wesitarz Samba Member
Joined: August 20, 2012 Posts: 1491 Location: Victoria,B.C.Canada
Posted: Wed Oct 07, 2015 4:54 pm Post subject: 02 2.5L crank,no start |
Swapped out my t'stat yesterday and it would not start. The only electrical I touched was the temp sender. It cranks,no start. I have no fuel pump cycling or FP relay or ignition start relay clicking with the green test connectors together and ignition on. I have B+ power at the junction box with ign off pre and post fuse. With ign on I have no B+ power at the junction box, no power to the ECU,but have IGN+ power at the junction box and at the ECU. B+ measured 12.3 volts at the battery, but his battery is old (2 years past warranty). I have replaced the ignition switch with a new one from the dealer. Only thing I can think of is the battery. Any ideas? |
insyncro Banned
Posted: Wed Oct 07, 2015 5:12 pm Post subject: |
Disconnected crank or cam sensors will allow cranking but no firing. |
Posted: Wed Oct 07, 2015 6:45 pm Post subject: |
The B+ post in the junction box goes dead when the ignition switch is on. Does that mean the battery is toast (I Hope)? |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16508 Location: Brookeville, MD
insyncro Banned
Posted: Thu Oct 08, 2015 7:15 am Post subject: |
Does a relay in your wiring feed the post? |
Posted: Thu Oct 08, 2015 1:10 pm Post subject: |
Success! I jumped a wire from B+ post to B+ at the alternator with ignition on and green test connectors together and got relays clicking, fuel pump cycling. Must have a broken wire in harness from alt to B+ post - probably at a sharp kink.
Three crank/no starts this summer (1) ECU (2) ignition switch (3) no B+ power with ignition on (fun with vanagons!)
Got it bled after t'stat replacement using my Libby bong which was useful since I snapped off the plastic bleed screw on my new Nissens rad a while ago and it's now sealed with marine epoxy.
Soldered and shrink wrapped two wire slices in the junction bow for B+ and IGN+ from my original conversion wiring that were only taped together.
88 Wolfsburg auto with 02 Subaru 2.5L |
Posted: Thu Oct 08, 2015 4:43 pm Post subject: |
Maybe the bad wire was the problem the last time when I had a no start one day,but started the next day. I thought it was an intermittently bad ignition switch so I replaced it and it hasn't been a problem til now. Because it restarted,I didn't continue with voltage tests, but the ECU was not getting power. I was messing with the O2 sensor wires and the alt wire bending them and zap strapping them away from the catalytic converter. Maybe I partially broke the alt B+ wire at that time.I did check all the O2 wires for continuity and re-zap everything back up,maybe making a partial connection. Will have to trace it and see, but hat's a job for next summer. Ha,ha,ha,ha. |
