm    Post subject: Reply with quote
One last place to check. It's close to me and they typically have what I'm looking for.
Interstate VW Junkyard
http://interstateusedparts.com/
Call them and email them a pic.
SGKent is offline
PostPosted: Thu Oct 08, 2015 1:03 pm    Post subject: Reply with quote
FWIW - I would get the new one and know it will last as long as you own the bus.
alman72
alman72 is offline
PostPosted: Thu Oct 08, 2015 2:50 pm    Post subject: Reply with quote
sell the old one as a repairable/parts piece, to get back some of that hard earned money. or, if you a typical bus guy, put in in the parts stash just in case
scrivyscriv
Samba Electrician
scrivyscriv is offline
PostPosted: Thu Oct 08, 2015 5:16 pm    Post subject: Reply with quote
bad thing about turn signals is they are not really repairable... you can't really do any soldering on the assembly whatsoever or the platic just melts before you can even flow the solder. I ruined an old bug signal switch trying to fix it once and I can't ever really recommend trying to repair one.. Nice to see you've got an NOS headed your way. I'll be passing through LR Sunday night on the way to Texas - do you drive your bus around town?
Robert in Memphis
Engine rebuild thread
Page 1 of 4
