What's this Ghia part and Where does it go?
Page: Previous  1, 2, 3 ... 7, 8, 9 ... 23, 24, 25  Next
WooleyNelson
WooleyNelson is offline
PostPosted: Tue Aug 25, 2015 11:22 am    Post subject: Reply with quote
windlace holders? go in front of doors at the kick panels.....?
paul_round Premium Member
paul_round is offline
PostPosted: Mon Aug 31, 2015 6:46 am    Post subject: Reply with quote
Anyone know what this hole is for?
It's in the chrome trim on the top of the door, there's one at the other end too.
John Moxon Premium Member
John Moxon is offline
PostPosted: Mon Aug 31, 2015 7:15 am    Post subject: Reply with quote
Trim held in place by large headed brass screws at regular intervals. The trim where the larger slots appeared were placed over the screws and the trim slid sideways over the screw heads to be held in place where the trim slot narrows.
John.
My 1958 Karmann Ghia
PostPosted: Wed Sep 23, 2015 9:37 am    Post subject: Reply with quote
Sorry Joh, but I don't mean the slot, if you look above it, you will see that there is a threaded hole.
c21darrel
c21darrel is offline
PostPosted: Wed Sep 23, 2015 11:04 am    Post subject: Reply with quote
Hi Paul,
Best i can tell from the pic...
John is right, his comment reflects correct installation. It looks like your previous owner failed and used screws to hold the trim down. There should be no screw holes in any of the door top/qtr window chrome.
GhiaBuild
Sudar
Sudar is offline
PostPosted: Wed Sep 23, 2015 12:00 pm    Post subject: Reply with quote
maybe a set screw to hold it in place
1968 Ghia Coupe AKA "Harley"
kiwighia68
kiwighia68 is offline
PostPosted: Sat Oct 10, 2015 11:02 pm    Post subject: Reply with quote
Please help. I know this part belongs somewhere in the steering mechanism at the top under the steering wheel. But where?
My car is '68 RHD coupe.
Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015
Brassneck
Brassneck is offline
PostPosted: Sun Oct 11, 2015 1:46 am    Post subject: Reply with quote
I just posted on your thread..but in case you check here first, it's the turn signal cancelling ring...mounts to the bottom of your steering wheel base.
kiwighia68
PostPosted: Sun Oct 11, 2015 1:53 am    Post subject: Reply with quote
Thanks. It makes sense and explains the note I made 2 years ago when I took the car apart. I'll reassemble everything tomorrow.
O2COOLED
O2COOLED is offline
PostPosted: Sun Oct 11, 2015 2:12 am    Post subject: Reply with quote
It is the turn signal canceling ring but it appears to have been modified/cut to adapt to something.... rubbing problem maybe? Or to fit to a different steering wheel?
"Sometimes people forget they signed up to a HELP & SHARE Forum not a pissing contest"
"At my age time is too short to respond to people with short minds"
Current: '69 Ghia Coupe
VW History:'63 Bug;'70 Bug;'73 412;'83 Rabbit;'86 Golf;'76 Fat Chick; 67 Ghia Coupe; '70 Bug
-Zodiac-
-Zodiac- is offline
PostPosted: Mon Oct 26, 2015 2:08 pm    Post subject: Mystery tin Reply with quote
I recently took my engine out and this fell out from somewhere while undoing screws. I can't figure out where it goes or what it's called, any help is much appreciated.
1973 karmann ghia - current, not the last VW.
1947 Chevy stylemaster - gone, but not forgotten.
1995 Ford F-150 - gone, hatred for it lives.
c21darrel
PostPosted: Mon Oct 26, 2015 2:16 pm    Post subject: Reply with quote
its engine tin, look at #11
https://www.thesamba.com/vw/gallery/pix/783462.jpg
GhiaBuild
-Zodiac-
-Zodiac- is offline
PostPosted: Mon Oct 26, 2015 2:34 pm    Post subject: Reply with quote
Thanks Darrel, where's it go?
c21darrel
PostPosted: Mon Oct 26, 2015 5:10 pm    Post subject: Reply with quote
in back (back = back of car) under the cylinder head tin. The threaded holes go up and your bolts go thru cyl head tin into deflector piece threaded holes. There should be one for each side L/R
Using your pic Cool
https://www.thesamba.com/vw/gallery/pix/1281960.jpg
GhiaBuild
-Zodiac-
-Zodiac- is offline
PostPosted: Mon Oct 26, 2015 5:25 pm    Post subject: Reply with quote
Thanks man, you gotta give me a break its been a while Wink
60ragtop Premium Member
Bonneville Belt Bitch
60ragtop is offline
PostPosted: Fri Oct 30, 2015 1:35 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/classifieds/detail.php?id=1854483
Never saw any of these rare fender mount mirrors before for a ghia, only on a 65-67 bug inside Shocked
Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
Sharp64 wrote:
But thatís crazy talk. He must be made to comply!!!
TDCTDI wrote:
Jump on it some more & then LITFA.
[email protected] wrote:
aftermarket shit that always needs a tweek eats time
Eaallred wrote:
People are over analyzing.......(insert your problem here)
PostPosted: Fri Oct 30, 2015 1:55 pm    Post subject: Reply with quote
I think he should supply detailed fitting instructions with the mirror. Laughing
John.
c21darrel
PostPosted: Fri Oct 30, 2015 2:38 pm    Post subject: Reply with quote
Its the rare offset, 3 screw fender mirror, definitely ghia Wink
GhiaBuild
Jbc1116
Jbc1116 is offline
PostPosted: Mon Jan 11, 2016 11:04 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Hello everyone.
I been scouring this site and its been such a tremendous help.
I recently acquired @69 Ghia as my daily driver. I'm a huge newbie to all of this so I apologise in advance for some questions..
The previous owner put a 1915 cc engine with less than 2k miles on it. Looks like the car sat in garage for quite some time . Upon looking at the engine I was wondering what part is this .. The upper left hand corner at about the 10 o'clock position..
Thank you all
c21darrel
PostPosted: Mon Jan 11, 2016 3:10 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Hard to tell...looks like a previous owner opened up a port (removed tar board to cut) and attached white plastic covering it.?. If that is white plastic covering, have you opened it up?
GhiaBuild
Page 8 of 25
