Fuel sender access hole, to do or not to do? |
To do |
55% |
[ 37 ] |
Not to do |
44% |
[ 30 ] |
Total Votes : 67 |
Tcash Samba Member
Posted: Mon Jun 09, 2014 4:15 pm Post subject: |
Does anyone have a picture of the measurements VW gave for cutting the hole ?
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Sun Jul 06, 2014 3:53 am Post subject: |
The pic is WRONG for a 70 bay!!!!!!!!!!!!!
hole ended up just to the right of the sender Oh well ,, got the fuckin gauge to work after all this now to patch a big hole _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Posted: Sun Jul 06, 2014 8:44 am Post subject: |
madmike wrote: |
hole ended up just to the right of the sender Oh well ,, got the fuckin gauge to work after all this now to patch a big hole |
If you have the correct dimensions it would be helpful if you would post them along with a pic. |
Posted: Tue Jul 08, 2014 5:40 am Post subject: |
Sorry no pic with this 'dial-up' I'm in the middle of an engine pull,,again
will post the correct measurements soon, _________________ 'Black Ice'Drag Buggy 'Turbo'
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Tue Jul 08, 2014 8:38 am Post subject: |
Follow the hatch latch post back, and from that rib, go two ribs to the right (one rib over works, two makes more room) and cut about 4 inches from the drop off behind the seat toward the hatch. 3 sides of the square you cut, fold the fourth..
Just did this last night to my 72...i feel guilty i hacked such a rust free bus, but i need that sender out! _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Tcash Samba Member
Posted: Tue Jul 08, 2014 8:50 am Post subject: |
madmike wrote: |
That is weird. The engine cover in the picture looks like an early one 68-71. Unless they used an old picture.
Early
Late
How much was it off?
Thanks |
dazwoods Samba Member
Posted: Thu Jul 10, 2014 5:49 am Post subject: |
madmike wrote: |
Mike, could you let us know the right measurements? Planning to do this on my 1970 bus... Cheers! _________________ '69 Westy
'64 Panelvan
'68 Beetle
'88 Caravelle GL
'88 Syncro Sika
'01 Passat PD
'xx Syncro Tristar (Yet to be found ) |
Posted: Fri Jul 11, 2014 4:34 am Post subject: |
800mm from the left and 880mm from the hatch will put the hole smack dab in the middle of the sending unit _________________ 'Black Ice'Drag Buggy 'Turbo'
Posted: Fri Jul 11, 2014 9:01 am Post subject: |
madmike wrote: |
800mm from the left and 880mm from the hatch will put the hole smack dab in the middle of the sending unit |
That sounds to be almost exactly what the VW instructions say, only about 1/4" off on the center of the hole, right to left. |
Tcash Samba Member
Posted: Fri Jul 11, 2014 11:09 am Post subject: Gas Tanks |
Thanks madmike
It appears the 71 sender unit is in a different location.
Which tank do you have.
68-70 baywindow gas tank
71 Gas Tank
72 fuel/gas tank |
Tcash Samba Member
Posted: Sun Dec 07, 2014 3:30 pm Post subject: Fuel Sender Access Hole |
Early
Late
Thanks to Speedy Jim's
WhirledTraveller Samba Member
Joined: January 09, 2008 Posts: 1399 Location: Cambridge, MA
Posted: Thu Oct 15, 2015 3:38 pm Post subject: |
FWIW I changed out my sender today without cutting an access hole and without pulling the tank. I did have the engine out but I could have done it easily without doing so (well, not as easy, but easy enough).
Just pull the firewall, take the vent tubes out of the way (change your rubber lines, mine practically crumbled into dust), then use a suitable tool and a mallet to tap tap tap the sender around. You can angle it around the forward LH side of the bus and out.
Hope my crappy aftermarket sender holds up. I did test it but the quality seems suspect. I can see how an access hole would be great if you had to do this all the time but if it's just a once every 5-10 year sort of thing it seems like more work to cut the hole. _________________ 1977 Westy, Automatic. Big Valve heads, CS Cam. |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16970 Location: San Diego, California
Posted: Thu Oct 15, 2015 7:57 pm Post subject: |
Your aftermarket sender with shit the bed within a year. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Thu Oct 15, 2015 8:31 pm Post subject: |
aeromech wrote: |
Your aftermarket sender with shit the bed within a year. |
Probably you're right but I don't know what else to do. I held onto my old one and maybe some winter evening I'll try repairing it with new wire according to that post somebody made. I wish there was an easy way to adapt an aircraft capacitive sender, no moving parts. But they output 0-5v which is incompatible with the VW gauge. _________________ 1977 Westy, Automatic. Big Valve heads, CS Cam. |
Posted: Fri Oct 16, 2015 6:25 am Post subject: |
I just replaced an aftermarket sender a couple months ago that looked really new. I installed an original VDO sender that had the Telford Repair done to it. That baby will last decades. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Wireless Samba Member
Posted: Tue Jan 19, 2016 7:10 am Post subject: Re: Fuel sender access hole, to do or not to do? |
I have an old 73 412 I keep for spares, as I have another 412, and am currently stripping the interior from my 76 Bay, and having the fuel gauge only registering the top 16 litres of fuel from full to empty, I believe I need to adjust the arm on my existing fuel sender to register the full tank from full to empty.
So I'm looking to fit one of these access panels.
I mentioned the 412 because in the load floor behind the rear seat is an access panel for the Eberspacher, and this looks identical to the one shown in the early illustration / pictures.
I think I'll be buying a new fuel sender for the Bay, and removing this 412 panel on the spares car, to see whether I'm right.
With the VW parts bin used as it was, I bet I'm right. _________________ 73 de M5WJF
1973 Volkswagen 412LS Variant
2000 Audi S3 Quattro
2014 Citroen C3 Airdream |
NASkeet Samba Member
Joined: April 29, 2006 Posts: 2958 Location: South Benfleet, Essex, UK
Posted: Tue Feb 14, 2017 9:26 am Post subject: |
rubbachicken wrote: |
aeromech wrote: |
Lettuce wrote: |
you guys are worried about fumes entering the bus... there should be no fumes coming from the tank |
Accidents happen. |
people also happen, ignore the cut in the tank, this bay tank had 5 screw holes in it, from a PO who fitted a home made interior, i guess they only had looooong screws
This picture reminds me of one of my local acquaintances, who installed a second-hand campervan interior into his 1973~79 VW "1700" Type 2 Kombi.
Either through ignorance or stupidity, he ended up drilling five holes in his fuel tank which resulted in a smell of petrol, of which he could not isolate the source, until I starting interrogating him.
Ultimately I supplied him with a second-hand 1974 VW 1800 Type 2 fuel tank I had spare, and took his perforated fuel tank in part exchange, which I later had repair-welded by another of my acquaintances, who many years earlier had repair-welded my corrosion-damaged Triumph Toledo (an amazing car, not sold in North America!) fuel tank. _________________ Regards.
Nigel A. Skeet
http://www.vwt2oc.net |
Posted: Tue Feb 14, 2017 9:32 am Post subject: Re: Fuel Sender Access Hole |
Late
[/quote]
Only the 1973 VW 17/18/2000 Type 2s had the horizontal, engine-compartment-ceiling, inspection-hatch.
The 1972 VW 1700 Type 2s and the 1972~79 VW 1600 Type 2s (including my 1973 VW 1600 Type 2) do NOT have the horizontal, engine-compartment-ceiling, inspection-hatch. _________________ Regards.
Nigel A. Skeet
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
Posted: Tue Feb 14, 2017 9:50 am Post subject: Re: Fuel sender access hole, to do or not to do? |
Got to ask,how often does the sender need service,I have owned probably 30 cars over the years,and only 1 or 2 times have I had to service a fuel sender.I have never cut a hole in a trunk or the box of a truck the get at it,don't think I would do it to the bus,also it may be a fire hazard unless the hole is well sealed. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=620186
1968 Dune Buggy
1974 parts bus
A smart man learns from his mistakes,a very smart man learns from other's mistakes. |
Posted: Tue Feb 14, 2017 10:00 am Post subject: Re: Fuel sender access hole, to do or not to do? |
I think I'm going to do it to my bus and here's why. The PO of my bus did an amazing job restoring the tank, engine compartment, and installing the engine. It's a work of art. The thing is that he must have installed an aftermarket fuel sender while doing the work and it's been in there for a few years. Now it's taken a shit. I have an original VDO sender that I want to install that's been repaired by Telford Dorr. So, do I want to pull the tank or cut a hole? I'm going with the logic that says VW would have installed an access hole if they could have but decided to keep things cheap and simple. I have donor metal to make the door. When i'm done I'm hoping that the access hole will look factory. I've done this a couple times so I know pretty well where to cut the hole. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
