Breezer Samba Member
Joined: April 19, 2005 Posts: 5 Location: Dunedin, FL
Posted: Tue Apr 19, 2005 12:04 pm Post subject: Dune Buggy Tire Size? |
I just picked up a dune buggy from an auction last week. I know very little about these things......so I'm starting to learn now I guess. The buggy has the same size tires and rims on the front and back. I'm not sure the exact size, but the front ones are only about a half to a full inch above the tires. You can see where the fiberglass has been rubbed a bit. I also noticed most buggys have the smaller tires on front. I was wondering if there's a way to lift the body so I can keep the wheels. It needs quite a bit of work so the less I have to put out to get it on the road the better. Oh yeah, it's a street legal buggy. I'd appreciate any advice. |
Nicksan Samba Member
Posted: Tue Apr 19, 2005 3:14 pm Post subject: |
Is it a baja bug? |
Posted: Tue Apr 19, 2005 6:11 pm Post subject: |
I added a picture of it in my profile. It is a fiberglass dune buggy that when running will be road ready. Do you have any suggestions? |
Posted: Tue Apr 19, 2005 6:24 pm Post subject: |
If its a stock vw pan then you can get a body lift just to keep that size tire but I dont know if that is stock, I have heard that those style buggies have shortened pans, anyone else know? If that is the case and if its a bug pan you can turn the rear torsion bars and that would give you the clearance you need. See the 2 stickys at the top of this forum for lifting. |
Posted: Tue Apr 19, 2005 7:17 pm Post subject: |
Cool......thanks for the info. How do I know if it's shortened? Do they shorten them because the fiberglass bodies are made smaller? I will try and figure out what type of pan I have. Thanks again. |
DavidLH Samba Member
Posted: Tue Apr 19, 2005 7:28 pm Post subject: |
Some buggy bodies require a shortened pan. Measure your wheelbase. Typical wheelbase for a shortened pan is 80 inches. Those big front tires will handle terrible. They are harder to steer as well. When I changed my wide tire/wheels to skinnys- was night and day! I suggest putting smaller tires up front. Yes you can put on a 3 inch body lift ( with minor mods to the kits). You could also cut and turn the beam for some added lift. You could also use lowered spindles. |
Posted: Tue Apr 19, 2005 7:42 pm Post subject: |
like I said before..........I don't have a clue about this stuff yet. So if I go with smaller rims and tires, what size is best for street use? ANd where is the best place to get a deal? |
HamburgerBrad Je suis Napoléon!
Joined: February 21, 2003 Posts: 6957 Location: SoCal
Posted: Tue Apr 19, 2005 8:07 pm Post subject: |
what size are your current wheels and tires? those tires look like balloons on there, maybe look for a 195/55 or 60 on the front and a 205/60 or 65 on the back _________________ OGST | CU05 | OGJHC
1970 baja|1953 oval
Wanted: two beat up, ugly, curb rashed 6" phone dial wheels |
iceluke Samba Member
Posted: Tue Apr 19, 2005 8:52 pm Post subject: |
I have 255/70r15 in the rear and 165/15 in front. looks real good on a f/g buggy _________________ dual purpose....more fun that way |
plasticman1432 Samba Member
Joined: January 19, 2004 Posts: 1180 Location: Nosebleed seats, NY
Posted: Tue Apr 19, 2005 9:08 pm Post subject: |
Mine has 225/60-14 in the front, and 275/50-15 in the rear; the 'big & little' look always seemed right to me anyway.
_________________ Organized people are just too lazy to look for stuff
'68 Meyers Manx: M1689D815E
http://public.fotki.com/VWDave/ |
carbaholic Samba Member
Joined: April 10, 2005 Posts: 134 Location: Provo, UT
Posted: Wed Apr 20, 2005 7:48 am Post subject: |
on my buggy I have the stock tire size up forn on a 14" rin and 30's in the rear with a 15" rim. All I have is a 1" body lift. I really like the look and it still handles and accelerated great with my 1835.
For your question of what tire size I think we need more info. Are you planning on making this a streetable baja or do you want it to be a street style that is lowered? This would help us to help you with what to do to this buggy. |
Joined: April 12, 2003 Posts: 1839 Location: Englewood, FL
Posted: Wed Apr 20, 2005 8:51 am Post subject: |
breezer, did you pick that up at the Buggy World closeout auction? _________________ Markus |
Posted: Wed Apr 20, 2005 10:27 am Post subject: |
OK, the tires on the front and rear are 235/75-15. I'm not sure how to tell what size the rims are? I measured straight across and I got a measurement of 16 1/4 inches.....does this sound right?
I plan to run it on the street, in my local area. I'm not sure what the difference is between the street styles you are asking about.
Yes I did pick it up at Buggy World! Did I meet you there? Do you have any advice? Like I said I have no clue what to do with this....I just want to get it up and running for a decent price.
By the way, Plasticman....where did you get that top cover? And how much was it? It gets HOT down here in Florida, so I'd love to pick one up. |
Posted: Wed Apr 20, 2005 10:49 am Post subject: |
First off the rim size is a 15 the tire size will be about a 29" tire. It's 28.9 to be exact. As for the street style or baja the differnt is a baja is lifted with much bigger than stock tires. A street style is going to be lowered some with wide low profile tires. both will have bigger engines and the basic upgrades will be the same. |
Posted: Thu Apr 21, 2005 2:50 pm Post subject: |
Breezer wrote: |
Mine was actually part of the kit, as offered by Meyers. They still offer them, but I'm not sure if it would fit other buggies without modification. Check out www.manxclub.com for details, and look in the 'store' section. _________________ Organized people are just too lazy to look for stuff
Posted: Thu Apr 21, 2005 8:03 pm Post subject: |
Breezer wrote: |
No I didn't go, I wanted to but funds were rather low and I figured it would be a freaking madhouse-as from what I heard it was! I heard you had to get your stuff out right away or it might get stolen out form under you when you weren't looking. A guy I talked to on another board said the F/G buggy body he won got stolen as he had to make two trips with all the stuff he bought. Buy the time he got back his buggy body was gone I bought alot of stuff from Bob over the years, I'm gonna miss that dirty old place!
As far as tips, well you need to figure out how you want to car to "look" before you worry about tires. If your not doing anything this weekend go to the Pier in St. Pete for the the VW show on Saturday (its free). and go to Maximo park (right off the skyway bridge/st pete side) on sunday about noontime. That is about when the 200+ VW's show up from going over the skyway bridge all at once. Theres always a few buggies there, you can kinda get an idea of whats running around. Its also one of the coolest things for VW's round these parts. If you go look us up- look for the green baja in my avatar, a "mystery Machine", and a westy camper sittin on small mud tires-thats where I'll be!
Fisher usually always has one or 2 built up Berrien buggies in the showroom as he is an authourized dealer, allthough try to keep form buying anything from them until you do some reasearch, you'll understand why after you get a little more price savy! _________________ Markus |
