eche_bus Samba Member
Posted: Thu Oct 22, 2015 9:01 pm Post subject: '76 Type 4 engine tin - What goes in this empty hole? |
1976 Type 4 GD engine. I have the fan shroud removed and am starting to put things back together. Just to the right of the breather box where the tin overlaps the block, there is a slot in the engine tin which leaves an open hole. It looks original and intentional, like something should go there.
What is supposed to go in or through the hole marked by the red arrow? |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51130 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Oct 22, 2015 9:20 pm Post subject: |
The dipstick if it's used in a 411/412 car. one tin and case for all uses. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Oct 23, 2015 9:53 am Post subject: |
Thanks, busdaddy!
For non-411/412 applications, should there be some kind of plug to seal the hole? |
Posted: Fri Oct 23, 2015 10:56 am Post subject: |
None that I've ever seen, but it wouldn't hurt to stick some sort of plug in there, every little leak adds up. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
